How to prevent from automatically connecting to "default" wireless network and only with specified ones?
  1. #1
    AI Guest
    I'm running Vista Home edition on my laptop and when I use my laptop
    at home, it keeps on connecting to an unsecured default wireless
    network, instead of connecting to my home network, which is named and
    is secured. I guess one of my neighbours decided to just run their
    wireless network like that.
    How can I prevent my laptop from connecting to other networks other
    than the ones I specify? I've looked in the settings and options in
    the wireless connection management utility in Vista and couldn't find
    a way to do that. Perhaps i didn't look hard enough, but would
    appreciate it if someone could provide a solution to this issue.
    Thank you very much for your time and courtesy.
  2. #2
    AI Guest
    Re: How to prevent from automatically connecting to "default" wireless network and only with specified ones?
    Oh, I don't think I've tried that yet. Great, thanks for your reply!
    On Sat, 20 Feb 2010 17:29:12 -0500, "Bob" <bob@newsgroup> wrote:
    >Right click the network(s) you don't want>>select Properties>>Connection
    >tab>>Uncheck Connect when this network is in range.
    >"AI" <android@newsgroup> wrote in message
    >news:kh7un5tnp1t4cmghe7ul87ifhl6v6eog40@newsgroup
  3. #3
    digz Guest
    check out your settings in 'network & sharing centre' > manage wireless
    networks
    find your network (possible delete all except yours?), check the wireless
    properties. I have mine set to 'connect automatically when in range'
    you could try unchecking the option about connecting to preferred network if
    available
How to prevent from automatically connecting to "default" wireless network and only with specified ones? problems?
Plug a cable into network adapter "local area connection" or get ip automatically? nitins11 Network & Sharing 0 31 Jan 2010
How do I keep wireless network from automatically connecting? ggull Vista General 0 20 Oct 2008
How to change default "connect to" from all to wireless? lllusion Vista General 2 17 Jun 2008
PPTP VPN connections fail if "Use default gateway on remote network" is set. Carl Farrington Vista networking & sharing 3 25 Jan 2008
Automatically "Automatically get new IP settings for the network adapter" Hexaphim Vista networking & sharing 0 03 Aug 2007
