| | Vista - Internet connection problems |
| 02-22-2007 | #1 |
| | Internet connection problems I'm having some major issues with Vista 64 and internet connection problems. Everything will work fine, then all of a sudden I cannot connect to the internet. Comes up saying that the DNS is not found, and to contact my ISP. I am using a speedstream 6520 router/modem, and I can connect to the modem fine, it says I'm connected to the internet, yet I cannot sign into messenger, or view any webpages. I can mess around for an hour trying to get it to work, then all of a sudden, I am able to connect again. My ISP has checked the lines and everything is good. I've never had an internet connection problem with XP. Any suggestions? I have all my drivers up to date, and have very new and trusted hardware installed. Specs: DFI Lanparty UT nforce 4 board (newest drivers installed) 8800 GTS Opteron 165 Speedstream 6520 modem/router (Bell sympatico) Vista Home Premium 64 bit |
| My System Specs |
| 02-22-2007 | #2 |
| | Re: Internet connection problems This is very similar to what I am facing. Internet works, but intermittently say 30 min or an hour, it would just go down. I am using Motorolla cable modem and vista business. Can you check your windows event logs (system logs). Is there a log like dhcp-client started everytime connection drops? I notice that everytime although there is evidence of that service crashing otherwise. "Tech4808" <Tech4808@discussions.microsoft.com> wrote in message news:800221A8-41CA-4356-A440-2FAE3433148C@microsoft.com... > I'm having some major issues with Vista 64 and internet connection > problems. > > Everything will work fine, then all of a sudden I cannot connect to the > internet. Comes up saying that the DNS is not found, and to contact my > ISP. > I am using a speedstream 6520 router/modem, and I can connect to the modem > fine, it says I'm connected to the internet, yet I cannot sign into > messenger, or view any webpages. > > I can mess around for an hour trying to get it to work, then all of a > sudden, I am able to connect again. My ISP has checked the lines and > everything is good. I've never had an internet connection problem with > XP. > > Any suggestions? I have all my drivers up to date, and have very new and > trusted hardware installed. > > Specs: > > DFI Lanparty UT nforce 4 board (newest drivers installed) > 8800 GTS > Opteron 165 > Speedstream 6520 modem/router (Bell sympatico) > Vista Home Premium 64 bit |
| My System Specs |
| 02-22-2007 | #3 |
| | Re: Internet connection problems There are incompatabilities with Vista and some of the built-in DHCP servers in routers. As a result, kiss off automatic assignment of network settings for these routers (wireless or otherwise). You will have to MANUALLY set your IP info, just like in the old days. Unfortunately, that also means that you will have to CAN those adapter IP setting when using true DHCP enabled routers that actually work. When you run into this, I've found that the alternate IP info does not work at all, it never gets referenced or determined. Here is one solution that may work for SOME routers (but it does NOT work for all of them!) http://support.microsoft.com/kb/928233/en-us The reality is that as long as you can connect to the router (i.e. local only connection) then the manual assignment of the IP info should get you there. And forget about wasting your time trying to use the Alternate configuration, it doesn't work. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ "noorix" wrote: > This is very similar to what I am facing. > Internet works, but intermittently say 30 min or an hour, it would just go > down. I am using Motorolla cable modem and vista business. > > Can you check your windows event logs (system logs). Is there a log like > dhcp-client started everytime connection drops? > I notice that everytime although there is evidence of that service crashing > otherwise. > > > > "Tech4808" <Tech4808@discussions.microsoft.com> wrote in message > news:800221A8-41CA-4356-A440-2FAE3433148C@microsoft.com... > > I'm having some major issues with Vista 64 and internet connection > > problems. > > > > Everything will work fine, then all of a sudden I cannot connect to the > > internet. Comes up saying that the DNS is not found, and to contact my > > ISP. > > I am using a speedstream 6520 router/modem, and I can connect to the modem > > fine, it says I'm connected to the internet, yet I cannot sign into > > messenger, or view any webpages. > > > > I can mess around for an hour trying to get it to work, then all of a > > sudden, I am able to connect again. My ISP has checked the lines and > > everything is good. I've never had an internet connection problem with > > XP. > > > > Any suggestions? I have all my drivers up to date, and have very new and > > trusted hardware installed. > > > > Specs: > > > > DFI Lanparty UT nforce 4 board (newest drivers installed) > > 8800 GTS > > Opteron 165 > > Speedstream 6520 modem/router (Bell sympatico) > > Vista Home Premium 64 bit > > > |
| My System Specs |
| 02-22-2007 | #4 |
| | Re: Internet connection problems I dont see really anything for the DHCP... just a lot of errors about stuff trying to access the net, but cant. It gets really frustrating cause I'll be doing my normal thing on the net, and it will just quit.... and no telling on when it comes back up. "noorix" wrote: > This is very similar to what I am facing. > Internet works, but intermittently say 30 min or an hour, it would just go > down. I am using Motorolla cable modem and vista business. > > Can you check your windows event logs (system logs). Is there a log like > dhcp-client started everytime connection drops? > I notice that everytime although there is evidence of that service crashing > otherwise. > > > > "Tech4808" <Tech4808@discussions.microsoft.com> wrote in message > news:800221A8-41CA-4356-A440-2FAE3433148C@microsoft.com... > > I'm having some major issues with Vista 64 and internet connection > > problems. > > > > Everything will work fine, then all of a sudden I cannot connect to the > > internet. Comes up saying that the DNS is not found, and to contact my > > ISP. > > I am using a speedstream 6520 router/modem, and I can connect to the modem > > fine, it says I'm connected to the internet, yet I cannot sign into > > messenger, or view any webpages. > > > > I can mess around for an hour trying to get it to work, then all of a > > sudden, I am able to connect again. My ISP has checked the lines and > > everything is good. I've never had an internet connection problem with > > XP. > > > > Any suggestions? I have all my drivers up to date, and have very new and > > trusted hardware installed. > > > > Specs: > > > > DFI Lanparty UT nforce 4 board (newest drivers installed) > > 8800 GTS > > Opteron 165 > > Speedstream 6520 modem/router (Bell sympatico) > > Vista Home Premium 64 bit > > > |
| My System Specs |
| 02-26-2007 | #5 |
| | Re: Internet connection problems On 22 Feb, 17:30, Tech4808 <Tech4...@discussions.microsoft.com> wrote: > I dont see really anything for the DHCP... just a lot of errors about stuff > trying to access the net, but cant. It gets really frustrating cause I'll be > doing my normal thing on the net, and it will just quit.... and no telling on > when it comes back up. > > "noorix" wrote: > > This is very similar to what I am facing. > > Internet works, but intermittently say 30 min or an hour, it would just go > > down. I am using Motorolla cable modem and vista business. > > > Can you check your windows event logs (system logs). Is there a log like > > dhcp-client started everytime connection drops? > > I notice that everytime although there is evidence of that service crashing > > otherwise. > > > "Tech4808" <Tech4...@discussions.microsoft.com> wrote in message > >news:800221A8-41CA-4356-A440-2FAE3433148C@microsoft.com... > > > I'm having some major issues with Vista 64 and internet connection > > > problems. > > > > Everything will work fine, then all of a sudden I cannot connect to the > > > internet. Comes up saying that the DNS is not found, and to contact my > > > ISP. > > > I am using a speedstream 6520 router/modem, and I can connect to the modem > > > fine, it says I'm connected to the internet, yet I cannot sign into > > > messenger, or view any webpages. > > > > I can mess around for an hour trying to get it to work, then all of a > > > sudden, I am able to connect again. My ISP has checked the lines and > > > everything is good. I've never had an internet connection problem with > > > XP. > > > > Any suggestions? I have all my drivers up to date, and have very new and > > > trusted hardware installed. > > > > Specs: > > > > DFI Lanparty UT nforce 4 board (newest drivers installed) > > > 8800 GTS > > > Opteron 165 > > > Speedstream 6520 modem/router (Bell sympatico) > > > Vista Home Premium 64 bit http://groups.google.co.uk/group/mic...03f284489f27c2 |
| My System Specs |
| 02-26-2007 | #6 |
| | Re: Internet connection problems Thanks for the link, but I'm not trying to do a wireless connection. I have tried manually imputting my IP addresses, and turned off DHCP on the router and in windows, yet the internet connection still drops while surfing the net. My router/modem says I'm connected, but every webpage comes back as not found. The only way I can get it to work again is by shutting off my comp and router and restarting both. "gg@timehaven.org" wrote: > On 22 Feb, 17:30, Tech4808 <Tech4...@discussions.microsoft.com> wrote: > > I dont see really anything for the DHCP... just a lot of errors about stuff > > trying to access the net, but cant. It gets really frustrating cause I'll be > > doing my normal thing on the net, and it will just quit.... and no telling on > > when it comes back up. > > > > "noorix" wrote: > > > This is very similar to what I am facing. > > > Internet works, but intermittently say 30 min or an hour, it would just go > > > down. I am using Motorolla cable modem and vista business. > > > > > Can you check your windows event logs (system logs). Is there a log like > > > dhcp-client started everytime connection drops? > > > I notice that everytime although there is evidence of that service crashing > > > otherwise. > > > > > "Tech4808" <Tech4...@discussions.microsoft.com> wrote in message > > >news:800221A8-41CA-4356-A440-2FAE3433148C@microsoft.com... > > > > I'm having some major issues with Vista 64 and internet connection > > > > problems. > > > > > > Everything will work fine, then all of a sudden I cannot connect to the > > > > internet. Comes up saying that the DNS is not found, and to contact my > > > > ISP. > > > > I am using a speedstream 6520 router/modem, and I can connect to the modem > > > > fine, it says I'm connected to the internet, yet I cannot sign into > > > > messenger, or view any webpages. > > > > > > I can mess around for an hour trying to get it to work, then all of a > > > > sudden, I am able to connect again. My ISP has checked the lines and > > > > everything is good. I've never had an internet connection problem with > > > > XP. > > > > > > Any suggestions? I have all my drivers up to date, and have very new and > > > > trusted hardware installed. > > > > > > Specs: > > > > > > DFI Lanparty UT nforce 4 board (newest drivers installed) > > > > 8800 GTS > > > > Opteron 165 > > > > Speedstream 6520 modem/router (Bell sympatico) > > > > Vista Home Premium 64 bit > > > http://groups.google.co.uk/group/mic...03f284489f27c2 > > |
| My System Specs |
| 03-03-2007 | #7 |
| | RE: Internet connection problems I have had a similar problem happen to me. My router will hang/lock when the MS Vista installed PC is switched on. Only after switching the router off and on again, the router will function normally again until the MS Vista PC is restarted again. Does this problem occur due to the newly implemented IPv6 protocol? Also it is impossible in my Vista to disable IPv6 even tho it is almost nothing that use it. So it is impossible for me to test manually. An option is of course to buy a new router, but it would be interesting to know why this happens. Buying a new one might not help. "Tech4808" wrote: > I'm having some major issues with Vista 64 and internet connection problems. > > Everything will work fine, then all of a sudden I cannot connect to the > internet. Comes up saying that the DNS is not found, and to contact my ISP. > I am using a speedstream 6520 router/modem, and I can connect to the modem > fine, it says I'm connected to the internet, yet I cannot sign into > messenger, or view any webpages. > > I can mess around for an hour trying to get it to work, then all of a > sudden, I am able to connect again. My ISP has checked the lines and > everything is good. I've never had an internet connection problem with XP. > > Any suggestions? I have all my drivers up to date, and have very new and > trusted hardware installed. > > Specs: > > DFI Lanparty UT nforce 4 board (newest drivers installed) > 8800 GTS > Opteron 165 > Speedstream 6520 modem/router (Bell sympatico) > Vista Home Premium 64 bit |
| My System Specs |
| Similar Threads for: Internet connection problems | ||||
| internet connection problems | Browsers & Mail | |||
| Problems with Internet Connection | Network & Sharing | |||
| SP1 Causes Problems with Internet Connection | Vista General | |||
| internet connection problems | Vista networking & sharing | |||
| UAC Internet Connection (and other) Problems | Vista security | |||
