| | Connection Issue I have a Toshiba Satallite 135 laptop W/ Vista sp1. Amusing a Linksys wrt45g with latest firmware. Router used in both lan and wireless mode. Problem. Can establish a network with laptop using WEP secure mode, but when attempting to establish connection in either WPA or WPA-2 using either AES or TKIP no network is created. |
| | Re: Connection Issue HI From the weakest to the strongest, Wireless security capacity is. No Security MAC______(Band Aid if nothing else is available). WEP64____(Easy, to "Brake" by knowledgeable people). WEP128___(A little Harder, but "Hackable" too). WPA-PSK__(Very Hard to Brake ). WPA-AES__(Not functionally Breakable) WPA2____ (Not functionally Breakable). Note 1: WPA-AES the the current entry level rendition of WPA2. Note 2: If you use WinXP and did not updated it you would have to download the WPA2 patch from Microsoft. http://support.microsoft.com/kb/893357 The documentation of your Wireless devices (Wireless Router, and Wireless Computer's Card) should state the type of security that is available with your Wireless hardware. All devices MUST be set to the same security level using the same pass phrase. Therefore the security must be set according what ever is the best possible of one of the Wireless devices. I.e. even if most of your system might be capable to be configured to the max. with WPA2, but one device is only capable to be configured to max . of WEP, to whole system must be configured to WEP. If you need more good security and one device (like a Wireless card that can do WEP only) is holding better security for the whole Network, replace the device with a better one. Setting Wireless Security - http://www.ezlan.net/Wireless_Security.html The Core differences between WEP, WPA, and WPA2 - http://www.ezlan.net/wpa_wep.html Jack (MVP-Networking). "jpoffy" <jpoffy@xxxxxx> wrote in message news:AAB8C33A-94D1-499B-93BC-FACE26B07797@xxxxxx Quote: >I have a Toshiba Satallite 135 laptop W/ Vista sp1. Amusing a Linksys >wrt45g > with latest firmware. Router used in both lan and wireless mode. Problem. > Can establish a network with laptop using WEP secure mode, but when > attempting to establish connection in either WPA or WPA-2 using either AES > or > TKIP no network is created. |
| SQL connection issue | VB Script | |||
| Connection issue after network connection | Network & Sharing | |||
| Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue | Vista networking & sharing | |||
| Connection issue | Vista mail | |||
