| | Default gateway problem This might be answered in the 'Vista assigns 0.0.0.0. IP address' thread, but that was a bit technical so I couldn't follow it. I have an intermittant problem with my internet connection at work. Well, not so much intermittant as near constant, I fail to connect 90% of the time, following no pattern I can identify. I've tried rebooting, disabling and enabling the network adapter, and followed all the advice that the troubleshooter offers to no avail. My ip/config all when my connection is functioning is Host Name . . . . . . . . . . . . : Toms_PC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Wireless LAN adapter Wireless Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Atheros AR5005G Wireless Network Adapter Physical Address. . . . . . . . . : 00-19-7D-6A-E2-19 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Work: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : NVIDIA nForce Networking Controller Physical Address. . . . . . . . . : 00-16-D3-51-82-41 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 172.16.240.66(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 172.16.240.254 DNS Servers . . . . . . . . . . . : 192.168.100.254 NetBIOS over Tcpip. . . . . . . . : Enabled When it is not working there is only one small change, Ethernet adapter Work: Default Gateway . . . . . . . . . : 172.16.240.254 becomes Ethernet adapter Work: Default Gateway . . . . . . . . . : 0.0.0.0 172.16.240.254 Thanks in advance for help/advice, Tom |
| | Re: Default gateway problem You may want to use route command to reset the gateway. Or this post may help. Vista Gateway is 0.0.0.0 The solutions of Vista computer default gateway 0.0.0.0 are 1) reset it by using route delete 0.0.0.0 command; 2) Disable IPv6; 3) install new firmware for ... www.chicagotech.net/vista/gateway0.htm -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Tedium" <Tedium@xxxxxx> wrote in message news:9A336C78-9162-41E8-9DF8-1A2556F24C64@xxxxxx Quote: > This might be answered in the 'Vista assigns 0.0.0.0. IP address' thread, > but > that was a bit technical so I couldn't follow it. > > I have an intermittant problem with my internet connection at work. Well, > not so much intermittant as near constant, I fail to connect 90% of the > time, > following no pattern I can identify. I've tried rebooting, disabling and > enabling the network adapter, and followed all the advice that the > troubleshooter offers to no avail. My ip/config all when my connection is > functioning is > > Host Name . . . . . . . . . . . . : Toms_PC > Primary Dns Suffix . . . . . . . : > Node Type . . . . . . . . . . . . : Hybrid > IP Routing Enabled. . . . . . . . : No > WINS Proxy Enabled. . . . . . . . : No > > Wireless LAN adapter Wireless Network Connection: > > Media State . . . . . . . . . . . : Media disconnected > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Atheros AR5005G Wireless Network > Adapter > Physical Address. . . . . . . . . : 00-19-7D-6A-E2-19 > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > > Ethernet adapter Work: > > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : NVIDIA nForce Networking Controller > Physical Address. . . . . . . . . : 00-16-D3-51-82-41 > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > IPv4 Address. . . . . . . . . . . : 172.16.240.66(Preferred) > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > Default Gateway . . . . . . . . . : 172.16.240.254 > DNS Servers . . . . . . . . . . . : 192.168.100.254 > NetBIOS over Tcpip. . . . . . . . : Enabled > > > > > > When it is not working there is only one small change, > > Ethernet adapter Work: > Default Gateway . . . . . . . . . : 172.16.240.254 > > becomes > > Ethernet adapter Work: > Default Gateway . . . . . . . . . : 0.0.0.0 > 172.16.240.254 > > > > > > > Thanks in advance for help/advice, > > Tom |
| Default Gateway | Network & Sharing | |||
| 0.0.0.0 default gateway problem | Vista General | |||
| Vista VPN Default gateway problem | Vista General | |||
| Default Gateway | Vista networking & sharing | |||
| Problem to get default gateway in dhcp | Vista networking & sharing | |||
