Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista networking & sharing
Vista - Problem remoting to vista enterprise system
07-09-2008   #1 (permalink)
Lem
I get an authentication error when I try to remote to my windows vista system
using remote desktop. Every other system on the network responds just fine
but connecting to the vista enterprise system is where the connection gives
me an authentication error when trying to connect.
Does anyone have any suggestions? I did change the time to match up with the
server, also tried lowering the required securtiy level for remote desktop
for vista, also the exact error is: an authentication error has occurred
(code 0x80090330)
It has worked before but once i had to reinstall vista then i was unable to
connect. I also tried with different users and also made sure the passwords
were the orrect ones, still no luck.
07-10-2008   #2 (permalink)
Morgan che
RE: Problem remoting to vista enterprise system
In Remote Desktop Connection 6.0, server authentication verifies that you
are connecting to the correct remote computer or server, which may lead to
some incompatibility issue.
So, could you confirm if you use Remote Desktop Connection 6.0 client to
connect Vista?
Before Vista, Remote Desktop Connection 6.0 has been included in the
following OS:
Microsoft Windows Server 2003 with Service Pack 1 (SP1)
Microsoft Windows Server 2003 with Service Pack 2 (SP2)
Microsoft Windows XP with Service Pack 2 (SP2)
If so, please edit Default.rdp file as following steps to turn off the new
features in Remote Desktop Connection 6.0 to revert to the features in
Remote Desktop Connection 5.x.
To do this, follow these steps:
1. Click Start, click Run, type mstsc.exe, and then click OK.
2. Click Options, and then click the General tab.
3. Click Save As, and then type a file name in the File name box.
4. Select the location where you want to save the remote desktop file,
click Save, and then click Cancel.
Note The saved file has the .rdp file name extension.
5. Click Start, click Run, type notepad, and then click OK.
6. On the File menu, click Open.
7. In the Files of type list, click All Files.
8. In the Look in list, locate and then click the file that you saved in
step 4. Then, click Open.
9. Locate the line that resembles the following:
authentication level:i:n
Note The n placeholder represents the current authentication level.
10. Change the authentication level to 0 so that the line becomes the
following:
authentication level:i:0
Note When you set the authentication level to 0, RDP 6.0 does not check for
server authentication.
11. Add the following line to the end of the file:
enablecredsspsupport:i:0
Note When this line is present, you do not have to provide credentials
before you establish a remote desktop connection.
12. On the File menu, click Save.
More information, please see:
Remote Desktop Connection 6.0 prompts you for credentials before you
http://support.microsoft.com/kb/941641
In addition, please also install hotfixs for Remote Desktop Connection 6.0
client, which can be achieved from:
http://technet2.microsoft.com/window...-7038-4e82-a32
c-4bc10ffe56ab1033.mspx?mfr=true
Please also test if you use RDC 5.0 to connect Vista, does this issue still
persist?
If you need further assistance, please post back with the latest
information.
Hope this helps.
Best wishes
Morgan Che
Sincerely
Morgan Che
Microsoft Online Support
Microsoft Global Technical Support Center
Get Secure! - www.microsoft.com/security
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
--->Thread-Topic: Problem remoting to vista enterprise system
--->thread-index: AcjiElodSI/IN9zOQ4a/aWZSsRYNfg==
--->X-WBNR-Posting-Host: 207.46.19.168
--->From: =?Utf-8?B?TGVtQGNvbW11bml0eS5ub3NwYW0=?= <Lem@xxxxxx>
--->Subject: Problem remoting to vista enterprise system
--->Date: Wed, 9 Jul 2008 15:23:02 -0700
--->Lines: 14
--->Message-ID: <F806EB90-E139-482D-99D0-C055300B0439@xxxxxx>
--->MIME-Version: 1.0
--->Content-Type: text/plain;
---> charset="Utf-8"
--->Content-Transfer-Encoding: 7bit
--->X-Newsreader: Microsoft CDO for Windows 2000
--->Content-Class: urn:content-classes:message
--->Importance: normal
--->Priority: normal
--->X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2992
--->Newsgroups: microsoft.public.windows.vista.networking_sharing
--->Path: TK2MSFTNGHUB02.phx.gbl
--->Xref: TK2MSFTNGHUB02.phx.gbl
microsoft.public.windows.vista.networking_sharing:29015
--->NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149
--->X-Tomcat-NG: microsoft.public.windows.vista.networking_sharing
--->I get an authentication error when I try to remote to my windows vista
system
--->using remote desktop. Every other system on the network responds just
fine
--->but connecting to the vista enterprise system is where the connection
gives
--->me an authentication error when trying to connect.
--->Does anyone have any suggestions? I did change the time to match up
with the
--->server, also tried lowering the required securtiy level for remote
desktop
--->for vista, also the exact error is: an authentication error has
occurred
--->(code 0x80090330)
--->It has worked before but once i had to reinstall vista then i was
unable to
--->connect. I also tried with different users and also made sure the
passwords
--->were the orrect ones, still no luck.
07-11-2008   #3 (permalink)
Morgan che
Thanks for letting us know my suggestion works. I you encounter any other
problems, please feel free to post here.
Have a nice weekend!
Sincerely
Morgan Che
--->thread-index: AcjinuVFonFBmHrITrOtwu5kv6I4jg==
--->X-WBNR-Posting-Host: 207.46.192.207
--->References: <F806EB90-E139-482D-99D0-C055300B0439@xxxxxx>
<CXYmnfn4IHA.1620@xxxxxx>
--->Subject: RE: Problem remoting to vista enterprise system
--->Date: Thu, 10 Jul 2008 08:09:05 -0700
--->Lines: 143
--->Message-ID: <0D14596C-94BC-483E-946B-7104E4B9B7B8@xxxxxx>
microsoft.public.windows.vista.networking_sharing:29041
--->Thanks Morgan! that worked like a charm. I never had to do this before
so its
--->still puzzling but it works, so im grateful.
--->thanks again.
--->"Morgan che(MSFT)" wrote:
--->> Hi,
--->> In Remote Desktop Connection 6.0, server authentication verifies that
you
--->> are connecting to the correct remote computer or server, which may
lead to
--->> some incompatibility issue.
--->> So, could you confirm if you use Remote Desktop Connection 6.0 client
to
--->> connect Vista?
--->> Before Vista, Remote Desktop Connection 6.0 has been included in the
--->> following OS:
--->> Microsoft Windows Server 2003 with Service Pack 1 (SP1)
--->> Microsoft Windows Server 2003 with Service Pack 2 (SP2)
--->> Microsoft Windows XP with Service Pack 2 (SP2)
--->> If so, please edit Default.rdp file as following steps to turn off
the new
--->> features in Remote Desktop Connection 6.0 to revert to the features
in
--->> Remote Desktop Connection 5.x.
--->> To do this, follow these steps:
--->> 1. Click Start, click Run, type mstsc.exe, and then click OK.
--->> 2. Click Options, and then click the General tab.
--->> 3. Click Save As, and then type a file name in the File name box.
--->> 4. Select the location where you want to save the remote desktop
file,
--->> click Save, and then click Cancel.
--->> Note The saved file has the .rdp file name extension.
--->> 5. Click Start, click Run, type notepad, and then click OK.
--->> 6. On the File menu, click Open.
--->> 7. In the Files of type list, click All Files.
--->> 8. In the Look in list, locate and then click the file that you saved
in
--->> step 4. Then, click Open.
--->> 9. Locate the line that resembles the following:
--->> authentication level:i:n
--->> Note The n placeholder represents the current authentication level.
--->> 10. Change the authentication level to 0 so that the line becomes the
--->> following:
--->> authentication level:i:0
--->> Note When you set the authentication level to 0, RDP 6.0 does not
check for
--->> server authentication.
--->> 11. Add the following line to the end of the file:
--->> enablecredsspsupport:i:0
--->> Note When this line is present, you do not have to provide
credentials
--->> before you establish a remote desktop connection.
--->> 12. On the File menu, click Save.
--->> More information, please see:
--->> Remote Desktop Connection 6.0 prompts you for credentials before you
--->> establish a remote desktop connection
--->> http://support.microsoft.com/kb/941641
--->> In addition, please also install hotfixs for Remote Desktop
Connection 6.0
--->> client, which can be achieved from:
--->> c-4bc10ffe56ab1033.mspx?mfr=true
--->> Please also test if you use RDC 5.0 to connect Vista, does this issue
still
--->> persist?
--->> If you need further assistance, please post back with the latest
--->> information.
--->> Hope this helps.
--->> Best wishes
--->> Morgan Che
--->> Sincerely
--->> Morgan Che
--->> Microsoft Online Support
--->> Microsoft Global Technical Support Center
--->> Get Secure! - www.microsoft.com/security
--->> When responding to posts, please "Reply to Group" via your newsreader
so
--->> that others may learn and benefit from your issue.
--->> This posting is provided "AS IS" with no warranties, and confers no
rights.
--->> --->Thread-Topic: Problem remoting to vista enterprise system
--->> --->thread-index: AcjiElodSI/IN9zOQ4a/aWZSsRYNfg==
--->> --->X-WBNR-Posting-Host: 207.46.19.168
--->> --->From: =?Utf-8?B?TGVtQGNvbW11bml0eS5ub3NwYW0=?=
<Lem@xxxxxx>
--->> --->Subject: Problem remoting to vista enterprise system
--->> --->Date: Wed, 9 Jul 2008 15:23:02 -0700
--->> --->Lines: 14
--->> --->Message-ID: <F806EB90-E139-482D-99D0-C055300B0439@xxxxxx>
--->> --->MIME-Version: 1.0
--->> --->Content-Type: text/plain;
--->> ---> charset="Utf-8"
--->> --->Content-Transfer-Encoding: 7bit
--->> --->X-Newsreader: Microsoft CDO for Windows 2000
--->> --->Content-Class: urn:content-classes:message
--->> --->Importance: normal
--->> --->Priority: normal
--->> --->X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2992
--->> --->Newsgroups: microsoft.public.windows.vista.networking_sharing
--->> --->Path: TK2MSFTNGHUB02.phx.gbl
--->> --->Xref: TK2MSFTNGHUB02.phx.gbl
--->> microsoft.public.windows.vista.networking_sharing:29015
--->> --->NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149
--->> --->X-Tomcat-NG: microsoft.public.windows.vista.networking_sharing
--->> --->I get an authentication error when I try to remote to my windows
vista
--->> system
--->> --->using remote desktop. Every other system on the network responds
just
--->> fine
--->> --->but connecting to the vista enterprise system is where the
connection
--->> gives
--->> --->me an authentication error when trying to connect.
--->> --->Does anyone have any suggestions? I did change the time to match
up
--->> with the
--->> --->server, also tried lowering the required securtiy level for
remote
--->> desktop
--->> --->for vista, also the exact error is: an authentication error has
--->> occurred
--->> --->(code 0x80090330)
--->> --->It has worked before but once i had to reinstall vista then i was
--->> unable to
--->> --->connect. I also tried with different users and also made sure the
--->> passwords
--->> --->were the orrect ones, still no luck.
 Problem remoting to vista enterprise system problems?
Similar topics to: Problem remoting to vista enterprise system
Remoting in to Office System Network & Sharing
crcdisk.sys and Vista Enterprise total system meltdown dell xps 41 Vista hardware & devices
Migrate from .NET Remoting to WCF (CAO & Remoting.Marshal) Indigo
crcdisk.sys and Vista Enterprise total system meltdown dell xps 41 Vista General
Napster Problem on Vista Enterprise Vista music pictures video
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
