Vista - Wireless router; setting up my wireless network?
Old 05-30-2008   #1 (permalink)
help me
I tried to set up my wireless router network via:
http://www.microsoft.com/athome/more...tup.mspx#step2
The username and password are not working for me. It will not accept them.
Using the wizad; I don't know what they want from me when they ask for a USB
flash drive. Was that supposed to come with my wireless linksys?
Help me! Please!
Old 05-30-2008   #2 (permalink)
Ultimate x64/32bit
Re: Wireless router; setting up my wireless network?
This read may help you too. Please let us have more info on your Linksys router, computers, etc. How are you going about setting up your router? Is it the username and password for the router you are talking about. I'd forget using the wizard personally.
Old 05-30-2008   #3 (permalink)
Jack \(MVP-Networking\).
Hi
It is much better to set the Wireless manually.
May be this can Help, these pages describe the general principle
Wireless Basic Configuration - <http://www.ezlan.net/Wireless_Config.html>
Wireless Security - <http://www.ezlan.net/Wireless_Security.htm>
These two pages have specific instructions for Vista.
<http://www.loughborough.ac.uk/computing/wireless/vista-guided.html>
<http://technet.microsoft.com/en-us/library/bb878035.aspx>
Jack (MVP-Networking).
"help me" <help me@xxxxxx> wrote in message
news:2CC591A1-C6D0-401D-9B72-B4DD56F4045F@xxxxxx
> USB
> Help me! Please!
Old 05-31-2008   #4 (permalink)
Mick Murphy
RE: Wireless router; setting up my wireless network?
You should be setting up your wireless in your router.
It is asking for a USB flash drive as it thinks that you want those settings
on other computers in your Network; and will save them to the USB for you to
taketo the others.
Conect your computer to the router with a Cat5 cable, log into the router,
and set the Network, and WPA2 security Key, up in there. Then turn on the
wireless in there!
Once you have done that, in Vista Start> connect to> put in Network name,
and security key that you made in the router.
Mick Murphy - Qld - Australia
> Help me! Please!
Wireless association failed beacause Windows did not receive any response from the wireless router or access point Vista networking & sharing
help with network (usb wireless adapter or wireless router) Network & Sharing
wireless modem/router setting please view! Network & Sharing
Seeing other computers on a wireless router network. Network & Sharing
Setting up a Security on my Wireless Router Vista security
