Re: Need help with Remote Desktop / Vista...
  1. #1
    Kerry Brown Guest
    It sounds like your router is blocking rdp. This is normal. You have to
    forward port 3389 from your router to the office computer. Here's some
    links. They are about XP but the setup is very close with Vista. The
    principles are the same.
    http://theillustratednetwork.mvps.or...eshooting.html
    http://ask-leo.com/how_can_i_connect...from_work.html
    Kerry Brown
    Microsoft MVP - Shell/User
    http://www.vistahelp.ca
    "frankmcma" <frank@fmstudio.com> wrote in message
    news:eZdxVhYSHHA.5012@TK2MSFTNGP04.phx.gbl...
    > On my office machine I have Windows Vista Ultimate, on my laptop I have
    > Windows XP Home (on the laptop I have downloaded the most recent Desktop
    > Connection Program)
    > If I am within my wireless network, i can input my computer and password
    > into my laptop and remote desktop works great on my laptop, Vista screen
    > pops right up on my laptop. However when I am at a coffee shop and try to
    > dial in to my office computer, it does not work. I tried computer name, my
    > computers IP address, etc...nothing worked.
    > Any ideas? I want to log in remotely to vista at my office from my XP
    > laptop. Any settings I am missing?
    > Thanks!
    > Frank
  2. #2
    frankmcma Guest
    Lots of good info and I found a site on there:
    http://www.portforward.com/default.htm Which has one solution which involves
    about 25 steps and creating a static IP and etc..etc...
    I have to say..if I am a business user who just purchased Windows Vista and
    wants to use Remote Desktop..should I need to be an IT guy and spend time
    researching info on this and reprogramming my system(s) for a half hour?
    Honestly...I thought it would be a bit easier than this. It worked fine with
    XP Pro
    Any other solutions out there?
    Frank
    "Kerry Brown" <kerry@kdbNOSPAMsys-tems.c*a*m> wrote in message
    news:emrjcpZSHHA.996@TK2MSFTNGP02.phx.gbl...
    > Kerry Brown
    >> Connection Program)
    >> my computers IP address, etc...nothing worked.
    >> Thanks!
    >> Frank
Re: Need help with Remote Desktop / Vista... problems?
Remote desktop can not find remote computer bitterpill Network & Sharing 5 26 Mar 2009
Can't login to remote comp. using Remote Desktop Connection on Vis Luigi_1996 Vista account administration 0 13 Dec 2007
Is there a program to use remote desktop, or remote assistance "host" on Vista Home? Tim Vista General 5 14 Aug 2007
Remote Desktop problem with remote printers neworders@gmail.com Vista networking & sharing 0 11 Feb 2007
Remote Desktop - Able to have one user logged in locally and one user via remote desktop? Paul Murdock Vista networking & sharing 3 20 Oct 2006
