Vista - DNS problem
Old 12-04-2006   #1 (permalink)
Jurek W
DNS problem
I have a small problem with DNS.
Everything works great and sometimes suddenly everything what needs DNS
response stops working. It is the latest build, Windows Update on,
everything is up and activated. Firewall is disabled. The Internet works
fine but as i said after some time several hours or days (I have this
windows for quite a short time, so it happend only about 3 or 4 times but it
is definitely a Vista bug as it never happened before) it still works but
when some app need an IP address from a host it does not get the DNS
response with the IP. Does anybody know how to fix it?
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
