Vista - Vista and XP Home Networking Problems
Old 02-14-2009   #1 (permalink)
Faile
I have a weird problem in my network setup.
I recently upgraded to a Gigabit router since I wanted to install a
small file server and wasn't satisfied with 8Mbyte/s on 100Mbit.
Well, my problems is as follows :
Starting transfers on my Vista Ult. SP1 Workstation :
Vista -> XP Home SP3 = 17Mbyte/s
Vista <- XP Home SP3 = 17Mbyte/s
Now the kicker if I start the transfers on my XP Home Server :
XP Home <- Vista = 17Mbyte/s
XP Home -> Vista = 55Mbyte/s !!!!!!
So, if I start the file transfer to my Vista machine on the XP Home via
Remote controle I get decent Gigabit speeds but not in any other case.
I tried disabling and enabling :
-Jumbo Packets
-IPv6
-QoS
-Flow Control
-Checksum Offload (any offloads I could turn off I tried)
-Auto-Tuning (tried even different levels of it)
-Tried killing all processes I could on the vista machine
-Tried the fix to disable the Multimedia Class Scheduler
Nothing changes the speed even by a bit...well, enabling Jumbo Packets
on the XP Home Machine made everything worse, that was the only thing
that made any change at all.
The Physical connection must be ok since I do get 55Mbyte/s one way, so
I guess there must be a software problem somewhere.
As it is now I can't do what I wanted, which is treat the server as an
intelligent HD so I can, for example, map the server drive and
decompress a file directly from there to my local disk with the
horsepower of my local machine. To do that now I have to log on remotely
to my server, push the files to my local HD and then I can decompress
them.
If you wonder why XP Home SP3 is on my server....well, it was on there
and it works, Vista is a no go for that machine since the server is not
powerful enough for that.
Hope someone has an idea what might be up with this
Faile
Faile's Profile: http://forums.techarena.in/members/faile.htm
View this thread: http://forums.techarena.in/windows-v...rk/1122536.htm
Vista and XP Home Networking Problems Network & Sharing
Slow networking between Vista Home Premium and Windows Home Server Vista networking & sharing
XP Home and Vista Home Networking Vista networking & sharing
Home Networking - hope this helps others having problems Vista networking & sharing
My cure for Vista home networking problems Vista networking & sharing
