Vista - Wireless and Wired Networking help
Old 09-18-2006   #1 (permalink)
Jeff Banks
I have one PC ( desktop) that is running Windows Vista RC1. It is connected
to the internet via a Belkin wireless-G router via an ethernet cable.
I have a laptop PC that is running Windows XP SP2. It connects to the router
wirelessly.
My question is how do I go about setting up a network so that I can share
files between these two PC's ? It seems very easy to do with Windows XP, but
with Windows Vista, it doesn't seem as obvious.
Thanks in advance.
Jeff
Old 09-18-2006   #2 (permalink)
=?Utf-8?B?Sm9zaCBTaG9ydGVy?=
RE: Wireless and Wired Networking help
I have the exact same question... i have no idea how to even set up a network
... but have one xp comp and one vista comp .. they connect to the net through
a router .. and i would like to know how to share files between them
Old 09-18-2006   #3 (permalink)
Steve Urbach
Re: Wireless and Wired Networking help
On Mon, 18 Sep 2006 13:56:24 -0400, "Jeff Banks" <jbanks@wowway.com>
>wirelessly.
>Thanks in advance.
>Jeff
I did mine by hand (Hate %*&^ wizards)
Question 1) Can Vista get to the Internet (IE loads MSN...)?
Question 2) Do you know each devices IP address? (typ 192.168.x.y
where x is the same for all units and y is unique) Hint if you have
the 2 computer icon in the tool tray on XP, Right click and select
Status the select the "Support" tab.
On Vista, Start Menu, Right click on Network, Properties. Connection:
Click "View Status", Click Details (you probably want IPv4 values)
Note: Both values need to follow the rule in Q2 above.
Other things to check, is both computers belong to the same workgroup.
I believe XPhome defaults to MSHOME and Vista Ultimate defaults to
WORKGROUP. pick your own name and make them both the SAME. A reboot
will be required.
You should be able to see each other now. Set your shares as desired.
Can't use both wired and wireless networking at same time Vista General
switching from wireless to wired networking does not work Vista networking & sharing
Wireless/Wired networking? Vista networking & sharing
Networking wireless and wired without router Vista networking & sharing
Xbox 360 and Vista MC networking wired/wireless Vista networking & sharing
