Vista - wifi router installation help required
Old 11-29-2008   #1 (permalink)
Vista Ultimate
Hello,
I am using vista ultimate with internet broadband connection from elitecore 24 online and to log in my connection requires browser login where i have to enter user name and password twice.
Now,
My query ::
how to use netgear wifi router WGR614 v7 with this connection .
things that i tried..
1. plugged in my broadband cable directly into router and saved login name n password in the the router. DID NOT WORk.
2. bought new ethernet card (say 2 ), and did internet sharing on the old ethernet card ( say 1 ) and set ethernet card 2 on obtain ip automatically and plugged in wifi router on the ethernet card 2 and set wifi router on internet connection does not require login name n password. DID NOT WORK.
PLEASE help ....
Old 11-29-2008   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: wifi router installation help required
You need to setup the router for PPPoE connection.
Old 11-29-2008   #3 (permalink)
Vista Ultimate
Did that selected PPPoE.
this time it asked for my login username n password , entered it.
I am checking this wifi router work status over my iphone.
and my iphone shows the wifi network and i can do the login into it :
BUT i CANNOT use net over it. a
Old 11-29-2008   #4 (permalink)
Jack \(MVP-Networking\).
Hi
There is two aspects to the process.
1. Configure the Internet (WAN) side of the Router.
Maybe this can Help, http://www.ezlan.net/PPPOE.html
2. Configure the LAN (computers) side of the Router.
Read carefully the Router's full Manual. It seems that you are confusing
different aspects of the process.
Jack (MS, MVP-Networking)
"pawandeep" <guest@xxxxxx-email.com> wrote in message
news:0634f23f4669ab8d2b0c6347441eb0c9@xxxxxx-gateway.com...
Quote:
> Hello,
> Now,
> My query ::
> PLEASE help ....
> pawandeep
Router required??? Vista General
Can't Connect wifi w/internet when connected to RJ45 to another Router (x64) Network & Sharing
Sharing a WiFi with ICS over a wireless router? Network & Sharing
Intel WiFi 4965 AGN / Vista - powers down Router - help? Vista networking & sharing
Vista without internet connection behind wifi router running as cl Vista networking & sharing
