Vista 64 will not accept additional drivers when setting up a network
printer. On my laptop I can install it using "local printer" but when I try
and install using "network printer" I get message not suitable driver. The
driver worked w/ XP32pro before I got Vista, now it does not work at all. I
check the box "x86" (for 32 bit, right?) and nothing.
Thanks
