Vista - vista/ xp pc's on home network- internet connection problems
Old 02-24-2007   #1 (permalink)
bullpig
hi, I have a home network ntl cable broadband modem- connected to a belkin
router, and then to 3 xp computers. I bought a new vista pc. I am able to
establish all pc's on network, but have to reset the modem (by un-powering,
and then re-powering), to enable vista pc to connect to internet. Then the xp
pc/s cant connect. To get them to connect I have to repeat this process, and
run the MS network fixing tool on each of the xp computers. This allows them
to connect to the internet, the vista pc is unable to connect.
It works fine if either xp or vista is using the router, but not if both
are. I called my ISP, but they said it was a router problem. I called belkin,
and they haven't been able to fix it. Is this a known issue. I have tried
with 3 different routers (netgear and centreCOM, its the same with all.
I'm considering uninstalling vista and putting xp on.
Can anyone help.
Old 02-24-2007   #2 (permalink)
Keith D
REPLY:-: vista/ xp pc's on home network- internet connection problems
Hi
i have
1 x vista computer
1 x XP computer
connected to a LYNKSIS router
which in turn is connected to internet by probaly same modem
as i also have NTL as my ISP
no problems here
i had a network problem but never a problem with either connecting to
internet
are you using Netguard ??? for firewall antivirus/spyware
if yes this may be the problem i does not run in Vista as NTL should admit
i had to totally delete programme
just disabling firewall apparently still leaves it running in background
i removed netguard completly and have installed m/soft liveone care
on its 90 day free trial
this may be worth a try as you can always download and re-install netguard
anytime
cheers for now
Keith D.
> un-powering,
> xp
> and
> them
> belkin,
> Can anyone help.
Old 02-24-2007   #3 (permalink)
bullpig
RE: REPLY:-: vista/ xp pc's on home network- internet connection probl
Thanks, no I don't have netguard but i have the xp firewall on xp pc's and
use onecare on the vista pc
"Keith D" wrote:
> Hi
> i have
> 1 x vista computer
> 1 x XP computer
> no problems here
> internet
> anytime
> cheers for now
> Keith D.
> > un-powering,
> > xp
> > and
> > them
> > belkin,
> > Can anyone help.
Old 02-24-2007   #4 (permalink)
railstop
I have the same issue. Runnging a belkin wireless adapter to a Linksys
WRT54GS. connects to the internet for a while, then drops out. during the
outage, i can connec to the Linksys manage page. but that's it. i am trying
the fix found on another thread next. I'll let you know if it works.
http://support.microsoft.com/kb/928233/en-us
> "Keith D" wrote:
> > Hi
> > i have
> > 1 x vista computer
> > 1 x XP computer
> > no problems here
> > internet
> > anytime
> > cheers for now
> > Keith D.
> > > un-powering,
> > > xp
> > > and
> > > them
> > > belkin,
> > > Can anyone help.
Old 02-25-2007   #5 (permalink)
bullpig
Yes, I have had them both connecting for a while, but then, as you say- it
drops out, and I can only reset the modem for vista OR xp, but not both.
railstop- if you find a fix I would be very pleased to hear from you.
> > "Keith D" wrote:
> > > Hi
> > > i have
> > > 1 x vista computer
> > > 1 x XP computer
> > > no problems here
> > > internet
> > > anytime
> > > cheers for now
> > > Keith D.
> > > > un-powering,
> > > > xp
> > > > and
> > > > them
> > > > belkin,
> > > > Can anyone help.
Old 02-25-2007   #6 (permalink)
Robert L [MVP - Networking]
Re: vista/ xp pc's on home network- internet connection problems
Posting the results of XP and Vista ipconfig /all here may help.
Bob Lin, MS-MVP, MCSE & CNE
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
"bullpig" <bullpig@discussions.microsoft.com> wrote in message news0386666-5F39-4836-BAD9-5312CB1AC0FC@microsoft.com...
Can anyone help.
How many pc's can be hosted on a Vista home network? Vista networking & sharing
Vista Ultimate: Wireless network connection problems and slow internet access Vista networking & sharing
Home Network Windows Vista laptop + XP Desktop connection problems Vista networking & sharing
RC2 network connection problems to Internet Vista General
home network and printer connection problems with XP and Vista Vista General
