Vista - Page Not Found Problem
Old 09-28-2008   #1 (permalink)
Vista Ultimate x64
Hello,
Just installed Vista 64, i'm connecting to the internet using a Linksys WRT54G Ver. 8 router. Pretty vanilla. What i'm finding is that when visiting a site that I haven't visited before, there is a 5-10 second delay (usually in the "Looking Up" phase of the connection) to pull up the page OR it times out. I'm not talking about some podunk page, but something like microsoft.com or yahoo.com. Once the page is cached,then theres no problem.
Anyone have experience with this router and slow downs? I haven't installed any drivers, etc. I have just used what Vista gave me.
** Wanted to update this. It seems that oftentimes I click a link to go to a page, and the page times out. then I reselect the link and it's fine. Any thoughts?
thanks
Old 09-29-2008   #2 (permalink)
Jack \(MVP-Networking\).
Re: Page Not Found Problem
Hi
Sites that you already visit are cached on the Hard Drive so there is No
need for extended Internet traffic to brink them back.
New sites depends on the Internet connection and if they load so slow it
means that the Router or (some thing else) impedes the connection.
Cable/DSL do no need drivers. Either the Router is Not configured correctly
or it is a "lame" unit.
Did you try to connect the computer directly to the modem to find out
whether it is your new installation or the Router?
Jack (MS, MVP-Networking)
"mistafadedglory" <guest@xxxxxx-email.com> wrote in message
news:641eceddf3f2603201388341b0518665@xxxxxx-gateway.com...
Quote:
> Hello,
> delay to pull up the page OR it times out. I'm not talking about some
> thanks
> mistafadedglory
Old 09-29-2008   #3 (permalink)
+Bob+
On Mon, 29 Sep 2008 11:37:45 -0400, "Jack \(MVP-Networking\)."
<jack@xxxxxx> wrote:
Quote:
>Hi
I think Jack is heading in the right direction. Have you done a speed
test on your line lately? It sounds like you have general speed
issues. These are more likely due to a bad modem.
http://www.speakeasy.net/speedtest/
Old 09-30-2008   #4 (permalink)
Victor S.
RE: Page Not Found Problem
One common cause of this is the phishing filter having problems. To see if
this is the cause of your problem, disable the phishing filter in Internet
Explorer (under Tools / Internet Options / Advanced, near the bottom).
If that does not help, then maybe the first DNS server your router is using
is not replying so it waits to time out, then switches to the next DNS
server? If you manually set up the DNS servers on your Vista computer or the
router, try changing the order of the DNS servers.
Old 09-30-2008   #5 (permalink)
Gordon
"Victor S." <VictorS@xxxxxx> wrote in message
news:B5C5B59C-9CEF-43FA-AE6A-2279F9D05D21@xxxxxx
> if
> using
> the
Please quote the post you are replying to - most regulars here do NOT use
the web interface.
http://dts-l.net/goodpost.htm
http://www.netmeister.org/news/learn2quote.html
Thank you.
Problem with Personalization page General Discussion
Firefox page problem Browsers & Mail
Found new hardware problem Vista hardware & devices
Found the Problem Vista General
