Vista - VISTA Wireless Connection IP Resolve Problems
Old 02-03-2007   #1 (permalink)
IDBUGM
I have a SONICWALL TZ150 and I bought me a couple new DELL VISTA
Computers. I called Linksys, Dell, and Sonicwall.
When VISTA WLAN tries to connect to the SONICWALL it bounces back for
IP SPOOF error. Vista is not changing it's IP range to fit within my
network. Thus, I can't resolve an address back to my box.
Simple enough problem I thought.
I went in and set a Static IP to my network range. When I check
IPCONFIG i get an internal IPv4 Address, Jacked up Subnet and my
Default Gateway. I can't get VISTA to use the IP I told it to use.
Because of these issues I can't get the system to sync with my
SonicWall using WLAN.
The LAN works fine. I resolve and connect, all without any problems.
Any Suggestions?
IDBUGM
Old 12-29-2007   #2 (permalink)
Vista Home Basic
Re: VISTA Wireless Connection IP Resolve Problems
I had the same problem (IP address already in use on the network - DHCP or static IPs made no difference - same error either way) with a SonicWall TZ 150 Wireless Standard router running Sonic OS Standard 3.1.3.0-6s firmware trying to connect a Toshiba laptop with Vista Home Basic. An IBM T-42 Laptop with Windows XP SP2 connected instantly as does every other PC in the house. I had seen a post recommending a firmware upgrade. We went to SonicWall's web site and after logging in to our existing support account (yes, you have to have your SonicWall registered to receive support!) we downloaded the firmware at version 3.1.5.0-2s and applied it. It took several minutes to upload the firmware to the router. Downloading and reading the release notes is key to getting the procedure to work. Make a backup of your current configuration first as recommended!
After rebooting the SonicWall router, everything came up and the Vista based laptop connected right away with no more errors. Thanks to the person who made this suggestion in another post (couldn't find that post again..)
Old 12-29-2007   #3 (permalink)
Robert L. \(MS-MVP\)
Thank you for sharing your experience with us.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"CurtSzal" <CurtSzal.32dky4@xxxxxx-mx.forums.net> wrote in message
news:CurtSzal.32dky4@xxxxxx-mx.forums.net...
> again..)
> CurtSzal
using windows mail live to resolve connection problems with HTTP sites Vista mail
Vista 64 SP1 Wireless Connection Problems Vista networking & sharing
ethernet problems in Windows Vista with wireless connection Vista General
Vista Wireless Connection Problems Vista networking & sharing
XP vs Vista wireless connection problems Vista networking & sharing
