IPv6: When will we start using it?
  1. #1
    Nathan Sokalski Guest
    Those of you that are technical people probably know that IPv6 has existed
    for several years now (I'd have to check for the exact amount). But none of
    the Internet Service Providers that I have used or looked at since then are
    offering to use it with their customers yet. I realize that it is a major
    change because of the fact that older software might not be capable of
    everything, all those people that refuse to upgrade their operating systems
    (my dad still uses Windows 98, even though we have an extra XP system
    sitting around) may have some problems, and all those companies with static
    IP addresses will need to take care of some stuff. Even though it has some
    backward compatibilities (It's been a while since I looked over the specs
    for it, and even though I'm a developer, networking isn't my concentration),
    it will be a big project for everyone. But I stopped hearing about it a
    while ago, and with all the updates that have been going on lately (IE7 and
    the increase in broadband usage, for example), I'm wondering when the
    project will begin. Does anybody have any information on when the big
    companies (Microsoft, Verizon, etc.) will start pushing this, and what some
    of the next steps might be?
    Nathan Sokalski
    njsokalski@hotmail.com
    http://www.nathansokalski.com/
  2. #2
    Chuck Guest
    Re: IPv6: When will we start using it?
    On Fri, 26 May 2006 01:29:02 -0400, "Nathan Sokalski" <njsokalski@hotmail.com>
    Nathan,
    Many folks have been asking that question. One of the problems is that there
    are not a lot of folks using it, because there are not a lot of websites using
    it. And vice-versa. The fact that Windows Networking under XP doesn't work
    well with it probably doesn't help either.
    IPV6 will be a native part of the network stack in Vista. But will Vista drive
    its popularity?
    <http://nitecruzrnews.blogspot.com/2006/05/does-ipv6-have-future.html>
    http://nitecruzrnews.blogspot.com/20...ve-future.html
    Cheers,
    Chuck, MS-MVP [Windows - Networking]
    http://nitecruzr.blogspot.com/
    Paranoia is not a problem, when it's a normal response from experience.
    My email is AT DOT
    actual address pchuck mvps org.
  3. #3
    Pierre Szwarc Guest
    Re: When will we start using it?
    The IP v6 stack is already alive and kicking in Vista (just look at your
    connection's properties). What you need is an IP v6 network to connect to.
    That means IP v6 router(s) and server(s), and these aren't very widespread
    yet. In fact, I haven't yet seen any consumer IP v6 routers or switches yet,
    and professional ones are *way* out of my budget.
    Pierre Szwarc
    Paris, France
    PGP key ID 0x75B5779B
    Multitasking: Reading in the bathroom !
    "Nathan Sokalski" <njsokalski@hotmail.com> a écrit dans le message de news:
    O7egMVIgGHA.2032@TK2MSFTNGP02.phx.gbl...
    of
    are
    systems
    static
    concentration),
    and
    some
    | Nathan Sokalski
  4. #4
    Andre Da Costa [Extended64] Guest
    It will probably be a sensible choice I guess if your entire network is
    using Longhorn Server/Vista.
    Andre
    Windows Connected | http://www.windowsconnected.com
    Extended64 | http://www.extended64.com
    Blog | http://www.extended64.com/blogs/andre
    http://spaces.msn.com/members/adacosta
    "Chuck" <none@example.net> wrote in message
    news:616d72d9qeiupn69rmbcn3rgapr51e71hg@4ax.com...
    >>of
    >>are
    >>systems
    >>static
    >>concentration),
    >>and
    >>some
    > Nathan,
    > there
    > using
    > work
    > drive
    > its popularity?
    > Cheers,
    > My email is AT DOT
  5. #5
    Chuck Guest
    On Fri, 26 May 2006 07:03:13 -0700, "Andre Da Costa [Extended64]"
    Right.
    So what will get an entire network using Longhorn / Vista? Is there really a
    business case for that?
    Cheers,
    My email is AT DOT
  6. #6
    No, but Siemens did do a massive roll out of Server 2003 on 8,000 Servers
    and XP on 400,000 desktops, plus Office and XP supports IPv6, so its not
    like the transition would be PITA.
    Andre
    news:cr4e72lpmpo1jnu372tiai529rkfr0mbg9@4ax.com...
    > Right.
    > really a
    > Cheers,
    > My email is AT DOT
  7. #7
    Adam Leinss Guest
    "Nathan Sokalski" <njsokalski@hotmail.com> wrote in
    news:O7egMVIgGHA.2032@TK2MSFTNGP02.phx.gbl:
    > what some of the next steps might be?
    Look at computing history for your answer. Our company is still
    running some 16-bit GUI MS-Windows applications. 16-bit GUI MS-Windows
    applications first appeared in Windows 3.0 back in 1990. Now 17 years
    later, Microsoft is finally dropping support for them in the operating
    system. It's even worst for MS-DOS applications: you can run some MS-
    DOS programs from 1981 on existing Windows XP machines. That's _25
    years_ of compatibility!
    IPV6 also yields little to no benefit for most companies. Why drop
    Benjamins on something that doesn't produce immediate results?
    Adam
    Visit my PC Tech blog at www.leinss.com/blog
IPv6: When will we start using it? problems?
Can't see IPv6 The Informer Vista networking & sharing 3 13 Mar 2008
TCP/IPv6 Sylvia Vista General 11 08 Nov 2007
RE: ICS fail to start, IPV6 stack issue vluke Vista networking & sharing 3 29 Aug 2007
IPv6 DanS Vista General 3 19 Mar 2007
IPv6 =?Utf-8?B?QmVuIEdyaWZmaXRocw==?= Vista networking & sharing 3 28 Sep 2006
