| | Remote Desktop Problems I have been having ongoing problems with Remote Desktop since Beta 2 (now on RC2). I connect from work fine (from XP Pro) and it runs smooth for maybe a minute then the screen update stalls for 30-40 seconds at a time (it gets really irritating). I thought it may have been a bandwidth problem at work but I am running Remote Desktop to XP at home now (dual boot) and it works as always. It seems like a screen buffer is emptying and then a delay catching up again (if that makes sense). I tried bypassing my router, using another NIC (my motherboard has 2) and still no change. I did send a bug report to MS. Is anyone else having this kind of problem? Thanks, Dave |
| | RE: Remote Desktop Problems I can verify having this same problem, pretty annoying. I thought it was bandwidth at first as well but I ruled that out the same way you did. "Dave Balcom" wrote: > I have been having ongoing problems with Remote Desktop since Beta 2 > (now on RC2). I connect from work fine (from XP Pro) and it runs smooth > for maybe a minute then the screen update stalls for 30-40 seconds at a > time (it gets really irritating). I thought it may have been a bandwidth > problem at work but I am running Remote Desktop to XP at home now (dual > boot) and it works as always. It seems like a screen buffer is emptying > and then a delay catching up again (if that makes sense). I tried > bypassing my router, using another NIC (my motherboard has 2) and still > no change. I did send a bug report to MS. > > Is anyone else having this kind of problem? > > Thanks, > Dave > |
| | Re: Remote Desktop Problems On Tue, 10 Oct 2006 14:40:03 -0700, Andy <Andy@discussions.microsoft.com> wrote: }I can verify having this same problem, pretty annoying. I thought it was }bandwidth at first as well but I ruled that out the same way you did. The strange thing is within my LAN I can connect to Vista just fine. It is when going over the Internet that the problem surfaces. Going from Vista/XP at home to XP Pro at work is OK too. |
| | Re: Remote Desktop Problems I have not seen that at all. I run Remote Desktop to my Vista RC2 box via a PPTP VPN tunnel and have no issues at all. Do you think it might be a variation of a MTU issue with the router? See this page from Bob Lin's (MS-MVP) site... http://www.howtonetworking.com/casestudy/mtu1.htm FWIW I am on a cable ISP... -- Al Jarvi (MS-MVP Windows Networking) Please post *ALL* questions and replies to the news group for the mutual benefit of all of us... The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights... "Dave Balcom" <balcy24@charter.net> wrote in message news:1neqi2h0foq6juucbt69so88rur05jsm3a@4ax.com... > On Tue, 10 Oct 2006 14:40:03 -0700, Andy > <Andy@discussions.microsoft.com> wrote: > > }I can verify having this same problem, pretty annoying. I thought it was > }bandwidth at first as well but I ruled that out the same way you did. > > The strange thing is within my LAN I can connect to Vista just fine. It > is when going over the Internet that the problem surfaces. Going from > Vista/XP at home to XP Pro at work is OK too. |
| | Re: Remote Desktop Problems On Wed, 11 Oct 2006 14:05:01 -0500, "Sooner Al [MVP]" <SoonerAl@somewhere.net.invalid> wrote: }I have not seen that at all. I run Remote Desktop to my Vista RC2 box via a }PPTP VPN tunnel and have no issues at all. I tried starting a PPTP VPN first and it connected but it would not let me login. From work to home I was able to use Remote Desktop alone and it let me login but was extremely slow. Going the other way (home to work) I have to use a VPN to get through the company firewall. }Do you think it might be a variation of a MTU issue with the router? See }this page from Bob Lin's (MS-MVP) site... Makes sense but didn't Vista change to a self tuning stack? With RC1, I took the router off and connected directly to my Charter broadband modem with no change. I haven't tried that with RC2. My router is an older Netgear RT314. I couldn't find where the MTU could be changed on it. }FWIW I am on a cable ISP... Me too... ![]() |
| | #6 (permalink) |
| | Re: Remote Desktop Problems Anything in the event logs that may be of interest? -- Al Jarvi (MS-MVP Windows Networking) Please post *ALL* questions and replies to the news group for the mutual benefit of all of us... The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights... |
| | #7 (permalink) |
| | Re: Remote Desktop Problems On Thu, 12 Oct 2006 13:50:38 -0500, "Sooner Al [MVP]" <SoonerAl@somewhere.net.invalid> wrote: }Anything in the event logs that may be of interest? I found 2 entries in the Windows system log. Both were source: TermDD, Event ID: 56, "The Terminal Server security layer detected an error in the protocol stream and has disconnected the client" with the same time stamp. I remember the connection dropping this morning at about that time. There were several (actually 14) printer driver errors in the system log too, source: Umrdpservice, event ID: 1111 a few minutes before the error above. I am connecting from a domain with several print servers. Is this any help? |
| | #8 (permalink) |
| | Re: Remote Desktop Problems There are some hints on the EventID site that may or may not be of some help. Beyond that hopefully someone else has some ideas... http://tinyurl.com/ve6fu FWIW, I configure my Vista RC2 machine Remote Desktop encryption level for "High" encryption only... I am also running the Beta Remote Desktop Client Version 6 software on all of my XP Pro client machines... -- Al Jarvi (MS-MVP Windows Networking) Please post *ALL* questions and replies to the news group for the mutual benefit of all of us... The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights... "Dave Balcom" <balcy24@charter.net> wrote in message news 4lti215h9lst70hgml0kif2m5slc31b9b@4ax.com...> On Thu, 12 Oct 2006 13:50:38 -0500, "Sooner Al [MVP]" > <SoonerAl@somewhere.net.invalid> wrote: > > }Anything in the event logs that may be of interest? > > I found 2 entries in the Windows system log. Both were source: TermDD, > Event ID: 56, "The Terminal Server security layer detected an error in > the protocol stream and has disconnected the client" with the same time > stamp. I remember the connection dropping this morning at about that > time. > > There were several (actually 14) printer driver errors in the system log > too, source: Umrdpservice, event ID: 1111 a few minutes before the error > above. I am connecting from a domain with several print servers. > > Is this any help? |
| Remote Desktop problems | Vista General | |||
| Remote Desktop - Login Problems | Vista networking & sharing | |||
| Remote desktop causes taskbar problems | Vista General | |||
| Remote Desktop Problems | Vista networking & sharing | |||
| Problems with Vista Remote Desktop | Vista networking & sharing | |||
