Vista - Problem with internet connectivity on HP laptop running on Vista
Old 07-02-2009   #1 (permalink)
Treadstone
Hello,
I am facing a strange problem with my HP Dv6705 laptop running on Vista
Professional.
I have a Wi-fi router configured for internet access.
Now, the internet connectivity is intermittent i.e. I am connected to
the internet for about 5 seconds before it gets disconnected. I get the
connectivity again after a few seconds before it gets disconnected.
Now, I started using the uTorrent application after which I got
prolonged connectivity. From the past few days, whenever I need
uninterrupted internet I need to turn on the uTorrent application.
It is quite strange that I am the only one who needs to do this while
the others in my house (who have similar laptops) do not face any
problem.
Is there any way to detect what exactly is happening and how I can
resolve this uTorrent workaround?
Thanks in advance.
- Treadstone
Treadstone
Treadstone's Profile: http://forums.techarena.in/members/110667.htm
View this thread: http://forums.techarena.in/windows-v...rk/1206714.htm
Old 07-02-2009   #2 (permalink)
Jack-MVP
Re: Problem with internet connectivity on HP laptop running on Vista
Hi
Take a look of of is running the Wireless and make sure that only one
Utility is running (either the Vendor utility, or Window WLAN Auto Config).
In addition, many Laptops come with "Loads of Junk" in the StratUp that is
running unneeded in the background (including applications that affect the
Network connection) take a look at the StartUp and remove things that you do
not need.
Get these two free Utilities (StartUp & Process Explorer).
Check what your computer is doing upfront (StartUp),
http://www.ezlan.net/infestation.html#startup
Then get this one and check what it is doing behind you back.
http://www.ezlan.net/infestation.html#process
P.S. these utility are free and do not need even to get installed, just run
the Exe files it does not take more then few seconds.
Jack (MS, MVP-Networking)
"Treadstone" <Treadstone.3uol7c@xxxxxx> wrote in message
news:Treadstone.3uol7c@xxxxxx
Quote:
> Hello,
> Professional.
> problem.
> Thanks in advance.
> - Treadstone
> Treadstone
> View this thread:
Old 07-03-2009   #3 (permalink)
PhilPerrier
Treadstone,
Which is the state of connection network to the place you uses your
laptop? Is the signal good? Which is the transmission speed of the
laptop when that arrives?
PhilPerrier
PhilPerrier's Profile: http://forums.techarena.in/members/110305.htm
Old 07-09-2009   #4 (permalink)
Trio
Remove Utorrent from your pc,this was also my same problem last week the
i switched in to bit lord,
you can get it from here.
Trio
Trio's Profile: http://forums.techarena.in/members/48449.htm
Old 07-09-2009   #5 (permalink)
PhilPerrier
Treadstone,
Your Atheros card transmit from 6 to 54 Mbs. If the signal is bad, the
transmission will be done at speeds' bellow 30 Mbps. Probably, that the
speed of 12 Mbps is caused by the weakness of the signal. You should
try to connect your laptop close to your router in order to check if you
do not lose the connection due to quality of the signal. If it is the
case, moves your router in an elevated place in order to pass over the
most metallic’s objects as possible.
PhilPerrier
Re: Internet connectivity problem Vista General
Internet Connectivity Problem Network & Sharing
Problem booting up laptop running Vista when overseas Vista General
Internet Connectivity Problem Vista networking & sharing
internet connectivity issue on laptop Vista networking & sharing
