| | XP - Vista Networking problem I have a Desktop running XP - SP3 wired to a Linksys wireless router. My Vista laptop is wireless. I can connect to the Internet fine from either machine. I can see and access the laptop from the desktop but I can't see the desktop XP machine from the Vista laptop. I went through this same thing with my network up north but now that we've moved back to Florida I've got the same problem. McAfee network management shows both machines on the network but I can't access shared files and printers from the laptop. I know there are some settings I need to make to the Vista laptop but I can't remember what I did to get it working up north. Can anyone help? Thanks, Rick |
| | Re: XP - Vista Networking problem Have you enabled NetBIOS over TCP/IP? Also it could be 3rd party security software issue. For troubleshooting, try clean boot. Windows general How to run Windows OS with a clean boot · How to Run Windows Safe Mode with Networking · How to setup DHCP for IP Phone · How to setup and use Wake on LAN ... http://www.howtonetworking.com/Windo...owsgeneral.htm -- Bob Lin, Microsoft-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Rick Morrison" <rlmorrison@newsgroup> wrote in message news:avOdnZr6PJ8WbXXXnZ2dnUVZ_sydnZ2d@newsgroup Quote: >I have a Desktop running XP - SP3 wired to a Linksys wireless router. My >Vista laptop is wireless. I can connect to the Internet fine from either >machine. I can see and access the laptop from the desktop but I can't see >the desktop XP machine from the Vista laptop. I went through this same >thing with my network up north but now that we've moved back to Florida >I've got the same problem. McAfee network management shows both machines >on the network but I can't access shared files and printers from the >laptop. > > I know there are some settings I need to make to the Vista laptop but I > can't remember what I did to get it working up north. > > Can anyone help? > > Thanks, Rick > |
| | Re: XP - Vista Networking problem Thanks, I have the McAfee Firewall turned off on both computers with only the Windows firewall running. I can ping the Vista portable from the XP desktop (192.168.1.101) but I can't ping the desktop (192.168.1.100) from the Vista laptop. I'm pretty sure I have enabled NetBIOS over TCP/IP. I also tried disabling the SPI Firewall in the Linksys router but no help there either. Thanks, Rick "Bob Lin (MS-MVP)" <noreply@newsgroup> wrote in message news:BC8F0EE4-57AB-443C-AA22-3D4361116288@newsgroup Quote: > Have you enabled NetBIOS over TCP/IP? Also it could be 3rd party security > software issue. For troubleshooting, try clean boot. > Windows general > How to run Windows OS with a clean boot · How to Run Windows Safe > Mode with Networking · How to setup DHCP for IP Phone · How to setup and > use Wake on LAN ... > http://www.howtonetworking.com/Windo...owsgeneral.htm > > > -- > Bob Lin, Microsoft-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "Rick Morrison" <rlmorrison@newsgroup> wrote in message > news:avOdnZr6PJ8WbXXXnZ2dnUVZ_sydnZ2d@newsgroup Quote: >>I have a Desktop running XP - SP3 wired to a Linksys wireless router. My >>Vista laptop is wireless. I can connect to the Internet fine from either >>machine. I can see and access the laptop from the desktop but I can't see >>the desktop XP machine from the Vista laptop. I went through this same >>thing with my network up north but now that we've moved back to Florida >>I've got the same problem. McAfee network management shows both machines >>on the network but I can't access shared files and printers from the >>laptop. >> >> I know there are some settings I need to make to the Vista laptop but I >> can't remember what I did to get it working up north. >> >> Can anyone help? >> >> Thanks, Rick >> |
| | Re: XP - Vista Networking problem What happens when you search for the desktop from the laptop? You should be able to search for it with "\\machinename". Try temporarily turning off the XP firewall and make sure the McAfee firewall is really turned off--sometimes getting AV firewalls turned off can be problematic. Also, ensure you really aren't running any other security programs on the XP machine. XP should be the easier to see from Vista then the other way around, so something is not set up correctly on the XP machine. Also, make sure the workgroups are the same and that you have checked your networking assignments on both. If either is set for a manual IP and the range is wrong, things get go wrong. Dale On Oct 30, 7:44*am, "Rick Morrison" <rlmorri...@newsgroup> wrote: Quote: > Thanks, > > I have the McAfee Firewall turned off on both computers with only the > Windows firewall running. *I can ping the Vista portable from the XP desktop > (192.168.1.101) but I can't ping the desktop (192.168.1.100) from the Vista > laptop. *I'm pretty sure I have enabled NetBIOS over TCP/IP. *I also tried > disabling the SPI Firewall in the Linksys router but no help there either.. > > Thanks, > > Rick > > "Bob Lin (MS-MVP)" <nore...@newsgroup> wrote in messagenews:BC8F0EE4-57AB-443C-AA22-3D4361116288@newsgroup > Quote: > > Have you enabled NetBIOS over TCP/IP? Also it could be 3rd party security > > software issue. For troubleshooting, try clean boot. > > Windows general > > * * *How to run Windows OS with a clean boot · How to Run Windows Safe > > Mode with Networking · How to setup DHCP for IP Phone · How to setup and > > use Wake on LAN ... > > * * *http://www.howtonetworking.com/Windo...owsgeneral.htm Quote: > > -- > > Bob Lin, Microsoft-MVP, MCSE & CNE > > Networking, Internet, Routing, VPN Troubleshooting on > >http://www.ChicagoTech.net > > How to Setup Windows, Network, VPN & Remote Access on > >http://www.HowToNetworking.com Quote: > > "Rick Morrison" <rlmorri...@newsgroup> wrote in message > >news:avOdnZr6PJ8WbXXXnZ2dnUVZ_sydnZ2d@newsgroup Quote: > >>I have a Desktop running XP - SP3 wired to a Linksys wireless router. *My > >>Vista laptop is wireless. *I can connect to the Internet fine from either > >>machine. *I can see and access the laptop from the desktop but I can't see > >>the desktop XP machine from the Vista laptop. *I went through this same > >>thing with my network up north but now that we've moved back to Florida > >>I've got the same problem. *McAfee network management shows both machines > >>on the network but I can't access shared files and printers from the > >>laptop. Quote: Quote: > >> I know there are some settings I need to make to the Vista laptop but I > >> can't remember what I did to get it working up north. Quote: Quote: > >> Can anyone help? Quote: Quote: > >> Thanks, *Rick |
| | Re: XP - Vista Networking problem Does the problem persist if you replace the McAfee Firewall with the Windows Firewall? McAfee Consumer Product Removal Tool http://www.softpedia.com/get/Tweak/U...val-Tool.shtml "Rick Morrison" <rlmorrison@newsgroup> wrote in message news:iJadnVApXrvruHbXnZ2dnUVZ_rGdnZ2d@newsgroup Quote: > Got it! > > The problem was with the McAfee Firewall. For whatever reason when I > checked it always said Firewall service not running and I couldn't get in > to do anything with it. After running McAfee's Virtual Technician to > correct that problem I shut the McAfee Firewall down and can not access > the XP machine. > > Thanks again, > > Rick > > "daleeh" <dale.e.harrington@newsgroup> wrote in message > news:e95e36be-1ff5-455d-a635-753d49679bfe@newsgroup > What happens when you search for the desktop from the laptop? You > should be able to search for it with "\\machinename". > > Try temporarily turning off the XP firewall and make sure the McAfee > firewall is really turned off--sometimes getting AV firewalls turned > off can be problematic. > > Also, ensure you really aren't running any other security programs on > the XP machine. > > XP should be the easier to see from Vista then the other way around, > so something is not set up correctly on the XP machine. > > Also, make sure the workgroups are the same and that you have checked > your networking assignments on both. If either is set for a manual IP > and the range is wrong, things get go wrong. > > > Dale > > On Oct 30, 7:44 am, "Rick Morrison" <rlmorri...@newsgroup> wrote: Quote: >> Thanks, >> >> I have the McAfee Firewall turned off on both computers with only the >> Windows firewall running. I can ping the Vista portable from the XP >> desktop >> (192.168.1.101) but I can't ping the desktop (192.168.1.100) from the >> Vista >> laptop. I'm pretty sure I have enabled NetBIOS over TCP/IP. I also tried >> disabling the SPI Firewall in the Linksys router but no help there >> either. >> >> Thanks, >> >> Rick >> >> "Bob Lin (MS-MVP)" <nore...@newsgroup> wrote in >> messagenews:BC8F0EE4-57AB-443C-AA22-3D4361116288@newsgroup >> Quote: >> > Have you enabled NetBIOS over TCP/IP? Also it could be 3rd party >> > security >> > software issue. For troubleshooting, try clean boot. >> > Windows general >> > How to run Windows OS with a clean boot · How to Run Windows Safe >> > Mode with Networking · How to setup DHCP for IP Phone · How to setup >> > and >> > use Wake on LAN ... >> > http://www.howtonetworking.com/Windo...owsgeneral.htm Quote: >> > -- >> > Bob Lin, Microsoft-MVP, MCSE & CNE >> > Networking, Internet, Routing, VPN Troubleshooting on >> >http://www.ChicagoTech.net >> > How to Setup Windows, Network, VPN & Remote Access on >> >http://www.HowToNetworking.com Quote: >> > "Rick Morrison" <rlmorri...@newsgroup> wrote in message >> >news:avOdnZr6PJ8WbXXXnZ2dnUVZ_sydnZ2d@newsgroup >> >>I have a Desktop running XP - SP3 wired to a Linksys wireless router. >> >>My >> >>Vista laptop is wireless. I can connect to the Internet fine from >> >>either >> >>machine. I can see and access the laptop from the desktop but I can't >> >>see >> >>the desktop XP machine from the Vista laptop. I went through this same >> >>thing with my network up north but now that we've moved back to Florida >> >>I've got the same problem. McAfee network management shows both >> >>machines >> >>on the network but I can't access shared files and printers from the >> >>laptop. Quote: >> >> I know there are some settings I need to make to the Vista laptop but >> >> I >> >> can't remember what I did to get it working up north. Quote: >> >> Can anyone help? Quote: >> >> Thanks, Rick > |
| | #6 (permalink) |
| | Re: XP - Vista Networking problem No, I have the Windows Firewall running on both machines and everything works fine. "Bob" <bob@newsgroup> wrote in message news:OpfanEZWKHA.5208@newsgroup Quote: > Does the problem persist if you replace the McAfee Firewall with the > Windows Firewall? > > McAfee Consumer Product Removal Tool > http://www.softpedia.com/get/Tweak/U...val-Tool.shtml > > > "Rick Morrison" <rlmorrison@newsgroup> wrote in message > news:iJadnVApXrvruHbXnZ2dnUVZ_rGdnZ2d@newsgroup Quote: >> Got it! >> >> The problem was with the McAfee Firewall. For whatever reason when I >> checked it always said Firewall service not running and I couldn't get in >> to do anything with it. After running McAfee's Virtual Technician to >> correct that problem I shut the McAfee Firewall down and can not access >> the XP machine. >> >> Thanks again, >> >> Rick >> >> "daleeh" <dale.e.harrington@newsgroup> wrote in message >> news:e95e36be-1ff5-455d-a635-753d49679bfe@newsgroup >> What happens when you search for the desktop from the laptop? You >> should be able to search for it with "\\machinename". >> >> Try temporarily turning off the XP firewall and make sure the McAfee >> firewall is really turned off--sometimes getting AV firewalls turned >> off can be problematic. >> >> Also, ensure you really aren't running any other security programs on >> the XP machine. >> >> XP should be the easier to see from Vista then the other way around, >> so something is not set up correctly on the XP machine. >> >> Also, make sure the workgroups are the same and that you have checked >> your networking assignments on both. If either is set for a manual IP >> and the range is wrong, things get go wrong. >> >> >> Dale >> >> On Oct 30, 7:44 am, "Rick Morrison" <rlmorri...@newsgroup> wrote: Quote: >>> Thanks, >>> >>> I have the McAfee Firewall turned off on both computers with only the >>> Windows firewall running. I can ping the Vista portable from the XP >>> desktop >>> (192.168.1.101) but I can't ping the desktop (192.168.1.100) from the >>> Vista >>> laptop. I'm pretty sure I have enabled NetBIOS over TCP/IP. I also tried >>> disabling the SPI Firewall in the Linksys router but no help there >>> either. >>> >>> Thanks, >>> >>> Rick >>> >>> "Bob Lin (MS-MVP)" <nore...@newsgroup> wrote in >>> messagenews:BC8F0EE4-57AB-443C-AA22-3D4361116288@newsgroup >>> >>> > Have you enabled NetBIOS over TCP/IP? Also it could be 3rd party >>> > security >>> > software issue. For troubleshooting, try clean boot. >>> > Windows general >>> > How to run Windows OS with a clean boot · How to Run Windows Safe >>> > Mode with Networking · How to setup DHCP for IP Phone · How to setup >>> > and >>> > use Wake on LAN ... >>> > http://www.howtonetworking.com/Windo...owsgeneral.htm >>> >>> > -- >>> > Bob Lin, Microsoft-MVP, MCSE & CNE >>> > Networking, Internet, Routing, VPN Troubleshooting on >>> >http://www.ChicagoTech.net >>> > How to Setup Windows, Network, VPN & Remote Access on >>> >http://www.HowToNetworking.com >>> >>> > "Rick Morrison" <rlmorri...@newsgroup> wrote in message >>> >news:avOdnZr6PJ8WbXXXnZ2dnUVZ_sydnZ2d@newsgroup >>> >>I have a Desktop running XP - SP3 wired to a Linksys wireless router. >>> >>My >>> >>Vista laptop is wireless. I can connect to the Internet fine from >>> >>either >>> >>machine. I can see and access the laptop from the desktop but I can't >>> >>see >>> >>the desktop XP machine from the Vista laptop. I went through this same >>> >>thing with my network up north but now that we've moved back to >>> >>Florida >>> >>I've got the same problem. McAfee network management shows both >>> >>machines >>> >>on the network but I can't access shared files and printers from the >>> >>laptop. >>> >>> >> I know there are some settings I need to make to the Vista laptop but >>> >> I >>> >> can't remember what I did to get it working up north. >>> >>> >> Can anyone help? >>> >>> >> Thanks, Rick >> |
| Vista SP1 & XP Pro - Networking Problem | Vista networking & sharing | |||
| Vista to XP networking problem | Vista networking & sharing | |||
| Different Vista XP networking problem | Vista networking & sharing | |||
| Vista/XP LAN networking problem | Vista networking & sharing | |||
| XP/Vista networking problem | Vista networking & sharing | |||
