| VISTA ULTIMATE 32BIT | Shared printer connection problem I'm having a problem printing from my vista laptop. The printer is connected to my desktop which is a Vista Ultimate SP1 32bit and the Laptop is Vista Home Premium . I keep getting this error message when I'm trying to connect to the printer. I could ping both computers fine without a problem I get all of the packets nothing fails. [Window Title] Connect to Printer [Main Instruction] Windows cannot connect to the printer. Operation could not be completed (error 0x0000000d). [OK] |
| | RE: Shared printer connection problem You have to have the Printer's Driver installed in the laptop as well as the Desktop. And, in the Vista Laptop>Start>Network>Network and Sharing>Add Network Device>Browse to the ultimate's printer>Follow instructions to add it Have a read of the info below as well on how to Network. http://technet.microsoft.com/en-us/l.../bb727037.aspx Have a read of the above link re Vista File and Printer Sharing. Permissions/Share info is there as well. If using Norton, McAfee, Trend Micro I.S., make sure file and printer sharing is enabled in THEIR firewall (or LAN allowed, depending on how their Exceptions are worded in their Firewall) 1st thing to do is make sure that the Workgroup Name of ALL the computers is the SAME. In Vista Network and Sharing: Network Discovery: ON (So it can see the other computers) Network set to Private (Public is for hotspots, airports, etc) File Sharing: ON Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared Docs) Password Protected: OFF (unless you want to set up identical usernames and passwords (passwords can be different) on ALL computers in your Network) If you have it ON, you will be asked for a username and password when you try to access a Vista computer from an XP computer, or a Vista computer. - Mick Murphy - Qld - Australia "VistaKing" wrote: Quote: > > ::I'm having a problem printing from my vista laptop. The printer is > connected to my desktop which is a Vista Ultimate SP1 32bit and the > Laptop is Vista Home Premium . I keep getting this error message when > I'm trying to connect to the printer. I could ping both computers fine > without a problem I get all of the packets nothing fails. :: > > > ::[Window Title]:: > ::Connect to Printer:: > ::[Main Instruction]:: > ::Windows cannot connect to the printer. Operation could not be > completed (error 0x0000000d).:: > ::[OK]:: > > > -- > VistaKing > |
| VISTA ULTIMATE 32BIT | Re: Shared printer connection problem [quote=Mick Murphy;781227]You have to have the Printer's Driver installed in the laptop as well as the Desktop. And, in the Vista Laptop>Start>Network>Network and Sharing>Add Network Device>Browse to the ultimate's printer>Follow instructions to add it Have a read of the info below as well on how to Network. File and Printer Sharing in Windows Vista Have a read of the above link re Vista File and Printer Sharing. Permissions/Share info is there as well. If using Norton, McAfee, Trend Micro I.S., make sure file and printer sharing is enabled in THEIR firewall (or LAN allowed, depending on how their Exceptions are worded in their Firewall) 1st thing to do is make sure that the Workgroup Name of ALL the computers is the SAME. In Vista Network and Sharing: Network Discovery: ON (So it can see the other computers) Network set to Private (Public is for hotspots, airports, etc) File Sharing: ON Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared Docs) Password Protected: OFF (unless you want to set up identical usernames and passwords (passwords can be different) on ALL computers in your Network) If you have it ON, you will be asked for a username and password when you try to access a Vista computer from an XP computer, or a Vista computer. - Mick Murphy - Qld - Australia Mick Murphy, Everything is enabled. print sharing is enabled on the desktop where the printer is connected via USB . Both of the computers have the vista driver installed . The firewall from Norton Internet Security on the laptop is configured to allow communication from both computers. I still get that error message. |
| | RE: Shared printer connection problem What do you do if an (HP) print driver will not install the print driver for Vista on a XP Home version? This is the conundrum I have been in. I was able to install the driver on my Vista laptop but not the driver needed to share the printer on my XP Home desktop. "Mick Murphy" wrote: Quote: > You have to have the Printer's Driver installed in the laptop as well as the > Desktop. > > And, in the Vista Laptop>Start>Network>Network and Sharing>Add Network > Device>Browse to the ultimate's printer>Follow instructions to add it > > Have a read of the info below as well on how to Network. > > http://technet.microsoft.com/en-us/l.../bb727037.aspx > > Have a read of the above link re Vista File and Printer Sharing. > > Permissions/Share info is there as well. > > If using Norton, McAfee, Trend Micro I.S., make sure file and printer > sharing is enabled in THEIR firewall (or LAN allowed, depending on how their > Exceptions are worded in their Firewall) > > 1st thing to do is make sure that the Workgroup Name of ALL the computers is > the SAME. > > In Vista Network and Sharing: > > Network Discovery: ON (So it can see the other computers) > > Network set to Private (Public is for hotspots, airports, etc) > > File Sharing: ON > > Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared > Docs) > > Password Protected: OFF (unless you want to set up identical usernames and > passwords (passwords can be different) on ALL computers in your Network) If > you have it ON, you will be asked for a username and password when you try to > access a Vista computer from an XP computer, or a Vista computer. > > - > Mick Murphy - Qld - Australia > > > "VistaKing" wrote: > Quote: > > > > ::I'm having a problem printing from my vista laptop. The printer is > > connected to my desktop which is a Vista Ultimate SP1 32bit and the > > Laptop is Vista Home Premium . I keep getting this error message when > > I'm trying to connect to the printer. I could ping both computers fine > > without a problem I get all of the packets nothing fails. :: > > > > > > ::[Window Title]:: > > ::Connect to Printer:: > > ::[Main Instruction]:: > > ::Windows cannot connect to the printer. Operation could not be > > completed (error 0x0000000d).:: > > ::[OK]:: > > > > > > -- > > VistaKing > > |
| | RE: Shared printer connection problem surfmavk wrote: Quote: > What do you do if an (HP) print driver will not install the print driver > for > Vista on a XP Home version? This is the conundrum I have been in. I was > able to install the driver on my Vista laptop but not the driver needed to > share the printer on my XP Home desktop. Go to HP's site and get XP drivers and install them on your XP machine. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| | #6 (permalink) |
| | RE: Shared printer connection problem That is exactly what I have done. I went to the HP site and tried to download the HP print driver for my printer that would be compatible for the Vista laptop to share this printer, and it could not install it. I downloaded the printer driver onto the laptop just fine so I could use the printer via hardwire but have been unsuccessful sharing this printer wirelessly. It is the Vista Ultimate OS. "Malke" wrote: Quote: > surfmavk wrote: > Quote: > > What do you do if an (HP) print driver will not install the print driver > > for > > Vista on a XP Home version? This is the conundrum I have been in. I was > > able to install the driver on my Vista laptop but not the driver needed to > > share the printer on my XP Home desktop. > You would never want to install Vista drivers for anything on an XP machine! > Go to HP's site and get XP drivers and install them on your XP machine. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > FAQ - http://www.elephantboycomputers.com/#FAQ > > |
| | #7 (permalink) |
| | RE: Shared printer connection problem I am wondering if you all could have resolved your printing problems. I am running some tests and ran into some problems. I have vista home, with an HP F4100 connected locally to it, via a usb port. I shared the printer, but my XP (professional) desk top cannot see my shared printer, any body knows what I should do? I could not even see the shared printer, so there is no issue with device drivers yet. Some body mentioned XP home, I do not think XP home can see a network printer, but I may be wrong, let me know if it could. Thanks. "surfmavk" wrote: Quote: > That is exactly what I have done. I went to the HP site and tried to > download the HP print driver for my printer that would be compatible for the > Vista laptop to share this printer, and it could not install it. I > downloaded the printer driver onto the laptop just fine so I could use the > printer via hardwire but have been unsuccessful sharing this printer > wirelessly. It is the Vista Ultimate OS. > > "Malke" wrote: > Quote: > > surfmavk wrote: > > Quote: > > > What do you do if an (HP) print driver will not install the print driver > > > for > > > Vista on a XP Home version? This is the conundrum I have been in. I was > > > able to install the driver on my Vista laptop but not the driver needed to > > > share the printer on my XP Home desktop. > > You would never want to install Vista drivers for anything on an XP machine! > > Go to HP's site and get XP drivers and install them on your XP machine. > > > > Malke > > -- > > MS-MVP > > Elephant Boy Computers - Don't Panic! > > FAQ - http://www.elephantboycomputers.com/#FAQ > > > > |
| | #8 (permalink) |
| | RE: Shared printer connection problem surfmavk wrote: Quote: > That is exactly what I have done. I went to the HP site and tried to > download the HP print driver for my printer that would be compatible for > the > Vista laptop to share this printer, and it could not install it. I > downloaded the printer driver onto the laptop just fine so I could use the > printer via hardwire but have been unsuccessful sharing this printer > wirelessly. It is the Vista Ultimate OS. onto the XP machine. Unless you are the Original Poster - "VistaKing" - you've injected your post into his thread. Make a new post and include all the details about your computers and your problem. Refer to at least some of these sites for what to include in the post: How to Post: http://www.elephantboycomputers.com/page2.html#Usenet http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| | #9 (permalink) |
| | RE: Shared printer connection problem The Army Girl wrote: Quote: > I am wondering if you all could have resolved your printing problems. > I am running some tests and ran into some problems. > I have vista home, with an HP F4100 connected locally to it, via a usb > port. I shared the printer, but my XP (professional) desk top cannot see > my shared printer, any body knows what I should do? > > I could not even see the shared printer, so there is no issue with device > drivers yet. > Some body mentioned XP home, I do not think XP home can see a network > printer, but I may be wrong, let me know if it could. Original Poster - "VistaKing" - you've injected your post into his thread. Make a new post and include all the details about your computers and your problem. Refer to at least some of these sites for what to include in the post: How to Post: http://www.elephantboycomputers.com/page2.html#Usenet http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| No Shared Printer Connection after SP2 | Windows Updates | |||
| Shared Printer Problem | Vista mail | |||
| Shared Printer Problem | Vista print fax & scan | |||
| Bluescreen: network file copy and shared printer connection | Vista General | |||
| Connection problems for shared printer | Vista networking & sharing | |||
