| | Vista - RE: wireless on VISTA problem |
| 04-14-2009 | #1 |
| | RE: wireless on VISTA problem "99XJ" wrote: Quote: > I just installed a D-Link DIR-625 router, before, we had a Linksys router > with no issues whatsoever. (This is in secure WPA mode, there is no problem > in "unsecure" mode) My sons PC has Vista installed. He has a D-Link > wireless usb adaptor. Before, with the Linksys router, hookup was as would > be expected, find the SSID, click, a prompt for passphrase, sweet. > > Now what happens is this... I right click the network icon in the taskbar > and select "Connect to a network" a list of available networks shows.( as > usual) I click our SSID and a different message appears than before, instead > of getting the usual prompt for a simple passphrase, I get a "Windows needs > more credentials to connect to this network", I click it and then a window > appears prompting for... > > Username > Password > Domain pass > > this is not an option suitable for the usual WPA Personal encryption, first > off there is no user name, no domain, its just WPA personal, TKIP, > passphrase... what can I do? like I said it connects fine if no encryption > is used. and it worked fine Lo these last 2 years with a Linksys WRT54G > > I'm not very familiar with Vista, I'm an XP man myself > > (I and my wife have XP, router installed on mine) > (My wife has windows XP with a Linksys adaptor and it works fine so I know > it is a Vista conflict) > > |
| My System Specs |
| Similar Threads for: RE: wireless on VISTA problem | ||||
| Wireless problem on Vista | Vista networking & sharing | |||
| Wireless Problem With Vista | Vista General | |||
| vista 64 bit wireless problem | Network & Sharing | |||
| Vista Wireless Problem... | Vista networking & sharing | |||
| Vista wireless problem | Vista General | |||
