Vista - Problem reconnecting offline files when mapped as a drive
Old 12-01-2008   #1 (permalink)
GeoffL
I have vista business, sp1. I use offline file a lot, and it works well most
of the time. But I have found that when the folder is set as a drive
mapping, and made to be offline, that often it does not re-connect when the
server is available. When I try to go to the server, all I see is the files
that are stored offline, and not all of the files available on the server (I
have only made some folders available). If I remove the drive mapping, then
it will reconnect. Also, without un-mapping the drive, if I put in the ip
address of the server in the form \\1.2.3.4 then I can log on, and see the
folders, so I know that the server is available. Does anyone have
suggestion, other than to not map the server. I like mapping the server,
because it makes the folders easily accesable in explorer.
Vista mapped drive problem Vista networking & sharing
Cannot rename files on mapped drive Vista networking & sharing
problems with reconnecting mapped network drive Vista networking & sharing
Can't modify folders, files on mapped network drive Vista file management
Mapped Drive problem -Attempt to Compromise Security? Vista networking & sharing
