| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Newbie | Remote Desktop - Login Problems Hi there I have Remote desktop set up on Vista Ultimate 64. Port forwarding is set up correctly. When I connect (from an XP machine outside the LAN) I get the infamous 'incorrect user name or password' error even though the password is correct. I have tried the DOMAIN\Username fix without success. However, I can connect without issue to another admin user I set up to test things. So my initial admin account which everything is set up with fails, but a secondary admin user account works without issue. But of course I have no interest in connecting to the PC under this secondary account. I've got to assume that there is some security setting somewhere in Vista that is preventing outside access to my main account, but for the life of me I can't find it!! Any ideas? Thanks in advance. Karl |
| DNPNWO ![]() ![]() ![]() | Re: Remote Desktop - Login Problems Check the network setting on the admin acct. See if the settings match the secondary acct. -Network and sharing center -Remote tab under system properties |
| Newbie | Re: Remote Desktop - Login Problems Thank you rive0108 I had another look around and I don't know if this is general knowledge and I'm an idiot, but it doesn't make much sense. While my main user account had the name xxxx (which had been changed from what it was set up with when I received the PC), as soon as I tried the original account name, and current password it logged on straight away, showing me logged in as the new name. Even though the original name I can't see anywhere anymore... This must be an issue that other people have come across -and certainly isn't something you'd think of as you're tearing your hair out trying to work out why your connection isn't working! Anyway, all's good now that I log on with the original account name. I don't care if it's odd -as long as it works! Thanks for your help Karl |
| | #4 (permalink) | ||||||||||||
| Guest | RE: Remote Desktop - Login Problems -- R. T. Hohan "Krul74" wrote:
My System Specs![]() | |||||||||||||
| Display Modes | |
| Can't login to remote comp. using Remote Desktop Connection on Vis | Luigi_1996 | Vista account administration | 0 | 12-13-2007 10:14 PM |
| login control off - password required after Remote Desktop session | speedbump49 | Vista security | 1 | 08-09-2007 11:56 PM |
| I don't want to login again after using Remote desktop? | speedbump49 | Vista account administration | 3 | 08-02-2007 06:40 PM |
| I am not able to login to my Windows Visa machine using Remote Desktop it shows the network connections as local how to change this settings | jack | Vista performance & maintenance | 1 | 07-30-2007 09:44 PM |
| Remote Desktop Auto Login To Windows Server 2003 R2 | Kenneth H. Brannigan | Vista General | 4 | 11-24-2006 06:56 PM |
