Vista - Remote Desktop: Keys Ctrl, Alt, Shift do not function
Old 12-15-2006   #1 (permalink)
Sander G
I am using RDP from a laptop with Vista Home Premium to XP Pro SP2. Both
are US English versions with regional settings to Dutch and the US
International keyboard layout.
Locally on the laptop everything works fine. However when connecting to the
XP box (in full screen mode), the Ctrl, Alt and Shift keys are not
functioning. The same applies to selecting text with the mouse. The impact
is that capitals can only be typed with Caps Lock, and characters like
brackets, double quotes etc. cannot be typed at all.
The computers are on the same subnet, with only a switch in between -
nothing fancy.
If you have seen this before or think of a solution, please let me know -
it's not really workable in this way ;-)
Thanks,
Sander
Old 12-15-2006   #2 (permalink)
David Wright
Re: Remote Desktop: Keys Ctrl, Alt, Shift do not function
In the Remote Desktop Options, under the "Local Resources" tab, what do you
have selected in "Keyboard"?
Old 12-16-2006   #3 (permalink)
Sander G
"David Wright" <d_wright@hotpop.com> wrote in
news:ecjBT0JIHHA.1240@TK2MSFTNGP03.phx.gbl:
> do you have selected in "Keyboard"?
'in full screen mode only', but 'on the remote computer' does not make any
difference.
Selecting text with the mouse also does not work, perhaps this is sent as a
shift-arrow combination...
Thanks,
Sander
Old 12-16-2006   #4 (permalink)
Sander G
Sander G <news@sander.goudswaard.verwijderdit.cx> wrote in
news:Xns989B488E786487574505Bjvrqvgyrrfgv@194.109.133.242:
> as a shift-arrow combination...
But, copying mstsc.exe and mstscax.dll from the XP box and launching it on
the Vista box resolves the problem :-?
Weird, very weird.
Sander
Old 12-16-2006   #5 (permalink)
David Wright
What version of Remote Desktop are you using on the XP Pro machine? There
was an updated version released on 11/28/06. I'd suggest reverting those
files on Vista back to the originals and try the update.
Link:
http://www.microsoft.com/downloads/d...displaylang=en
KB925876: http://support.microsoft.com/?kbid=925876
Old 12-16-2006   #6 (permalink)
Sander G
news:ONpPmNPIHHA.3780@TK2MSFTNGP02.phx.gbl:
> There was an updated version released on 11/28/06. I'd suggest
> reverting those files on Vista back to the originals and try the
> update.
The update is client only. The XP machine is the host, so applying a client
update there should not make any difference.
Regards,
Sander
Remote desktop does not sent ctrl+alt+left or ctrl+alt+right Network & Sharing
Lost Shift/Ctrl/drag'n'drop functions in Remote Desktop Session Vista General
keys & SHIFT keys not working properly in Vista Home Premium Vista General
Ctrl Alt Shift keys display? Vista General
Ctrl-Alt-Delete / Ctrl-Shift-Esc--------Task Manager Vista General
