| | Problem with Remote Desktop I am having problem with remote desktop on my Vista Ultimate machine. I am using two machines, one XP and one Vista. Both with the latest updates installed. I am using the XP machine to connect to the Vista machine. Here's what happens: 1) Connecting to the Vista Machine using XP:s RD works just fine. 2) Being connected everythings works like a charm 3) I can log out and log in without any problem The XP machine is at my office, the Vista machine at home. When I return home and check the Vista machine I can see the log in screen. So I type in the password and press Enter and Vista says "Welcome" --- and then nothing happens. The same thing happens if I try to reboot the machine from the log in screen. There's nothing else I can do that to shut down the PC. Any clue? |
| | Re: Problem with Remote Desktop You may want to shutdown to restart the computer remotely if you have another networking computer. This how to may help. How to shutdown Windows How to shutdown a Win2000/XP remotely How to Disable Win98 Fast Shutdown to eliminating Shut-Down problems How to remove shutdown menu from Start ... www.howtonetworking.com/Windows/shutdown.htm -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "trazzel" <trazzel@xxxxxx> wrote in message news:2D44247F-F756-42AA-B074-DCF061ED323B@xxxxxx Quote: >I am having problem with remote desktop on my Vista Ultimate machine. > > I am using two machines, one XP and one Vista. Both with the latest > updates > installed. I am using the XP machine to connect to the Vista machine. > Here's > what happens: > > 1) Connecting to the Vista Machine using XP:s RD works just fine. > 2) Being connected everythings works like a charm > 3) I can log out and log in without any problem > > The XP machine is at my office, the Vista machine at home. When I return > home and check the Vista machine I can see the log in screen. So I type in > the password and press Enter and Vista says "Welcome" --- and then nothing > happens. The same thing happens if I try to reboot the machine from the > log > in screen. > There's nothing else I can do that to shut down the PC. > > Any clue? > |
| | Re: Problem with Remote Desktop Thank you very much for your answer! What is the difference between your suggestion and restarting the Vista machine remotely from the XP machine using the "ordinary" reboot button? "Robert L. (MS-MVP)" wrote: Quote: > You may want to shutdown to restart the computer remotely if you have > another networking computer. This how to may help. > How to shutdown Windows > How to shutdown a Win2000/XP remotely How to Disable Win98 Fast > Shutdown to eliminating Shut-Down problems How to remove shutdown menu from > Start ... > www.howtonetworking.com/Windows/shutdown.htm > > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > "trazzel" <trazzel@xxxxxx> wrote in message > news:2D44247F-F756-42AA-B074-DCF061ED323B@xxxxxx Quote: > >I am having problem with remote desktop on my Vista Ultimate machine. > > > > I am using two machines, one XP and one Vista. Both with the latest > > updates > > installed. I am using the XP machine to connect to the Vista machine. > > Here's > > what happens: > > > > 1) Connecting to the Vista Machine using XP:s RD works just fine. > > 2) Being connected everythings works like a charm > > 3) I can log out and log in without any problem > > > > The XP machine is at my office, the Vista machine at home. When I return > > home and check the Vista machine I can see the log in screen. So I type in > > the password and press Enter and Vista says "Welcome" --- and then nothing > > happens. The same thing happens if I try to reboot the machine from the > > log > > in screen. > > There's nothing else I can do that to shut down the PC. > > > > Any clue? > > > |
| Remote Desktop Problem | Vista General | |||
| remote desktop problem.. please help! | Vista General | |||
| Remote Desktop problem with remote printers | Vista networking & sharing | |||
| Remote Desktop problem | Vista networking & sharing | |||
