| Guest | Wireless networking on a Toshiba M200 Has anyone been able to make the Atheros AR5001X (built in) card connect to a wireless network. The hardware installs correctly in Device Manager, but the wizard says there are no wireless networks to connect to. If I try to create a manual connection, it asks for the adapter, and then the next screen just says "an unexpected error occured" Any suggestions would be welcomed ![]() |
| Guest | Re: Wireless networking on a Toshiba M200 you might give the XP drivers a go. Josh "Marcus Dunne" <Marcus Dunne@discussions.microsoft.com> wrote in message news:CECA8404-5928-4C00-BCFF-AF2F046B7BF5@microsoft.com... > Has anyone been able to make the Atheros AR5001X (built in) card connect > to a > wireless network. The hardware installs correctly in Device Manager, but > the > wizard says there are no wireless networks to connect to. > > If I try to create a manual connection, it asks for the adapter, and then > the next screen just says "an unexpected error occured" > > Any suggestions would be welcomed ![]() |
| Guest | Re: Wireless networking on a Toshiba M200 I am having the same issue but with Tecra M2. It used to work fine with Beta1 Also I have two hard drives, one for XP and other for Vista, if I POP the XP drive, the same adapter connects fine, while on Vista it does not even show any signal strength, let alone connecting to the network Is this still a driver problem or something else????? "Josh" wrote: > you might give the XP drivers a go. > > Josh > "Marcus Dunne" <Marcus Dunne@discussions.microsoft.com> wrote in message > news:CECA8404-5928-4C00-BCFF-AF2F046B7BF5@microsoft.com... > > Has anyone been able to make the Atheros AR5001X (built in) card connect > > to a > > wireless network. The hardware installs correctly in Device Manager, but > > the > > wizard says there are no wireless networks to connect to. > > > > If I try to create a manual connection, it asks for the adapter, and then > > the next screen just says "an unexpected error occured" > > > > Any suggestions would be welcomed ![]() > > > |
| Guest | Re: Wireless networking on a Toshiba M200 Any ideas???????? or suggestion on how to resolve this issue "kaushas" wrote: > I am having the same issue but with Tecra M2. It used to work fine with Beta1 > Also I have two hard drives, one for XP and other for Vista, if I POP the XP > drive, the same adapter connects fine, while on Vista it does not even show > any signal strength, let alone connecting to the network > > Is this still a driver problem or something else????? > > "Josh" wrote: > > > you might give the XP drivers a go. > > > > Josh > > "Marcus Dunne" <Marcus Dunne@discussions.microsoft.com> wrote in message > > news:CECA8404-5928-4C00-BCFF-AF2F046B7BF5@microsoft.com... > > > Has anyone been able to make the Atheros AR5001X (built in) card connect > > > to a > > > wireless network. The hardware installs correctly in Device Manager, but > > > the > > > wizard says there are no wireless networks to connect to. > > > > > > If I try to create a manual connection, it asks for the adapter, and then > > > the next screen just says "an unexpected error occured" > > > > > > Any suggestions would be welcomed ![]() > > > > > > |
| Guest | Re: Wireless networking on a Toshiba M200 I have got the same problem. I got an Acer Aspire Notebook (should be with an Atheros-W-LAN device) and Windows Vista tells me that i have to press the button in front of my notebook. So i did and nothing changed... HELP ME PLEASE!!! "kaushas" wrote: > Any ideas???????? or suggestion on how to resolve this issue > > "kaushas" wrote: > > > I am having the same issue but with Tecra M2. It used to work fine with Beta1 > > Also I have two hard drives, one for XP and other for Vista, if I POP the XP > > drive, the same adapter connects fine, while on Vista it does not even show > > any signal strength, let alone connecting to the network > > > > Is this still a driver problem or something else????? > > > > "Josh" wrote: > > > > > you might give the XP drivers a go. > > > > > > Josh > > > "Marcus Dunne" <Marcus Dunne@discussions.microsoft.com> wrote in message > > > news:CECA8404-5928-4C00-BCFF-AF2F046B7BF5@microsoft.com... > > > > Has anyone been able to make the Atheros AR5001X (built in) card connect > > > > to a > > > > wireless network. The hardware installs correctly in Device Manager, but > > > > the > > > > wizard says there are no wireless networks to connect to. > > > > > > > > If I try to create a manual connection, it asks for the adapter, and then > > > > the next screen just says "an unexpected error occured" > > > > > > > > Any suggestions would be welcomed ![]() > > > > > > > > > |
| Toshiba L305-S5884 wireless card and hard drive issue on Vista | Vista General | |||
| vista + toshiba m200 | Vista General | |||
| Toshiba N Vidia Ge Force G0 6200 TE 64M for Canadian Toshiba Tecra | Vista hardware & devices | |||
| Toshiba M200 and Vista | Vista hardware & devices | |||
| Install Vista on Toshiba M200 via USB DVD Drive | Vista installation & setup | |||
