Error: A cable is not plugged into the network adapter "Local Area Connection"
  1. #1
    Newbie
    Vista x64
    Local Time: 02:10 AM
    Hey all - having a rather frustrating experience with my computer.
    I'm on Vista x64 with an ASUS P5N-SLI mobo and a Realtek RTL8139/810x NIC.
    The onboard ethernet stopped working on my mobo, so I bought a cheap OEM NIC and installed it earlier today. The modem is reading it fine - the PC link light is illuminated - but Vista seems to think that there's nothing plugged into it.
    In accordance with other people having this issue, I went into my BIOS and disabled everything I could - namely the 1394 onboard firewire - but nothing has worked. When I disabled the Nvidia LAN controller in the BIOS, the computer was able to communicate with the network sort of - but for whatever reason, was still unable to connect fully or to the internet. It was giving me errors about assigning the IP, resetting the router, etc.
    Any ideas?
  2. #2
    Tae Song Guest
    Re: Error: A cable is not plugged into the network adapter "Local Area Connection"
    "hlliw" <guest@newsgroup-email.com> wrote in message news:1c0229d697c8b68a5ef5e7531bed6a2f@newsgroup-gateway.com...
    > NIC.
    > router, etc.
    > Any ideas?
    > hlliw
    Did you update the Realtek RTL8139/810x driver from Windows Update?
    I did and although no errors were reported in Device Manager, my network stopped working. I installed Realtek drivers from their site and it works fine. The NIC may look like it is not working if you install the driver from Windows update. It's dated back to 2007, I don't know what they're thinking offering that driver.
  3. #3
    smlunatick Guest
    Re: Error: A cable is not plugged into the network adapter "LocalArea Connection"
    > NIC.
    > router, etc.
    > Any ideas?
    > hlliw
    Can you try a different cable?
Plug a cable into network adapter "local area connection" or get ip automatically? nitins11 Network & Sharing 0 31 Jan 2010
Plug a cable into network adaptor "Local Area Connection"?? khayes .NET General 3 10 Mar 2009
Plug a cable into network adapter "local area connection" dmpp209 Network & Sharing 0 17 Feb 2009
Error: "A Cable is not plugged into Ethernet Adapter" DevLoy Vista networking & sharing 4 04 Feb 2008
What's "Tunnel adapter Local Area Connection" cstrike Vista networking & sharing 0 09 Oct 2006
