| | internet connection problems OK perhaps someone can help me with this. when at home on a comcast cable connection connected through a link sys router everything works great. but now that i am at school all is not so great. at first i thought it was because i was behind a netgear router but i am using it as a switch. now some webpages load but some do not or in some cases if the address is forwarded it will not work. all this worked under windows xp but now does not under vista also i used outlook under xp and was able to get my outside mail which is setup with pop access, but now under vista it will not connect. other programs have the same problem not connected such as my avg virus software and windows media center, can't connect for guide setup. so if someone could please enlighten me i would appreciate it, i thought it was ipv6 but i disabled that and still have the problem. i am confused. an example is if i want to go to espn.com i simply can't type that, i have to type espn.go.com. i have a xp laptop on the same network here at school and it works perfect, just flaws with vista. |
| | Re: internet connection problems check your firewall settings my linksys router is in compable with vista might have simular problems "bova80" <bova80@discussions.microsoft.com> wrote in message news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... > OK perhaps someone can help me with this. when at home on a comcast > cable > connection connected through a link sys router everything works great. > but > now that i am at school all is not so great. at first i thought it was > because i was behind a netgear router but i am using it as a switch. now > some webpages load but some do not or in some cases if the address is > forwarded it will not work. all this worked under windows xp but now does > not under vista > > also i used outlook under xp and was able to get my outside mail which is > setup with pop access, but now under vista it will not connect. other > programs have the same problem not connected such as my avg virus software > and windows media center, can't connect for guide setup. so if someone > could > please enlighten me i would appreciate it, i thought it was ipv6 but i > disabled that and still have the problem. i am confused. an example is > if i > want to go to espn.com i simply can't type that, i have to type > espn.go.com. > i have a xp laptop on the same network here at school and it works > perfect, > just flaws with vista. |
| | Re: internet connection problems checked the firewall, even disabled it and the vista firewall and still having the same problem. its just odd that everything works fine on xp but not on vista with the same exact settings. so its something in vista. "Jeff_giampetro@hotmail.com" wrote: > check your firewall settings my linksys router is in compable with vista > might have simular problems > > "bova80" <bova80@discussions.microsoft.com> wrote in message > news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... > > OK perhaps someone can help me with this. when at home on a comcast > > cable > > connection connected through a link sys router everything works great. > > but > > now that i am at school all is not so great. at first i thought it was > > because i was behind a netgear router but i am using it as a switch. now > > some webpages load but some do not or in some cases if the address is > > forwarded it will not work. all this worked under windows xp but now does > > not under vista > > > > also i used outlook under xp and was able to get my outside mail which is > > setup with pop access, but now under vista it will not connect. other > > programs have the same problem not connected such as my avg virus software > > and windows media center, can't connect for guide setup. so if someone > > could > > please enlighten me i would appreciate it, i thought it was ipv6 but i > > disabled that and still have the problem. i am confused. an example is > > if i > > want to go to espn.com i simply can't type that, i have to type > > espn.go.com. > > i have a xp laptop on the same network here at school and it works > > perfect, > > just flaws with vista. > > |
| | Re: internet connection problems Do you have correct TCP/IP settings? Can you ping a public IP? Posting the result of ipconfig /all may help. Or check this step by step troubleshooting, How to troubleshoot internet access issuesNone of the networking computers can access the Internet. ... Related Topics. Can’t access the Internet via USB after enabling NIC for network ... http://www.howtonetworking.com/Inter...netaccess0.htm Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "bova80" <bova80@discussions.microsoft.com> wrote in message news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... OK perhaps someone can help me with this. when at home on a comcast cable connection connected through a link sys router everything works great. but now that i am at school all is not so great. at first i thought it was because i was behind a netgear router but i am using it as a switch. now some webpages load but some do not or in some cases if the address is forwarded it will not work. all this worked under windows xp but now does not under vista also i used outlook under xp and was able to get my outside mail which is setup with pop access, but now under vista it will not connect. other programs have the same problem not connected such as my avg virus software and windows media center, can't connect for guide setup. so if someone could please enlighten me i would appreciate it, i thought it was ipv6 but i disabled that and still have the problem. i am confused. an example is if i want to go to espn.com i simply can't type that, i have to type espn.go.com. i have a xp laptop on the same network here at school and it works perfect, just flaws with vista. |
| | Re: internet connection problems yeah most websites work. i can even ping the ones that don't work and they will reply. "Robert L [MVP - Networking]" wrote: > Do you have correct TCP/IP settings? Can you ping a public IP? Posting the result of ipconfig /all may help. Or check this step by step troubleshooting, > > How to troubleshoot internet access issuesNone of the networking computers can access the Internet. ... Related Topics. Can’t access the Internet via USB after enabling NIC for network ... > http://www.howtonetworking.com/Inter...netaccess0.htm > > > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com > "bova80" <bova80@discussions.microsoft.com> wrote in message news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... > OK perhaps someone can help me with this. when at home on a comcast cable > connection connected through a link sys router everything works great. but > now that i am at school all is not so great. at first i thought it was > because i was behind a netgear router but i am using it as a switch. now > some webpages load but some do not or in some cases if the address is > forwarded it will not work. all this worked under windows xp but now does > not under vista > > also i used outlook under xp and was able to get my outside mail which is > setup with pop access, but now under vista it will not connect. other > programs have the same problem not connected such as my avg virus software > and windows media center, can't connect for guide setup. so if someone could > please enlighten me i would appreciate it, i thought it was ipv6 but i > disabled that and still have the problem. i am confused. an example is if i > want to go to espn.com i simply can't type that, i have to type espn.go.com. > i have a xp laptop on the same network here at school and it works perfect, > just flaws with vista |
| | #6 (permalink) |
| | Re: internet connection problems well i finally found a solution that worked. you have to go into start menu, programs, accessories, right click command prompt and run as administrator and then type this command netsh interface tcp set global autotuninglevel=disabled and it fixed all my problems without a restart. "bova80" wrote: > yeah most websites work. i can even ping the ones that don't work and they > will reply. > > "Robert L [MVP - Networking]" wrote: > > > Do you have correct TCP/IP settings? Can you ping a public IP? Posting the result of ipconfig /all may help. Or check this step by step troubleshooting, > > > > How to troubleshoot internet access issuesNone of the networking computers can access the Internet. ... Related Topics. Can’t access the Internet via USB after enabling NIC for network ... > > http://www.howtonetworking.com/Inter...netaccess0.htm > > > > > > Bob Lin, MS-MVP, MCSE & CNE > > Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net > > How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com > > "bova80" <bova80@discussions.microsoft.com> wrote in message news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... > > OK perhaps someone can help me with this. when at home on a comcast cable > > connection connected through a link sys router everything works great. but > > now that i am at school all is not so great. at first i thought it was > > because i was behind a netgear router but i am using it as a switch. now > > some webpages load but some do not or in some cases if the address is > > forwarded it will not work. all this worked under windows xp but now does > > not under vista > > > > also i used outlook under xp and was able to get my outside mail which is > > setup with pop access, but now under vista it will not connect. other > > programs have the same problem not connected such as my avg virus software > > and windows media center, can't connect for guide setup. so if someone could > > please enlighten me i would appreciate it, i thought it was ipv6 but i > > disabled that and still have the problem. i am confused. an example is if i > > want to go to espn.com i simply can't type that, i have to type espn.go.com. > > i have a xp laptop on the same network here at school and it works perfect, > > just flaws with vista |
| | #7 (permalink) |
| | Re: internet connection problems Thanks very much bova80....this also solved my problems on two Vista Ultimate machines! If you Google the command, you'll find information about what it is, what it's supposed to do as well as the command to enable it should the disable command not work. Microsoft calls it, "Receive Window Auto-Tuning". The command to enable it is: netsh interface tcp set global autotuninglevel=normal To view the states of the TCP global parameters, you can use this command: netsh interface tcp show global Hope this helps others as much as it helped me! Bill "bova80" <bova80@discussions.microsoft.com> wrote in message news:FD6C67D9-0806-4EA4-8D39-199446DC7EAC@microsoft.com... > well i finally found a solution that worked. you have to go into start > menu, > programs, accessories, right click command prompt and run as administrator > and then type this command > > netsh interface tcp set global autotuninglevel=disabled > > and it fixed all my problems without a restart. > > "bova80" wrote: > >> yeah most websites work. i can even ping the ones that don't work and >> they >> will reply. >> >> "Robert L [MVP - Networking]" wrote: >> >> > Do you have correct TCP/IP settings? Can you ping a public IP? Posting >> > the result of ipconfig /all may help. Or check this step by step >> > troubleshooting, >> > >> > How to troubleshoot internet access issuesNone of the networking >> > computers can access the Internet. ... Related Topics. Can’t access the >> > Internet via USB after enabling NIC for network ... >> > http://www.howtonetworking.com/Inter...netaccess0.htm >> > >> > >> > Bob Lin, MS-MVP, MCSE & CNE >> > Networking, Internet, Routing, VPN Troubleshooting on >> > http://www.ChicagoTech.net >> > How to Setup Windows, Network, VPN & Remote Access on >> > http://www.HowToNetworking.com >> > "bova80" <bova80@discussions.microsoft.com> wrote in message >> > news:61AF810C-7F90-4CE6-8F49-A96630FE47A4@microsoft.com... >> > OK perhaps someone can help me with this. when at home on a comcast >> > cable >> > connection connected through a link sys router everything works >> > great. but >> > now that i am at school all is not so great. at first i thought it >> > was >> > because i was behind a netgear router but i am using it as a switch. >> > now >> > some webpages load but some do not or in some cases if the address is >> > forwarded it will not work. all this worked under windows xp but now >> > does >> > not under vista >> > >> > also i used outlook under xp and was able to get my outside mail >> > which is >> > setup with pop access, but now under vista it will not connect. >> > other >> > programs have the same problem not connected such as my avg virus >> > software >> > and windows media center, can't connect for guide setup. so if >> > someone could >> > please enlighten me i would appreciate it, i thought it was ipv6 but >> > i >> > disabled that and still have the problem. i am confused. an example >> > is if i >> > want to go to espn.com i simply can't type that, i have to type >> > espn.go.com. >> > i have a xp laptop on the same network here at school and it works >> > perfect, >> > just flaws with vista |
| internet connection problems | Browsers & Mail | |||
| internet connection problems | Network & Sharing | |||
| Internet connection problems | Vista networking & sharing | |||
| Re: internet connection problems | Vista networking & sharing | |||
