| | connection problem after reboot This problem is for Vista only. Some people have problem on Internet connection after reboot, and so do I, but I have tried many solutions suggested in these posts. The general situation of this problem is like this: After boot, reboot, sleep, or any kind of restart, you found yourself need to do the diagnose & repair to get connection back. There are a few suggested soluions: 1. disable the IPv6 from the property page of the NIC 2. check to see if your NIC driver is selected to power down for power saving in the driver page 3. add another NIC to your computer and I have found the solution for my computer: 4. disable the "routing and remote access " service I found it out as i discover i have a brief moment of connection to web pages and then lost it after all service loaded, so i tried to disable them one by one, reboot,try to go online, repeat again. and figure out this service is responsible for my problem. Now i would like some explain of what this service does exactly, and how it cause the problem? Why it does not cause problem for my XP on same computer but Vista only? |
| Every-time I ReBoot I lose my Internet Connection | Network & Sharing | |||
| sp2 reboot problem | Windows Updates | |||
| Reboot a Remote Desktop connection in Windows Virtual PC | Virtual PC | |||
| Network connection properites do not persist across a reboot. | Vista networking & sharing | |||
| Reboot problem | Vista General | |||
