Vista - Blackberry Dialup connection interupts wireless connection
Old 10-03-2006   #1 (permalink)
=?Utf-8?B?TGVvbiBDdXRsZXI=?=
I have my blackberry 7130e setup to be used as a tethered modem when I am not
at home, or work. But when I am using wireless, I keep getting taken offline,
and the dialup box keeps popping up to connect through my phone. I went into
internet explorer7 settings and changed my connection to "never dial-up" from
"dial whenever an internet connection is not present". I have been using this
for a while, but could this have been the issue?
Wireless connection works, cable connection does not! Vista General
Script to create Dialup connection on XP VB Script
how to set up dialup connection for guest user? Vista General
BT Dialup connection Vista General
Setup a Dialup Connection Vista General
