Vista Tutorial - wireless internet problem with vista
Old 10-05-2006   #1 (permalink)
=?Utf-8?B?U2NobWlkdA==?=
Guest
I just installed vista and I cannot connect to the internet. The wireless
adapter is recognized and it states I have a strong connection. It will not
allow me to access the internet however. When I boot to the drive that has
XP still on it, the internet works fine. If anyone can Help I would
appreciate it.
Old 10-05-2006   #2 (permalink)
=?Utf-8?B?cm95c3RyZWV0?=
Guest
RE: wireless internet problem with vista
If it means anything, I am having the same problem. If I use my old
fashioned wired router, I can connect...So any help would be much appreciated!
Thanks,
---roystreet
> appreciate it.
Old 10-06-2006   #3 (permalink)
=?Utf-8?B?RGVzZXJ0IHJhdHQ=?=
Guest
I have the same problem. Have tried the settings for beta 2 but they will
not work Vista says my key is wrong when I know it is not. Other drive with
Beta 2 works great although it did take a while to get it working.
> Thanks,
> ---roystreet
> > appreciate it.
Old 10-09-2006   #4 (permalink)
roystreet
Guest
Hello Again,
I discovered how to make mine work. I always used AES WPA security
on my wireless network. I was testing different settings & tried TKIP WPA
instead of AES & it worked just fine after that. I can't remember off of the
top of my head, but is TKIP less secure than AES? (Or less reccomended?) I
would like to use the most secure method. I did discover the my network
would work unsecured, but that's not acceptable.
Thanks,
-roystreet
> > Thanks,
> > ---roystreet
> > > appreciate it.
Vista+usb wireless internet=problem Network & Sharing
Lost internet on wireless LAN from friend's wireless router. Vista networking & sharing
Wireless internet problem Vista networking & sharing
Wireless internet, Vista, and HP Vista General
Vista vs. Xp wireless internet connection Vista networking & sharing
