| | Re: On startup PC restarts and network cable connected to PC problem Forwarded to Vista Networking newsgroup via crosspost. -- ~PA Bear Stanley wrote: Quote: > Hello everyone! > > PC don't work good with network cable pluged in socket. It restarts at the > moment cable touches socket. Then at start it don't load windows and > monitor > turns off. > > I see after line "NVRAM Ok" screen with dush-pointer blincking and then it > drops few clear lines and again blinck. Is it normal? > > But sometimes it loading system. I disconnected some hardware like > CD/DVD-Rom and Floppy Disk and i got connection to internet normal for one > day. Problem is that I don't know is it right on wrong but windows in My > Computer shows device Floppy Disk as present. Is it emulation from some > virus, rootkit? > > I loaded HDD utility from CD to format drive and made new partitions but > after windows installation the network cable troubles. One thing that > confused me is that programm shows partitions or one partition after > format > that shouldn't present. All the time they are not more than 1mb space or > 3mb, and impossible to delete. Even one time Vista installation menu > showed > it. I think it boot virus. > > How to locate harmfull programm and to remove it? |
| cable disconnected or connected | VB Script | |||
| Connected to Network, but Showing NOT Connected | Vista networking & sharing | |||
| Logon problem when not connected to network | Vista networking & sharing | |||
| Can only get connected Wirelessly, but not with eithernet cable | Vista General | |||
| Connection is offered , dial up and broadband, thru modem, when I´m actually connected by cable... | Vista General | |||
