| Vista Home Premium 32bit | voip problem in vista i have installed vista home premium 32-bit while installing i switched off automatic updates now i am not able to use my voip applications any solutions????? |
| | RE: voip problem in vista Why are the 2 things linked together????? Most of us change auto update to notify. What do you use for VoIP? Is it Vista compatible? -- Mick Murphy - Qld - Australia "girish2611" wrote: Quote: > > i have installed vista home premium 32-bit > while installing i switched off automatic updates > now i am not able to use my voip applications > > any solutions????? > > > -- > girish2611 > |
| Vista Home Premium 32bit | Re: voip problem in vista i use just voip to make phone calls i suspected "turning update off" as main culprit for blocking voip application i don't have any antivirus installed yet |
| windows vista ultimate | Re: voip problem in vista Hi Girish2611, There is no relevence with windows Update and your VOIP system, what you need to check is see whether your windows firewall is allowing your application to function ryt. also you need to state the error that your getting when u try to voip buddy. Hope this helps Cheers !! |
| | Re: voip problem in vista Skype, Freshtel? -- Mick Murphy - Qld - Australia "girish2611" wrote: Quote: > > i use just voip to make phone calls > > i suspected "turning update off" as main culprit for blocking voip > application > > i don't have any antivirus installed yet > > > -- > girish2611 > |
| | #6 (permalink) |
| | Re: voip problem in vista If the phones worked before the do a System Restore from a point when they worked. http://www.howtogeek.com/howto/windo...ystem-restore/ "girish2611" <guest@xxxxxx-email.com> wrote in message news:c26abbab93fa586f8429ccb3a7ab4118@xxxxxx-gateway.com... Quote: > > i have installed vista home premium 32-bit > while installing i switched off automatic updates > now i am not able to use my voip applications > > any solutions????? > > > -- > girish2611 |
| voip problem | Software | |||
| VoIP sound problem | Vista performance & maintenance | |||
| VoIP Connection problem | Vista General | |||
| Problem with vista and voip phone | General Discussion | |||
| VoIP Problem | Vista performance & maintenance | |||
