| | Re: HELP! No internet when copying files from ethernet drive I forgot to mention that I have exchanged both Modem and Router twice already! -- ABH83 ------------------------------------------------------------------------ ABH83's Profile: http://forums.techarena.in/members/142317.htm View this thread: http://forums.techarena.in/windows-v...rk/1256179.htm http://forums.techarena.in |
| | Re: HELP! No internet when copying files from ethernet drive Thank you for all the swift replies! Bill Kearney;4644669 Wrote: Quote: > Connect the laptop using a cat5 ethernet wire. See if the problem is > the > same. That will at least narrow down whether it's a wireless issue or > not. > > What network configuration is being used on the Lacie unit? Can you > bring > up it's config page and see what it's setup to use? > > Try using the laptop with a wired connection and report back. > > -Bill Kearney issue. I guess its because copying files on a wired connection usually takes me about 2 mins as opposed to copying files wirelessly which take me about 20-60 mins. Network configuration on the LaCie is set to automatic (DHCP). 'Jack [MVP-Networking Wrote: Quote: > ;4644672']Hi > Is it a LaCie related problem. > I.e. transfer of similar data computer to computer without using the > NAS > works OK. > If it is a LaCie problem, make sure that what ever protocol it uses his > also > used by the computer and its configuration is correct. > Jack (MS, MVP-Networking). any internet disturbance when copying files form other computers. However, when I copy files form other computers it will slow down the "host" computer (the one i'm copying from) imensly... almost unusable. Is that normal? Tae Song;4644854 Wrote: Quote: > How are you copying the files? FTP, Windows networking or software that > came with LeCie? > > I don't think it's the firewall or antivirus software. > > The cable modem is responding (quite badly) to the traffic between the > computer and network storage device. > > This is in strange in itself. > > Is the Arris CM450 connected to the ethernet port labeled Internet on > the > Linksys WRT54GL or one of the four numbered ethernet ports? use the web browser to access admin controls. In the user manual it recommends installing the software. But from what I can tell the software doesn't do much. I used Windows to map network drives. So I guess I'm using Windows networking. Yes the Arris Cable modem is connected to the Ethernet port labeled internet (IN) and the NetworkSpace is conected to the Ethernet port 2 (OUT). -- ABH83 ------------------------------------------------------------------------ ABH83's Profile: http://forums.techarena.in/members/142317.htm View this thread: http://forums.techarena.in/windows-v...rk/1256179.htm http://forums.techarena.in |
| | Re: HELP! No internet when copying files from ethernet drive "ABH83" <ABH83.3zsdvc@newsgroup> wrote in message news:ABH83.3zsdvc@newsgroup Quote: > > Thank you for all the swift replies! > > Bill Kearney;4644669 Wrote: Quote: >> Connect the laptop using a cat5 ethernet wire. See if the problem is >> the >> same. That will at least narrow down whether it's a wireless issue or >> not. >> >> What network configuration is being used on the Lacie unit? Can you >> bring >> up it's config page and see what it's setup to use? >> >> Try using the laptop with a wired connection and report back. >> >> -Bill Kearney > When I connect the laptop using ethernet cable I no longer have this > issue. I guess its because copying files on a wired connection usually > takes me about 2 mins as opposed to copying files wirelessly which take > me about 20-60 mins. > > Network configuration on the LaCie is set to automatic (DHCP). > > 'Jack [MVP-Networking Wrote: Quote: >> ;4644672']Hi >> Is it a LaCie related problem. >> I.e. transfer of similar data computer to computer without using the >> NAS >> works OK. >> If it is a LaCie problem, make sure that what ever protocol it uses his >> also >> used by the computer and its configuration is correct. >> Jack (MS, MVP-Networking). > Yes it seems this is related to the LaCie drive only. I did not notice > any internet disturbance when copying files form other computers. > However, when I copy files form other computers it will slow down the > "host" computer (the one i'm copying from) imensly... almost unusable. > Is that normal? > > Tae Song;4644854 Wrote: Quote: >> How are you copying the files? FTP, Windows networking or software that >> came with LeCie? >> >> I don't think it's the firewall or antivirus software. >> >> The cable modem is responding (quite badly) to the traffic between the >> computer and network storage device. >> >> This is in strange in itself. >> >> Is the Arris CM450 connected to the ethernet port labeled Internet on >> the >> Linksys WRT54GL or one of the four numbered ethernet ports? > The LaCie drive came with a software called Network Assistant. I also > use the web browser to access admin controls. > > In the user manual it recommends installing the software. But from what > I can tell the software doesn't do much. > > I used Windows to map network drives. So I guess I'm using Windows > networking. > > Yes the Arris Cable modem is connected to the Ethernet port labeled > internet (IN) and the NetworkSpace is conected to the Ethernet port 2 > (OUT). > > > -- > ABH83 > ------------------------------------------------------------------------ > ABH83's Profile: http://forums.techarena.in/members/142317.htm > View this thread: > http://forums.techarena.in/windows-v...rk/1256179.htm > > http://forums.techarena.in > reaching the cable-modem at all. Can you list which IP addresses are being assigned to which device? Linksys Computer LaCie Ariss You should be able to get all the info from the Linksys. Login to the Linksys and click on the Status tab. This will give IP configuration coming from the Ariss to Linksys. Under Status, you should see Router | Local Network | Wireless Click on Local Network and click on the DHCP Clients Table button for the other devices... assuming the menu is similar to the Linksys WRT54G I am using. |
| | Re: HELP! No internet when copying files from ethernet drive On Oct 9, 11:32*am, ABH83 <ABH83.3zs...@newsgroup> wrote: Quote: > Thank you for all the swift replies! > > Bill Kearney;4644669 Wrote: > Quote: > > Connect the laptop using a cat5 ethernet wire. *See if the problem is > > the > > same. *That will at least narrow down whether it's a wireless issue or > > not. Quote: > > What network configuration is being used on the Lacie unit? * Can you > > bring > > up it's config page and see what it's setup to use? Quote: > > Try using the laptop with a wired connection and report back. Quote: > > -Bill Kearney > When I connect the laptop using ethernet cable I no longer have this > issue. I guess its because copying files on a wired connection usually > takes me about 2 mins as opposed to copying files wirelessly which take > me about 20-60 mins. > > Network configuration on the LaCie is set to automatic (DHCP). > > 'Jack [MVP-Networking Wrote: > Quote: > > ;4644672']Hi > > Is it a LaCie related problem. > > I.e. transfer of similar data computer to computer without using the > > NAS > > works OK. > > If it is a LaCie problem, make sure that what ever protocol it uses his > > also > > used by the computer and its configuration is correct. > > Jack (MS, MVP-Networking). > Yes it seems this is related to the LaCie drive only. I did not notice > any internet disturbance when copying files form other computers. > However, when I copy files form other computers it will slow down the > "host" computer (the one i'm copying from) imensly... almost unusable. > Is that normal? > > Tae Song;4644854 Wrote: > Quote: > > How are you copying the files? *FTP, Windows networking or software that > > came with LeCie? Quote: > > I don't think it's the firewall or antivirus software. Quote: > > The cable modem is responding (quite badly) to the traffic between the > > computer and network storage device. Quote: > > This is in strange in itself. Quote: > > Is the Arris CM450 connected to the ethernet port labeled Internet on > > the > > Linksys WRT54GL or one of the four numbered ethernet ports? > The LaCie drive came with a software called Network Assistant. I also > use the web browser to access admin controls. > > In the user manual it recommends installing the software. But from what > I can tell the software doesn't do much. > > I used Windows to map network drives. So I guess I'm using Windows > networking. > > Yes the Arris Cable modem is connected to the Ethernet port labeled > internet (IN) and the NetworkSpace is conected to the Ethernet port 2 > (OUT). > > -- > ABH83 > ------------------------------------------------------------------------ > ABH83's Profile:http://forums.techarena.in/members/142317.htm > View this thread:http://forums.techarena.in/windows-v...k/1256179..htm > > http://forums.techarena.in the wireless "connections" to be "separate" from the other connections. On standard firmwares, this cam be known as "Wlan Protection." |
| | Re: HELP! No internet when copying files from ethernet drive Tae Song;4645478 Wrote: Quote: > That's very strange. Traffic between LaCie and your computer shouldn't > be > reaching the cable-modem at all. > > Can you list which IP addresses are being assigned to which device? > > Linksys > Computer > LaCie > Ariss > > You should be able to get all the info from the Linksys. > > Login to the Linksys and click on the Status tab. This will give IP > configuration coming from the Ariss to Linksys. > > Under Status, you should see Router | Local Network | Wireless > > Click on Local Network and click on the DHCP Clients Table button for > the > other devices... assuming the menu is similar to the Linksys WRT54G I > am > using. Quote: > > > Please check the router's settings. Normally, it is possible to set > the wireless "connections" to be "separate" from the other > connections. On standard firmwares, this cam be known as "Wlan > Protection." Sorry but there's something that just occured to me which I forgot to mention before. I doubt it matters though? I have a Desktop PC (Dell Dim 4400) attached via Ethernet to the router. It Uses an old 3com EtherLink card. My router is set to clone the MAC addrees of that PC. (Due to an old regulation of my ISP: allowing only one computer to be attached to the modem). The 2 other Laptops connect wirelessly. Linksys: 192.168.1.1 static Dell Desktop PC: 192.168.1.2 static MY Laptop: 192.168.1.6 static MetworkSpace: 192.168.1.13 static WAN IP (Arris?): 80.108.170.23 Some additional info: Under Status | Wireless: TX Power is 50mW and under Wireless Packet Info: Transmitted (TX): a big number around 56..... OK, 334 errors. Is that normal? THX -- ABH83 ------------------------------------------------------------------------ ABH83's Profile: http://forums.techarena.in/members/142317.htm View this thread: http://forums.techarena.in/windows-v...rk/1256179.htm http://forums.techarena.in |
| | #6 (permalink) |
| | Re: HELP! No internet when copying files from ethernet drive > Sorry but there's something that just occured to me which I forgot to Quote: > mention before. I doubt it matters though? > > My router is set to clone the MAC addrees of that PC. (Due to an old > regulation of my ISP: allowing only one computer to be attached to the > modem). You *may* want to considering totally resetting the configuration on the router. It's possible you've got something setup incorrectly. It might be best to reset the router to factory defaults and then start over from there. Also, be *certain* that you've got everything wired into the correct ports. And only once per device into the same network. From each machine do an "arp -a" in the cmd prompt. You should see that the IP to MAC addresses are consistent across each of them. The arp tables won't be the same on all of the computer. Each machine will only know about others that it connects with. You can cause a machine to load an arp entry by using the ping command. So to get the laptop on .6 to load an arp entry you'd just ping one of the other IP addresses. Post the 'arp -a' results here. -Bill Kearney |
| | #7 (permalink) |
| | Re: HELP! No internet when copying files from ethernet drive "ABH83" <ABH83.3zsujb@newsgroup> wrote in message news:ABH83.3zsujb@newsgroup Quote: > > Tae Song;4645478 Wrote: Quote: >> That's very strange. Traffic between LaCie and your computer shouldn't >> be >> reaching the cable-modem at all. >> >> Can you list which IP addresses are being assigned to which device? >> >> Linksys >> Computer >> LaCie >> Ariss >> >> You should be able to get all the info from the Linksys. >> >> Login to the Linksys and click on the Status tab. This will give IP >> configuration coming from the Ariss to Linksys. >> >> Under Status, you should see Router | Local Network | Wireless >> >> Click on Local Network and click on the DHCP Clients Table button for >> the >> other devices... assuming the menu is similar to the Linksys WRT54G I >> am >> using. > smlunatick;4645479 Wrote: Quote: >> >> >> Please check the router's settings. Normally, it is possible to set >> the wireless "connections" to be "separate" from the other >> connections. On standard firmwares, this cam be known as "Wlan >> Protection." > Hi! > > Sorry but there's something that just occured to me which I forgot to > mention before. I doubt it matters though? > > I have a Desktop PC (Dell Dim 4400) attached via Ethernet to the > router. > > It Uses an old 3com EtherLink card. > > My router is set to clone the MAC addrees of that PC. (Due to an old > regulation of my ISP: allowing only one computer to be attached to the > modem). > Take it off, in fact you might want to try resetting the router to factory defaults. Some setting on the router is causing traffic to reach the cable-modem. Did you setup the router manually? With the WRT54G I have, the local area network would be on 192.168.1.x subnet and if I had a cable-modem it might be on a separate subnet like 192.168.0.x. The traffic on subnet 192.168.1.x shouldn't show up on 192.168.0.x which is subnet the cable-modem would be on, since the laptop is on 192.168.1.6 going to 192.168.1.13 the traffic should only exist on the 192.168.1.x subnet. There might be two IP addresses assigned to the cable-modem and Linksys. Cable - modem Linksys ISP --- 80.108.170.23 | 192.168.0.1 --- 192.168.0.2 | 192.168.1.1 --- Home LAN Quote: > The 2 other Laptops connect wirelessly. > > Linksys: 192.168.1.1 static > Dell Desktop PC: 192.168.1.2 static > MY Laptop: 192.168.1.6 static > MetworkSpace: 192.168.1.13 static > > WAN IP (Arris?): 80.108.170.23 > > > Some additional info: > > Under Status | Wireless: > > TX Power is 50mW > > and under Wireless Packet Info: > > Transmitted (TX): a big number around 56..... OK, 334 errors. > > Is that normal? > > THX > of the router's signal range. Are you using any wireless security, WEP or WAP? Maybe someone or something is connecting from the edge of the Linksys' range. Quote: > > -- > ABH83 > ------------------------------------------------------------------------ > ABH83's Profile: http://forums.techarena.in/members/142317.htm > View this thread: > http://forums.techarena.in/windows-v...rk/1256179.htm > > http://forums.techarena.in > |
| Copying Files to External Drive | Vista file management | |||
| Copying files to a network drive + there is not enough space - noprompt to overwrite ? | Vista General | |||
| Importing/Copying Files from an External Drive | Vista file management | |||
| Copying files from XP to Vista via shared network drive | Vista security | |||
| Copying files to hard drive and error code 80070241 | Vista installation & setup | |||
