Vista - help! why cannot remote connect XP laptop to Vista Home PC?
Old 05-10-2009   #1 (permalink)
LunaMoon
I knew Vista Home does not allow remote desktop connection to it.
I followed some online hack and install some Terminal Service hack
file.
It worked when my laptop Windows XP sits close to the Vista HOME PC,
when the laptop is using wireless and the Vista is using Internet LAN
connection. I made sure my Kaspasky Internet Security Firewall is open
for RDP port.
But the moment when I move out of my home, and bring the laptop to an
outside network, I cann't connect to the Vista Home PC anymore.
Any thoughts?
If RDP to Vista is not an option. What is the next best remote
connection software that allows smooth file transform and clipboard
transfer, as seamless as RDP?
Thanks!
Old 05-14-2009   #2 (permalink)
Bill Kearney
Re: help! why cannot remote connect XP laptop to Vista Home PC?
> Okay! I have no way of configuring the router.
Quote:
> Any other next best remote control software?
It's your router, in your home, why can't you configure it?
Are you interested in remote controlling your home PC console session? If
so then look into something like logmein.com
And don't shot-gun questions to a dozen different groups. Pick one. It's
just rude otherwise.
-Bill Kearney
help! why cannot remote connect XP laptop to Vista Home PC? Vista General
help! why cannot remote connect XP laptop to Vista Home PC? Vista installation & setup
help! why cannot remote connect XP laptop to Vista Home PC? Vista performance & maintenance
help! why cannot remote connect XP laptop to Vista Home PC? Vista security
Vista Home Premium can't connect by remote desktop to XP Media Cen Vista General
