| | Create VPN connection results in Dial-up connection Running Windows Vista Ultimate, I create a VPN connection - 'Connect to a workplace'. I choose to 'Use my Internet Connection (VPN), and I enter the Internet address and assign a name to the connection. (I have used this method of creating VPN connection on other Windows Vista machines with no problems.) Once the connection has been created, on going into Manage Network Connections, the connection is visible in the list, but it says 'Unavailable - device missing'. Under Properties - Connect Using, it reads, 'Modem Removed - Unavailable device ()' and the IP address has been entered into the Phone Number box. Does anyone know of a workaround for this problem? |
| | RE: Create VPN connection results in Dial-up connection It seems that this problem could be to do with the fact that within this Windows the connection to the Internet is 'Not conencted', even though it works fine. Can anyone suggest a way of convincing Windows Vista that the Internet connection is actually working? Thanks SimonWillsher "SimonWillsher" wrote: Quote: > Running Windows Vista Ultimate, I create a VPN connection - 'Connect to a > workplace'. I choose to 'Use my Internet Connection (VPN), and I enter the > Internet address and assign a name to the connection. (I have used this > method of creating VPN connection on other Windows Vista machines with no > problems.) > > Once the connection has been created, on going into Manage Network > Connections, the connection is visible in the list, but it says 'Unavailable > - device missing'. Under Properties - Connect Using, it reads, 'Modem Removed > - Unavailable device ()' and the IP address has been entered into the Phone > Number box. > > Does anyone know of a workaround for this problem? |
| dial up connection | Network & Sharing | |||
| dial up connection box appears even though all dial up connections | Live Mail | |||
| Dial up connection connecting instead of LAN connection | Vista mail | |||
| No connection in Dial-up Connection box | Vista mail | |||
| Cannot create dial-up connection | Vista networking & sharing | |||
