FIXING VISTA WIRELESS NETWORKING PROBLEMS - SEVERAL SOLUTIONS
  1. #1
    Bill Wood Guest
    For all of you "techies" out there, before I even go through the fixes, do
    NOT waste your time with the Alternate IP configuration options on the
    wireless adapter. THEY FLAT DON'T WORK AT ALL in Vista.
    If you have a wireless access point, and you KNOW it works on other
    computers, but you get a "local only" message from Vista, the built-in DHCP
    router in your Wireless Access Point probably is NOT compatible with Vista...
    Here is one solution that may work for SOME routers (but it does NOT work for
    all of them!)
    http://support.microsoft.com/kb/928233/en-us
    If this does not work, and you still get the "local only" message, but you
    KNOW the access point works with XP wireless, etc., then MANUALLY SET the IP
    address info. Unfortunately, if you have to manually set the IP info, you
    will have to delete those settings with other wireless access points. And
    let me say one more time, DO NOT waste your time with the Alternate IP
    configuration, it doesn't work!
    http://support.microsoft.com/kb/928152/en-us (affects mostly wireless on
    laptops)
    http://support.microsoft.com/kb/929847/en-us (Vista and XP together in a
    wireless environment)
    If your Gateway is on a different subnet (usually locations with large
    numbers of wireless spots such as businesses, universities, etc.) then you
    may have connection problems that FORCE you to manually configure your IP
    settings on the adapter. This is a FIX for XP SP2 that doesn't look like it
    made it into Vista, so, if you are experiencing this problem, LIKE ME, then
    you have no choice but to manually configure the IP settings.
    http://support.microsoft.com/?kbid=822596
    If you are having periodic connection problems (and you know they didn't
    exist before), Vista has changed the Automitic IP Address discovery timing to
    be almost instantaneous. So if you have an older wireless access point, or
    one that has long broadcast / "handshake" times, then you may have trouble
    because of this "improvement."
    http://support.microsoft.com/kb/931550/en-us (MS Does not provide a
    solution, only info. Like the other options, you will likely have to
    MANUALLY set up your IP info in the adapter, or purchase a new wireless
    access point.)
    http://support.microsoft.com/kb/929824/en-us (problems if you have the SAME
    Gateway address as the one assigned to the computer you are trying to connect
    to the Wireless spot).
    To see your adapter info, use a command prompt window (Start > Run > type in
    CMD) and then type:
    ipconfig /all
    Find your network adapter and write down the Gateway, DNS, IP Address, and
    other settings.
    Also, go to the EVENT VIEWER and see if there are any messages related to
    you trying to connect to your wireless adapter at the times you tried to
    connect.
    Regardless of the problem, if you KNOW the wireless spot works, and you had
    little or no trouble on XP, try MANUALLY setting up the IP info for that
    wireless access point.
    I'm VERY disappointed at how many problems there are with the Vista wireless
    networking. Especially when SO MANY of the early Vista users are exactly the
    same customer base that USES WIRELESS!
  2. #2
    Barb Bowman Guest
    Re: FIXING VISTA WIRELESS NETWORKING PROBLEMS - SEVERAL SOLUTIONS
    what router and firmware version are you using?
    On Tue, 27 Feb 2007 08:48:10 -0800, Bill Wood
    >all of them!)
    >laptops)
    >access point.)
    >CMD) and then type:
    >ipconfig /all
    >other settings.
    >connect.
    Barb Bowman
    MS Windows-MVP
    Expert Zone & Vista Community Columnist
    http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
    http://blogs.digitalmediaphile.com/barb/
  3. #3
    Papa Guest
    Thank you, Bill.
    As you know, many (if not all) of us are experiencing problems getting
    wireless networking to function properly with the new Vista operating
    system. Hopefully one of your suggestions will provide us with a roadmap to
    a solution.
    Much appreciated,
    Papa
  4. #4
    Bill Wood Guest
    Thanks Barb for your interest. However my specific issue is not as much with
    the access point as it is with an XP SP2 "fix" that doesn't look like it made
    it into Vista.
    My Gateway is on a totally different subnet. I'm also in a working
    environment, in a large corporation, with about 30 access points. NONE of
    them are broadcasting SSID's (no problem there), and they are all using WEP
    128. The Wireless access points are high-end Cisco's... Like I said though,
    based on the messages I'm getting, and some of the testing I've done, it is
    specifically related to not being able to determine the Gateway when it is on
    a different subnet.
    This is a FIX for XP SP2 that doesn't look like it made it into Vista.
    > >all of them!)
    > >laptops)
    > >access point.)
    > >CMD) and then type:
    > >ipconfig /all
    > >other settings.
    > >connect.
    > Barb Bowman
    > MS Windows-MVP
  5. #5
    Barb Bowman Guest
    never saw a reference to corp/enterprise or EAP etc. in your post,
    so I assumed this was a standalone residential network. do you have
    a MS contact for your company you can escalate through?
    On Tue, 27 Feb 2007 10:11:20 -0800, Bill Wood
    >it into Vista.
    >a different subnet.
    >> >all of them!)
    >> >laptops)
    >> >access point.)
    >> >CMD) and then type:
    >> >ipconfig /all
    >> >other settings.
    >> >connect.
    >> Barb Bowman
    >> MS Windows-MVP
    Barb Bowman
    MS Windows-MVP
  6. #6
    Bill Wood Guest
    I'm an IT contractor at a client site who has chosen not to adopt Vista
    because of VPN problems. I seriously doubt they are going to escalate a
    wireless issue for me, especially since I have a manual workaround.
    And when I'm home, my wireless network is fine. I don't have any trouble at
    all with it. Probably my biggest aggravation is that the Alternate IP config
    doesn't work, AT ALL... It wouldn't bother me having to use manual IP
    settings if I didn't have to do it EVERY TIME I change from business to hotel
    to home, or other places. What a royal PAIN!
    I guess my frustration stems from the fact that I would have expected that
    the networking piece would have been more "bulletproof" in Vista...
    > >it into Vista.
    > >a different subnet.
    > >> >all of them!)
    > >> >laptops)
    > >> >access point.)
    > >> >CMD) and then type:
    > >> >ipconfig /all
    > >> >other settings.
    > >> >connect.
    > >> Barb Bowman
    > >> MS Windows-MVP
    > Barb Bowman
    > MS Windows-MVP
  7. #7
    markbyrn Guest
    I had this problem suddenly occur when using my home router - it had
    worked fine for several days, and than today I received this
    'unidentified network - local only' notification. The only solution
    that worked for me was to uninstall & reinstall my network adapter. I
    would hope there is a more elegant solution.
  8. #8
    John Scott Guest
    RE: FIXING VISTA WIRELESS NETWORKING PROBLEMS - SEVERAL SOLUTIONS
    I finally gave up on trying to get wireless to work in my laptop. I had two
    issues with Vista network. First my Wireless network Verizon did not have
    Vista drivers for my PC Card. Then their was the issue at home connecting to
    my router! I finally gave up and reinstalled XP. I had the same problem with
    my desktop machine with wireless connection. So I went back to Cat5 and so
    far so good. My only thought to Microsoft is have you never heard the saying"
    if it is'nt broke don't fix it" Well I think you should look that up!
    > all of them!)
    > laptops)
    > access point.)
    > CMD) and then type:
    > ipconfig /all
    > other settings.
    > connect.
  9. #9
    jim Guest
    i too am having problems.
    several of the people with me have the exact same computer running windows
    xp and no problem.
    i have a dell latitude d610 with intel 2200bg pro wireless card.
    the diagnostics, etc. do not fix things.
    i have a clear connection to the wireless network here at the hotel but have
    been cutoff from the internet. it keeps saying i need a different firewall
    setting but even when i disable the firewall setting, it tells me there is a
    dns issue.
    this is a _serious_ problem and i am UTTERLY perplexed why things that
    worked in xp are changed like this?
    if this isn't fixed very soon, i'm going back to windows xp. and i'm also
    about to start giving in to my students repeated arguments that we should
    switch to macs.
    > > >it into Vista.
    > > >a different subnet.
    > > >> >all of them!)
    > > >> >laptops)
    > > >> >access point.)
    > > >> >CMD) and then type:
    > > >> >ipconfig /all
    > > >> >other settings.
    > > >> >connect.
    > > >> Barb Bowman
    > > >> MS Windows-MVP
    > > Barb Bowman
    > > MS Windows-MVP
  10. #10
    Jukie Guest
    Bill, could you explain how to do this: "try MANUALLY setting up the IP info
    for that
    wireless access point." I'm having internet connection problems too, and
    have found much of the info way to technical for me, so please write
    instructions for someone as dumb as I am
    Thanks!
    > all of them!)
    > laptops)
    > access point.)
    > CMD) and then type:
    > ipconfig /all
    > other settings.
    > connect.
Page 1 of 3 123 LastLast
Vista host networking problems with Intel wireless and VMware serv Vista General
Is Microsoft incapable of fixing Vista USB problems? Vista General
Wireless networking problems... Help please! Vista networking & sharing
Fixing problems with Neverwinter Nights 2 on Vista Home Premium 32bit Vista Games
Vista: 150 problems, 0 solutions Vista General
