| Guest | Vista 64 SP1 Wireless Connection Problems I've just purchased a new PC, running Vista Home Premium, with a built- in PCI Wireless adapter, but am unable to connect to the internet. I have emailed my supplier's technical support, but I don't think the problem is straightforward, nor do I know whether it is a hardware of software issue, so I thought I'd try elsewhere in the meantime. The symptons are as follows: * I have an old Netgear DG824M wireless router/ADSL modem. * I have a laptop running Vista Home Premium. This was able to connect to the router and hence to the internet straight away with virtually no configuration - just entered the WEP key and it all worked. This has recently been upgraded to SP1, and still works okay. * I have my old desktop running XP. This has no connection problems. * The new PC has an Asus WL-138GE (or 138G V2 - not sure which) PCI adapter. Initially, it was identified as a Broadcom adapter. * The new PC had problems right from the start connecting to the router and the internet. Most of the time, it appears to be unable to get a DHCP address. The signal strength is always excellent, and it correctly identifies the router as a Netgear DG824M. * When it does manage to connect to the internet, the connection only seems to last a few seconds, or is extremely slow. * I cannot connect to the router at all using the new PC. It comes up with the username and password very quickly, accepts that, but then seems to hang loading the home page. I usually give up after about 5 or 10 minutes. * When connected, I can ping the router and I can also ping websites, even though I don't seem to be able to connect to them using IE. * I have no antivirus running, and the only firewall software is windows firewall I have tried the following: * Checking DHCP client service running * Disable WEP * Disable Windows Firewall * I upgraded the wireless driver by downloading one from Asus. It now recognises the adapter as an Asus 802.11g Network Adapter (driver c: \windows\system32\drivers\BCMWL664.SyS, Broadcom 4.102.15.56), but this doesn't seem to have made any difference * I deleted the adapter and let it recreate itself. It loaded up the same drivers. * I've removed IPv6 * I've set up the PC with a static IP address (192.168.0.51), set up the router as the gateway, and my ISP's DNS servers as the DNS servers. * I added an “ArpRetryCount” DWORD key to the registry as recommended somewhere * I made some further registry changes as recommended by Microsoft KB 928233 * I reset TCP/IP and Winsock using netsh as administrator. * I tried "netsh interface tcp set global rss=disabled autotuninglevel=disabled" None of these changes seem to have made any difference, and I've run out of things to try! Thanks, Oliver |
| Guest | Re: Vista 64 SP1 Wireless Connection Problems that router isn't on the Vista compatibility list http://winqual.microsoft.com/HCL/Pro...=v&cid=712&g=d which means you might have problems with it. try this test https://www.microsoft.com/windows/us...d/default.mspx On Fri, 2 May 2008 03:09:23 -0700 (PDT), olippold@xxxxxx wrote: Quote: >I have an old Netgear DG824M wireless router/ADSL modem. Barb Bowman MS-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| Guest | Re: Vista 64 SP1 Wireless Connection Problems also see http://support.microsoft.com/kb/928233/en-us On Fri, 2 May 2008 03:09:23 -0700 (PDT), olippold@xxxxxx wrote: Quote: >I've just purchased a new PC, running Vista Home Premium, with a built- >in PCI Wireless adapter, but am unable to connect to the internet. I >have emailed my supplier's technical support, but I don't think the >problem is straightforward, nor do I know whether it is a hardware of >software issue, so I thought I'd try elsewhere in the meantime. > >The symptons are as follows: > >* I have an old Netgear DG824M wireless router/ADSL modem. >* I have a laptop running Vista Home Premium. This was able to connect >to the router and hence to the internet straight away with virtually >no configuration - just entered the WEP key and it all worked. This >has recently been upgraded to SP1, and still works okay. >* I have my old desktop running XP. This has no connection problems. >* The new PC has an Asus WL-138GE (or 138G V2 - not sure which) PCI >adapter. Initially, it was identified as a Broadcom adapter. >* The new PC had problems right from the start connecting to the >router and the internet. Most of the time, it appears to be unable to >get a DHCP address. The signal strength is always excellent, and it >correctly identifies the router as a Netgear DG824M. >* When it does manage to connect to the internet, the connection only >seems to last a few seconds, or is extremely slow. >* I cannot connect to the router at all using the new PC. It comes up >with the username and password very quickly, accepts that, but then >seems to hang loading the home page. I usually give up after about 5 >or 10 minutes. >* When connected, I can ping the router and I can also ping websites, >even though I don't seem to be able to connect to them using IE. >* I have no antivirus running, and the only firewall software is >windows firewall > >I have tried the following: >* Checking DHCP client service running >* Disable WEP >* Disable Windows Firewall >* I upgraded the wireless driver by downloading one from Asus. It now >recognises the adapter as an Asus 802.11g Network Adapter (driver c: >\windows\system32\drivers\BCMWL664.SyS, Broadcom 4.102.15.56), but >this doesn't seem to have made any difference >* I deleted the adapter and let it recreate itself. It loaded up the >same drivers. >* I've removed IPv6 >* I've set up the PC with a static IP address (192.168.0.51), set up >the router as the gateway, and my ISP's DNS servers as the DNS >servers. >* I added an “ArpRetryCount” DWORD key to the registry as recommended >somewhere >* I made some further registry changes as recommended by Microsoft KB >928233 >* I reset TCP/IP and Winsock using netsh as administrator. >* I tried "netsh interface tcp set global rss=disabled >autotuninglevel=disabled" > >None of these changes seem to have made any difference, and I've run >out of things to try! > >Thanks, >Oliver Barb Bowman MS-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| Guest | Re: Vista 64 SP1 Wireless Connection Problems Thanks for the speedy response! I appreciate the router is quite old and I'm considering replacing it anyway, but it does work pefectly with the Vista laptop. I've already tried KB928233, but I haven't tried the MS testing tool - I'll try and download that over the weekend, as I'm currently elsewhere. One thing I forgot to mention is that on the laptop (Vista Home Premium SP1 32bit), there is an "ICS" tab on one of the network settings dialogs, although everything is unticked. However, this tab doesn't appear at all on the desktop. Could ICS somehow be intefering? On 2 May, 12:26, Barb Bowman <b...@xxxxxx> wrote: Quote: > also seehttp://support.microsoft.com/kb/928233/en-us > > > > > > On Fri, 2 May 2008 03:09:23 -0700 (PDT), olipp...@xxxxxx wrote: Quote: > >I've just purchased a new PC, running Vista Home Premium, with a built- > >in PCI Wireless adapter, but am unable to connect to the internet. I > >have emailed my supplier's technical support, but I don't think the > >problem is straightforward, *nor do I know whether it is a hardware of > >software issue, so I thought I'd try elsewhere in the meantime. Quote: > >The symptons are as follows: Quote: > >* I have an old Netgear DG824M wireless router/ADSL modem. > >* I have a laptop running Vista Home Premium. This was able to connect > >to the router and hence to the internet straight away with virtually > >no configuration - just entered the WEP key and it all worked. This > >has recently been upgraded to SP1, and still works okay. > >* I have my old desktop running XP. This has no connection problems. > >* The new PC has an Asus WL-138GE (or 138G V2 - not sure which) PCI > >adapter. Initially, it was identified as a Broadcom adapter. > >* The new PC had problems right from the start connecting to the > >router and the internet. Most of the time, it appears to be unable to > >get a DHCP address. The signal strength is always excellent, and it > >correctly identifies the router as a Netgear DG824M. > >* When it does manage to connect to the internet, the connection only > >seems to last a few seconds, or is extremely slow. > >* I cannot connect to the router at all using the new PC. It comes up > >with the username and password very quickly, accepts that, but then > >seems to hang loading the home page. I usually give up after about 5 > >or 10 minutes. > >* When connected, I can ping the router and I can also ping websites, > >even though I don't seem to be able to connect to them using IE. > >* I have no antivirus running, and the only firewall software is > >windows firewall Quote: > >I have tried the following: > >* Checking DHCP client service running > >* Disable WEP > >* Disable Windows Firewall > >* I upgraded the wireless driver by downloading one from Asus. It now > >recognises the adapter as an Asus 802.11g Network Adapter (driver c: > >\windows\system32\drivers\BCMWL664.SyS, Broadcom 4.102.15.56), but > >this doesn't seem to have made any difference > >* I deleted the adapter and let it recreate itself. It loaded up the > >same drivers. > >* I've removed IPv6 > >* I've set up the PC with a static IP address (192.168.0.51), set up > >the router as the gateway, and my ISP's DNS servers as the DNS > >servers. > >* I added an “ArpRetryCount” DWORD key to the registry as recommended > >somewhere > >* I made some further registry changes as recommended by Microsoft KB > >928233 > >* I reset TCP/IP and Winsock using netsh as administrator. > >* I tried "netsh interface tcp set global rss=disabled > >autotuninglevel=disabled" Quote: > >None of these changes seem to have made any difference, and I've run > >out of things to try! Quote: > >Thanks, > >Oliver > -- > > Barb Bowman > MS-MVPhttp://www.microsoft.com/windowsxp/expertzone/meetexperts/bowman.mspxhttp://blogs.digitalmediaphile.com/barb/- Hide quoted text - > > - Show quoted text - |
| Guest | Re: Vista 64 SP1 Wireless Connection Problems please post the text output of ipconfig /all http://digitalmediaphile.wordpress.c...t-text-output/ On Fri, 2 May 2008 05:04:52 -0700 (PDT), olippold@xxxxxx wrote: Quote: >Thanks for the speedy response! > >I appreciate the router is quite old and I'm considering replacing it >anyway, but it does work pefectly with the Vista laptop. > >I've already tried KB928233, but I haven't tried the MS testing tool - >I'll try and download that over the weekend, as I'm currently >elsewhere. > >One thing I forgot to mention is that on the laptop (Vista Home >Premium SP1 32bit), there is an "ICS" tab on one of the network >settings dialogs, although everything is unticked. However, this tab >doesn't appear at all on the desktop. Could ICS somehow be intefering? > >On 2 May, 12:26, Barb Bowman <b...@xxxxxx> wrote: Quote: >> also seehttp://support.microsoft.com/kb/928233/en-us >> >> >> >> >> >> On Fri, 2 May 2008 03:09:23 -0700 (PDT), olipp...@xxxxxx wrote: Quote: >> >I've just purchased a new PC, running Vista Home Premium, with a built- >> >in PCI Wireless adapter, but am unable to connect to the internet. I >> >have emailed my supplier's technical support, but I don't think the >> >problem is straightforward, *nor do I know whether it is a hardware of >> >software issue, so I thought I'd try elsewhere in the meantime. Quote: >> >The symptons are as follows: Quote: >> >* I have an old Netgear DG824M wireless router/ADSL modem. >> >* I have a laptop running Vista Home Premium. This was able to connect >> >to the router and hence to the internet straight away with virtually >> >no configuration - just entered the WEP key and it all worked. This >> >has recently been upgraded to SP1, and still works okay. >> >* I have my old desktop running XP. This has no connection problems. >> >* The new PC has an Asus WL-138GE (or 138G V2 - not sure which) PCI >> >adapter. Initially, it was identified as a Broadcom adapter. >> >* The new PC had problems right from the start connecting to the >> >router and the internet. Most of the time, it appears to be unable to >> >get a DHCP address. The signal strength is always excellent, and it >> >correctly identifies the router as a Netgear DG824M. >> >* When it does manage to connect to the internet, the connection only >> >seems to last a few seconds, or is extremely slow. >> >* I cannot connect to the router at all using the new PC. It comes up >> >with the username and password very quickly, accepts that, but then >> >seems to hang loading the home page. I usually give up after about 5 >> >or 10 minutes. >> >* When connected, I can ping the router and I can also ping websites, >> >even though I don't seem to be able to connect to them using IE. >> >* I have no antivirus running, and the only firewall software is >> >windows firewall Quote: >> >I have tried the following: >> >* Checking DHCP client service running >> >* Disable WEP >> >* Disable Windows Firewall >> >* I upgraded the wireless driver by downloading one from Asus. It now >> >recognises the adapter as an Asus 802.11g Network Adapter (driver c: >> >\windows\system32\drivers\BCMWL664.SyS, Broadcom 4.102.15.56), but >> >this doesn't seem to have made any difference >> >* I deleted the adapter and let it recreate itself. It loaded up the >> >same drivers. >> >* I've removed IPv6 >> >* I've set up the PC with a static IP address (192.168.0.51), set up >> >the router as the gateway, and my ISP's DNS servers as the DNS >> >servers. >> >* I added an “ArpRetryCount” DWORD key to the registry as recommended >> >somewhere >> >* I made some further registry changes as recommended by Microsoft KB >> >928233 >> >* I reset TCP/IP and Winsock using netsh as administrator. >> >* I tried "netsh interface tcp set global rss=disabled >> >autotuninglevel=disabled" Quote: >> >None of these changes seem to have made any difference, and I've run >> >out of things to try! Quote: >> >Thanks, >> >Oliver >> -- >> >> Barb Bowman >> MS-MVPhttp://www.microsoft.com/windowsxp/expertzone/meetexperts/bowman.mspxhttp://blogs.digitalmediaphile.com/barb/- Hide quoted text - >> >> - Show quoted text - Barb Bowman MS-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| Sony VAIO & Vista wireless connection problems | Vista networking & sharing | |||
| New Linksys wireless connection problems with Vista Basic. HELP!! | Vista performance & maintenance | |||
| VISTA Wireless Connection IP Resolve Problems | Vista networking & sharing | |||
| Vista Wireless Connection Problems | Vista networking & sharing | |||
| XP vs Vista wireless connection problems | Vista networking & sharing | |||
