Vista - Wireless connection cut - Wndows Vista Home Premium SP1
Old 07-23-2008   #1 (permalink)
gmcleung
I don't know why my notebook PC's wi-fi connection is cut sporadically. The
Windows diagnosis messages shown are mostly a wireless network is not found.
My Window version is Vista Home Premium SP1. The wireless chip in my
notebook is Intel 4965 AGN and the router used is TP-Link TL-941ND supporting
802.11 a/g/n. The security type chosen is WPA2-PSK.
Appreciate if any friends could advise me how to make the wireless
connection more stable. The connection is flawless when I use the ethernet
wire to connect the router.
Grateful to have your advice
Old 07-23-2008   #2 (permalink)
Jack \(MVP-Networking\).
Re: Wireless connection cut - Wndows Vista Home Premium SP1
Hi
Assuming that you are within the functional range of your Wireless hardware,
(Functional range is usually much shorter than what the marketing claims).
Make sure that your Wireless Router's SSID Broadcast is On.
Try to disable the Power saving feature of the Wireless card.
Try to set the Wireless channel to 11 or 1.
Jack (MS, MVP-Networking)
"gmcleung" <gmcleung@xxxxxx> wrote in message
news:162F334F-5EC7-4F85-87D2-12B91C25CD23@xxxxxx
>The
> found.
> supporting
> ethernet
Vista & XP Home Wireless Network Connection Please Help! Vista networking & sharing
Slow wireless connection on Desktop with Vista Home Premium Vista General
Having problem with wireless connection and Windows Vista Home Premium Vista networking & sharing
Windows Vista Home Premium - Wireless connection problem Vista networking & sharing
Home LAN adding a PC using vista on a wireless connection Vista networking & sharing
