| | Problem networking XP & Vista My configuration: Established PC running XP Home SP2 New Laptop with Vista Home Premium Netgear Router with ADSL modem, Wireless access point & Ethernet switch What I can do: Access the internet from both machines Share files both ways using Net Use From Laptop apparently access printer on old PC using Net Use but it does not work What I cannot do Access the other PC (either way) by browsing (but I did on one occasion) Print from the laptop to to a printer attached to the old PC; on the laptop the document status is shown as "Error - Sent to printer" while nothing appears to occur on the the old PC. Any suggestions? |
| | Re: Problem networking XP & Vista Hi Install the printer Drivers on the laptop through the add networked printer process. Jack (MVP-Networking). "jack99" <jack99@xxxxxx> wrote in message news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx Quote: > My configuration: > Established PC running XP Home SP2 > New Laptop with Vista Home Premium > Netgear Router with ADSL modem, Wireless access point & Ethernet switch > What I can do: > Access the internet from both machines > Share files both ways using Net Use > From Laptop apparently access printer on old PC using Net Use but it does > not work > What I cannot do > Access the other PC (either way) by browsing (but I did on one occasion) > Print from the laptop to to a printer attached to the old PC; on the > laptop > the document status is shown as "Error - Sent to printer" while nothing > appears to occur on the the old PC. > Any suggestions? > > > |
| | Re: Problem networking XP & Vista If you can do the net use but not browser, it could be the computer browser issue. What's the system error, if you use net view command? For example, net view \\remotepcipaddress first and then net view \\remotepchostname. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "jack99" <jack99@xxxxxx> wrote in message news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx Quote: > My configuration: > Established PC running XP Home SP2 > New Laptop with Vista Home Premium > Netgear Router with ADSL modem, Wireless access point & Ethernet switch > What I can do: > Access the internet from both machines > Share files both ways using Net Use > From Laptop apparently access printer on old PC using Net Use but it does > not work > What I cannot do > Access the other PC (either way) by browsing (but I did on one occasion) > Print from the laptop to to a printer attached to the old PC; on the > laptop > the document status is shown as "Error - Sent to printer" while nothing > appears to occur on the the old PC. > Any suggestions? > > > |
| | Re: Problem networking XP & Vista Jack, thank you for your interest. I did what you suggested and it changed the problem. This time it went down a black hole; as viewed on the Lap Top it appeared to print but nothing was seen on the old PC. "Jack (MVP-Networking)." wrote: Quote: > Hi > Install the printer Drivers on the laptop through the add networked printer > process. > Jack (MVP-Networking). > > "jack99" <jack99@xxxxxx> wrote in message > news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx Quote: > > My configuration: > > Established PC running XP Home SP2 > > New Laptop with Vista Home Premium > > Netgear Router with ADSL modem, Wireless access point & Ethernet switch > > What I can do: > > Access the internet from both machines > > Share files both ways using Net Use > > From Laptop apparently access printer on old PC using Net Use but it does > > not work > > What I cannot do > > Access the other PC (either way) by browsing (but I did on one occasion) > > Print from the laptop to to a printer attached to the old PC; on the > > laptop > > the document status is shown as "Error - Sent to printer" while nothing > > appears to occur on the the old PC. > > Any suggestions? > > > > > > > |
| | Re: Problem networking XP & Vista Robert, thank you. All the Net View commands worked without error. In each case they listed the target machine's shares and when it was by name the user machines name for those resources was also listed. "Robert L. (MS-MVP)" wrote: Quote: > If you can do the net use but not browser, it could be the computer browser > issue. What's the system error, if you use net view command? For example, > net view \\remotepcipaddress first and then net view \\remotepchostname. > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > "jack99" <jack99@xxxxxx> wrote in message > news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx Quote: > > My configuration: > > Established PC running XP Home SP2 > > New Laptop with Vista Home Premium > > Netgear Router with ADSL modem, Wireless access point & Ethernet switch > > What I can do: > > Access the internet from both machines > > Share files both ways using Net Use > > From Laptop apparently access printer on old PC using Net Use but it does > > not work > > What I cannot do > > Access the other PC (either way) by browsing (but I did on one occasion) > > Print from the laptop to to a printer attached to the old PC; on the > > laptop > > the document status is shown as "Error - Sent to printer" while nothing > > appears to occur on the the old PC. > > Any suggestions? > > > > > > > |
| | #6 (permalink) |
| | Re: Problem networking XP & Vista If you can net view without problem, you may want to try LLTD. This post may help. Troubleshoot computers not ...Feb 18, 2007 ... Vista uses the LLTD protocol to map computers and devices on a network. The Link Layer Topology Discovery (LLTD) protocol is disabled on the ... http://www.chicagotech.net/netforums...opic.php?t=366 -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "jack99" <jack99@xxxxxx> wrote in message news:9D143500-BA73-4AF2-ACED-315BDF52C2C8@xxxxxx Quote: > Robert, thank you. All the Net View commands worked without error. In > each > case they listed the target machine's shares and when it was by name the > user > machines name for those resources was also listed. > > "Robert L. (MS-MVP)" wrote: > Quote: >> If you can do the net use but not browser, it could be the computer >> browser >> issue. What's the system error, if you use net view command? For example, >> net view \\remotepcipaddress first and then net view \\remotepchostname. >> >> -- >> Bob Lin, MS-MVP, MCSE & CNE >> Networking, Internet, Routing, VPN Troubleshooting on >> http://www.ChicagoTech.net >> How to Setup Windows, Network, VPN & Remote Access on >> http://www.HowToNetworking.com >> "jack99" <jack99@xxxxxx> wrote in message >> news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx Quote: >> > My configuration: >> > Established PC running XP Home SP2 >> > New Laptop with Vista Home Premium >> > Netgear Router with ADSL modem, Wireless access point & Ethernet switch >> > What I can do: >> > Access the internet from both machines >> > Share files both ways using Net Use >> > From Laptop apparently access printer on old PC using Net Use but it >> > does >> > not work >> > What I cannot do >> > Access the other PC (either way) by browsing (but I did on one >> > occasion) >> > Print from the laptop to to a printer attached to the old PC; on the >> > laptop >> > the document status is shown as "Error - Sent to printer" while nothing >> > appears to occur on the the old PC. >> > Any suggestions? >> > >> > >> > >> |
| | #7 (permalink) |
| | Re: Problem networking XP & Vista Thank you for the suggestion. I have checked all the points in your posting and eliminated all except my router which I have no means of bypassing. "Robert L. (MS-MVP)" wrote: Quote: > If you can net view without problem, you may want to try LLTD. This post may > help. > > Troubleshoot computers not ...Feb 18, 2007 ... Vista uses the LLTD protocol > to map computers and devices on a network. The Link Layer Topology Discovery > (LLTD) protocol is disabled on the ... > http://www.chicagotech.net/netforums...opic.php?t=366 > > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > "jack99" <jack99@xxxxxx> wrote in message > news:9D143500-BA73-4AF2-ACED-315BDF52C2C8@xxxxxx Quote: > > Robert, thank you. All the Net View commands worked without error. In > > each > > case they listed the target machine's shares and when it was by name the > > user > > machines name for those resources was also listed. > > > > "Robert L. (MS-MVP)" wrote: > > Quote: > >> If you can do the net use but not browser, it could be the computer > >> browser > >> issue. What's the system error, if you use net view command? For example, > >> net view \\remotepcipaddress first and then net view \\remotepchostname. > >> > >> -- > >> Bob Lin, MS-MVP, MCSE & CNE > >> Networking, Internet, Routing, VPN Troubleshooting on > >> http://www.ChicagoTech.net > >> How to Setup Windows, Network, VPN & Remote Access on > >> http://www.HowToNetworking.com > >> "jack99" <jack99@xxxxxx> wrote in message > >> news:791F3210-7C2D-452D-936A-61EE858A17B8@xxxxxx > >> > My configuration: > >> > Established PC running XP Home SP2 > >> > New Laptop with Vista Home Premium > >> > Netgear Router with ADSL modem, Wireless access point & Ethernet switch > >> > What I can do: > >> > Access the internet from both machines > >> > Share files both ways using Net Use > >> > From Laptop apparently access printer on old PC using Net Use but it > >> > does > >> > not work > >> > What I cannot do > >> > Access the other PC (either way) by browsing (but I did on one > >> > occasion) > >> > Print from the laptop to to a printer attached to the old PC; on the > >> > laptop > >> > the document status is shown as "Error - Sent to printer" while nothing > >> > appears to occur on the the old PC. > >> > Any suggestions? > >> > > >> > > >> > > >> > >> > |
| networking problem Vista & XP | Vista General | |||
| Vista to XP networking problem | Vista networking & sharing | |||
| Another XP & Vista networking problem. | Vista networking & sharing | |||
| Vista Networking problem with VPN | Vista networking & sharing | |||
| Different Vista XP networking problem | Vista networking & sharing | |||
