Vista - Losing wireless connection to specific wireless network
Old 09-28-2008   #1 (permalink)
AnnieB
Hi All,
I have a Vaio VGN-SZ430N notebook with Vista business pre-installed. I
use the notebook at work and home. At work I mainly utilize the wired
LAN but occasionally make use of one of the wireless networks and I have
no problems. Home is another story. I cannot stay connected to our
home network for any extended periods of time, like an hour max and then
I get kicked off. Sometimes it is worse, and I lose the connection
every 5-10 minutes. None of my roommates have this problem.
Additionally, from home I can connect to one of my neighbors' unsecured
networks and stay on all day with no problems. Given all of this I'm
hopeful resolving this issue is just a matter of changing a setting or
something. But I've no idea what to do. The network connection icon in
the taskbar shows that I am still connected even after I get kicked off.
I go through the diagnose and repair steps and this is what happens:
1. Diagnose message - "Cannot communicate with primary DNS server"
2. Repair step one - Automatically renew IP - I try this and it fails
every time
3. Repair step two - Reset Network Adaptor - This works and I can
reconnect (until I unavoidably lose the connection again)
Any and all help is appreciated!
AnnieB
AnnieB's Profile: http://forums.techarena.in/members/annieb.htm
View this thread: http://forums.techarena.in/windows-v...rk/1045886.htm
Old 09-28-2008   #2 (permalink)
+Bob+
Re: Losing wireless connection to specific wireless network
On Mon, 29 Sep 2008 02:36:39 +0530, AnnieB
<AnnieB.3gguzc@xxxxxx> wrote:
Quote:
>Hi All,
>every time
As a first step, go into your router and change the Channel it is
operating on. Choose 1, 6, or 11.
Since you neighbor's router is apparently unsecured, you might want to
log into his router and check to see what channel he is using (and
choose another).
I'd also suggest going into the Power Options, Advanced Settings and
setting your wireless network card to "maximum performance". Then go
into Device Manager, Network, wireless card, Power Management and
uncheck the "all power management to control this device".
If you need more instruction on any of this just ask.
Old 09-28-2008   #3 (permalink)
AnnieB
Hi Bob,
Thanks for your help. I'll try that now.
AnnieB
Old 09-30-2008   #4 (permalink)
Victor S.
RE: Losing wireless connection to specific wireless network
If Bob's suggestions don't work, check Sony's website for updated wireless
network card drivers.
Old 09-30-2008   #5 (permalink)
Gordon
"Victor S." <VictorS@xxxxxx> wrote in message
news:67D53E2F-9682-41E8-ABA7-D5268DE004D6@xxxxxx
Please quote the post you are replying to - most regulars here do NOT use
the web interface.
http://dts-l.net/goodpost.htm
http://www.netmeister.org/news/learn2quote.html
Thank you.
Can one start a script after connecting to a specific wireless network? Vista installation & setup
Keep on Losing Wireless Internet Connection Vista General
Losing wireless connection Vista print fax & scan
Losing wireless connection after resume Vista General
