| | network bridge problems! Ok i am trying to bridge my wireless connection and my local connection so i can play on xbox live. Once i bridge the connections windows doesnt recognize my wireless adaptor which is a NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter with the latest updates. anyone know if there is a way i can fix this? thanks |
| | Re: network bridge problems! Hi You have to describe the whole setting including the Internet connection. Bridging is a very specific type of setting and from your description it is it is impossible to know if you are doing it correctly. Jack (MVP-Networking). "windows user92" <windowsuser92@xxxxxx> wrote in message news:E9FD2DE6-B0F7-4AB7-8230-AE23A6560FD2@xxxxxx Quote: > Ok i am trying to bridge my wireless connection and my local connection so > i > can play on xbox live. Once i bridge the connections windows doesnt > recognize > my wireless adaptor which is a NETGEAR WG111v2 54Mbps Wireless USB 2.0 > Adapter with the latest updates. anyone know if there is a way i can fix > this? thanks |
| | Re: network bridge problems! Ok the problem was that the wireless adapter came with propriatary software that ran it conneting to the router once i turned that off and let windows connect it to the router it started working. However once ever 30 mins it loses the internet signal i guess causing me to disconnect for like 30 seconds then it reconnects. This isnt a major a problem but it can get annoying. "Jack (MVP-Networking)." wrote: Quote: > Hi > You have to describe the whole setting including the Internet connection. > Bridging is a very specific type of setting and from your description it is > it is impossible to know if you are doing it correctly. > Jack (MVP-Networking). > > "windows user92" <windowsuser92@xxxxxx> wrote in message > news:E9FD2DE6-B0F7-4AB7-8230-AE23A6560FD2@xxxxxx Quote: > > Ok i am trying to bridge my wireless connection and my local connection so > > i > > can play on xbox live. Once i bridge the connections windows doesnt > > recognize > > my wireless adaptor which is a NETGEAR WG111v2 54Mbps Wireless USB 2.0 > > Adapter with the latest updates. anyone know if there is a way i can fix > > this? thanks > |
| slow network bridge | Network & Sharing | |||
| network bridge problems | Network & Sharing | |||
| Bridge network interfaces? | Vista networking & sharing | |||
| network bridge; mac address | Network & Sharing | |||
| Network Bridge | Vista networking & sharing | |||
