Vista - Vista wireless conection problem
Old 09-04-2008   #1 (permalink)
sharic2
hi
I have Toshiba P200 PC,32-bit operating sistem whit Whindows Vista
Home Premium,and have problem whit whireless conection.
My ruter is Linksis WRT54GC ver.2.0 and I havent any problems before
2-3 days ago,and now my internet is verry low.In "Wireless Network
Connection Status"I see that IPv6 Connectivity is limited,some times
this IPv6 Connectivity become to lpcal and my trafic become to normal
speed.
How can I repair my conection
sharic2
sharic2's Profile: http://forums.techarena.in/members/sharic2.htm
View this thread: http://forums.techarena.in/windows-v...rk/1032252.htm
Old 09-04-2008   #2 (permalink)
Malke
Re: Vista wireless conection problem
sharic2 wrote:
Quote:
> hi
> speed.
The First Question Of Troubleshooting: what changed between the time things
worked and the time they didn't?
Turn off the IPv6 connection and use only IPv4.
MVP Barb Bowman - http://digitalmediaphile.wordpress.com/ - home
http://digitalmediaphile.wordpress.c...windows-vista/
How to remove IPv6 and Tunnel completely on Vista -
www.howtonetworking.com/vista/vistaipconfig.htm
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
Old 09-04-2008   #3 (permalink)
John Thompson
> speed.
Are you actually on an IPv6 network?
John (john@xxxxxx)
** Posted from http://www.teranews.com **
Old 09-04-2008   #4 (permalink)
sharic2
No i think...
when I open Wireless Network conection status i see:
connection
IPv4 Connectivity: Intenet
IPv6 Connectivity: Limited
Media state: Enable
SSID: Vasilev
etc:etc
when Ipv6 connectivityis Local my internet speed is ok,but I cant
change it from lmited to local.
already disable autotuning
thanks for help
sharic2
Old 09-04-2008   #5 (permalink)
Malke
sharic2 wrote:
Quote:
> No i think...
> connection
> Media state: Enable
> SSID: Vasilev
> etc:etc
> thanks for help
That's why I told you to disable IPv6.
Malke
MS-MVP
Old 09-05-2008   #6 (permalink)
sharic2
i already disable IPv6 but the problem still exist
sharic2
Old 09-05-2008   #7 (permalink)
Malke
sharic2 wrote:
If you had really disabled IPv6, you wouldn't be getting the "IPv6 limited
connectivity" error.
Since you aren't providing any other information I can't help you further.
Obviously something has changed in the past "2-3 days". What? Only you can
find out.
Other extremely common reasons for Internet connectivity problems are
malware infection, ISP issues, and router failure.
Scan for malware:
http://www.elephantboycomputers.com/...moving_Malware
Connect the computer wired directly to the router. Still having problems?
Then it's probably the router. Prove it by connecting wired directly to the
modem. Still having problems? Call your ISP.
If you updated your wireless adapter drivers from Windows Update, roll back
to the correct drivers.
Roll Back Troublesome Device Drivers in Windows Vista from the How-To Geek -
http://tinyurl.com/346lox
So there are a few suggestions. If you need more help, these links will show
you what details to include so people who want to help you have something
with which to work:
http://www.elephantboycomputers.com/page2.html#Usenet
http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question
Malke
MS-MVP
lost wireless conection Network & Sharing
help ( Vista/Xp Ethernet conection problem):S Network & Sharing
Sharing PPPoE internet conection via wireless lan Vista networking & sharing
Wireless Conection Vista General
M2N32 SLI DELUXE WIFI LIMITED CONECTION PROBLEM Vista General
