| | Vista Network Connectivity Problem Hello, I have recently purchased a Vista Ultimate PC. I have it all set up and it is plugged into my wireless ADSL router/modem which also serves a server (which also acts as a DHCP server) I use for business and numerous laptops that connect locally and some remotely. I have had the PC for 2 weeks or so and it has all been working fine. When I first connected it all up and plugged the PC directly into the router using a cable it just seemed to auto-detect the network set up via the server and automatically added itself to it. I had had no connectivity problems until this morning when I noticed that the "Access" on the network icon in the tray was indicating "Limited Connectivity". I tried pulling out the ethernet cable for the PC from the back of the router, waiting 5 seconds and then putting it back again. It reconnected to the router and the internet almost immediately. I thought this was now sorted but within a couple of minutes, the same problem occurred again. Since then I have tried numerous things, trying the other available port on the router, resetting the router, rebooting the PC, turning both PC and router off for a couple of minutes and restarting them but the result always seems to be that at first things seem fine but within a few minutes (it is sometimes more than 2 minutes but never more than about 10 minutes) the connectivity is dropped and I can no longer get internet or even connect to the router. Any attempt to try and get Vista to "repair" or "diagnose" the problem via the various control panel options just results in failure and advice to conect my network administrator. I find it very odd that it all seemed fine for weeks but now consistently things are going wrong. I have not installed any new hardware or software in the last few days BTW. One other thing, the server and all connected laptops are all fine in terms of connectivity whenever the Vista PC stops working so I know it is something to do with the way this PC is connecting (or not!). Has anybody got any ideas for this problem? Thanks, Mark. |
| | Re: Vista Network Connectivity Problem You may want to re-configure the NIC or update the firmware for the router. This search result may help, Solved: Limited connectivity with ...Solved: Limited connectivity with Vista notebook ... Limited connectivity message, and won't connect to the network or the internet. ... http://www.chicagotech.net/netforums...opic.php?t=246 Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Mark Thompson" <choffi@dsl.pipex.com> wrote in message news:1173525689.867713.8940@h3g2000cwc.googlegroups.com... Hello, I have recently purchased a Vista Ultimate PC. I have it all set up and it is plugged into my wireless ADSL router/modem which also serves a server (which also acts as a DHCP server) I use for business and numerous laptops that connect locally and some remotely. I have had the PC for 2 weeks or so and it has all been working fine. When I first connected it all up and plugged the PC directly into the router using a cable it just seemed to auto-detect the network set up via the server and automatically added itself to it. I had had no connectivity problems until this morning when I noticed that the "Access" on the network icon in the tray was indicating "Limited Connectivity". I tried pulling out the ethernet cable for the PC from the back of the router, waiting 5 seconds and then putting it back again. It reconnected to the router and the internet almost immediately. I thought this was now sorted but within a couple of minutes, the same problem occurred again. Since then I have tried numerous things, trying the other available port on the router, resetting the router, rebooting the PC, turning both PC and router off for a couple of minutes and restarting them but the result always seems to be that at first things seem fine but within a few minutes (it is sometimes more than 2 minutes but never more than about 10 minutes) the connectivity is dropped and I can no longer get internet or even connect to the router. Any attempt to try and get Vista to "repair" or "diagnose" the problem via the various control panel options just results in failure and advice to conect my network administrator. I find it very odd that it all seemed fine for weeks but now consistently things are going wrong. I have not installed any new hardware or software in the last few days BTW. One other thing, the server and all connected laptops are all fine in terms of connectivity whenever the Vista PC stops working so I know it is something to do with the way this PC is connecting (or not!). Has anybody got any ideas for this problem? Thanks, Mark. |
| | RE: Vista Network Connectivity Problem If you have a wireless access point, and you KNOW it works on other computers, but you get a "local only" message from Vista, the built-in DHCP router in your Wireless Access Point probably is NOT compatible with Vista... Here is one solution that may work for SOME routers (but it does NOT work for all of them!) http://support.microsoft.com/kb/928233/en-us If this does not work, and you still get the "local only" message, but you KNOW the access point works with XP wireless, etc., then MANUALLY SET the IP address info. Unfortunately, if you have to manually set the IP info, you will have to delete those settings with other wireless access points. And let me say one more time, DO NOT waste your time with the Alternate IP configuration, it doesn't work! http://support.microsoft.com/kb/928152/en-us ; (affects mostly wireless on laptops) http://support.microsoft.com/kb/929847/en-us ; (Vista and XP together in a wireless environment) If your Gateway is on a different subnet (usually locations with large numbers of wireless spots such as businesses, universities, etc.) then you may have connection problems that FORCE you to manually configure your IP settings on the adapter. This is a FIX for XP SP2 that doesn't look like it made it into Vista, so, if you are experiencing this problem, LIKE ME, then you have no choice but to manually configure the IP settings. http://support.microsoft.com/?kbid=822596 If you are having periodic connection problems (and you know they didn't exist before), Vista has changed the Automitic IP Address discovery timing to be almost instantaneous. So if you have an older wireless access point, or one that has long broadcast / "handshake" times, then you may have trouble because of this "improvement." http://support.microsoft.com/kb/931550/en-us ; (MS Does not provide a solution, only info. Like the other options, you will likely have to MANUALLY set up your IP info in the adapter, or purchase a new wireless access point.) http://support.microsoft.com/kb/929824/en-us ; (problems if you have the SAME Gateway address as the one assigned to the computer you are trying to connect to the Wireless spot). ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ To see your adapter info, use a command prompt window (Start > Run > type in CMD) and then type: ipconfig /all Find your network adapter and write down the Gateway, DNS, IP Address, and other settings. Also, go to the EVENT VIEWER and see if there are any messages related to you trying to connect to your wireless adapter at the times you tried to connect. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Regardless of the problem, if you KNOW the wireless spot works, and you had little or no trouble on XP, try MANUALLY setting up the IP info for that wireless access point. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ I'm VERY disappointed at how many problems there are with the Vista wireless networking. Especially when SO MANY of the early Vista users are exactly the same customer base that USES WIRELESS! "Mark Thompson" wrote: > Hello, > > I have recently purchased a Vista Ultimate PC. I have it all set up > and it is plugged into my wireless ADSL router/modem which also serves > a server (which also acts as a DHCP server) I use for business and > numerous laptops that connect locally and some remotely. > > I have had the PC for 2 weeks or so and it has all been working fine. > When I first connected it all up and plugged the PC directly into the > router using a cable it just seemed to auto-detect the network set up > via the server and automatically added itself to it. > > I had had no connectivity problems until this morning when I noticed > that the "Access" on the network icon in the tray was indicating > "Limited Connectivity". I tried pulling out the ethernet cable for the > PC from the back of the router, waiting 5 seconds and then putting it > back again. It reconnected to the router and the internet almost > immediately. I thought this was now sorted but within a couple of > minutes, the same problem occurred again. Since then I have tried > numerous things, trying the other available port on the router, > resetting the router, rebooting the PC, turning both PC and router off > for a couple of minutes and restarting them but the result always > seems to be that at first things seem fine but within a few minutes > (it is sometimes more than 2 minutes but never more than about 10 > minutes) the connectivity is dropped and I can no longer get internet > or even connect to the router. Any attempt to try and get Vista to > "repair" or "diagnose" the problem via the various control panel > options just results in failure and advice to conect my network > administrator. > > I find it very odd that it all seemed fine for weeks but now > consistently things are going wrong. I have not installed any new > hardware or software in the last few days BTW. > > One other thing, the server and all connected laptops are all fine in > terms of connectivity whenever the Vista PC stops working so I know it > is something to do with the way this PC is connecting (or not!). > > Has anybody got any ideas for this problem? > > Thanks, > > Mark. > > |
| | Re: Vista Network Connectivity Problem The Vista 64bit beta F5D7000 V6 did it for me. Combined with shutting down DHCP and setting WPA2 On 11 mrt, 06:36, Bill Wood <BillW...@discussions.microsoft.com> wrote: > If you have a wireless access point, and you KNOW it works on other > computers, but you get a "local only" message from Vista, the built-in DHCP > router in your Wireless Access Point probably is NOT compatible with Vista... > Here is one solution that may work for SOME routers (but it does NOT work for > all of them!) > > http://support.microsoft.com/kb/928233/en-us > > If this does not work, and you still get the "local only" message, but you > KNOW the access point works with XP wireless, etc., then MANUALLY SET the IP > address info. Unfortunately, if you have to manually set the IP info, you > will have to delete those settings with other wireless access points. And > let me say one more time, DO NOT waste your time with the Alternate IP > configuration, it doesn't work! > > http://support.microsoft.com/kb/928152/en-us; (affects mostly wireless on > laptops)http://support.microsoft.com/kb/929847/en-us; (Vista and XP together in a > wireless environment) > > If your Gateway is on a different subnet (usually locations with large > numbers of wireless spots such as businesses, universities, etc.) then you > may have connection problems that FORCE you to manually configure your IP > settings on the adapter. This is a FIX for XP SP2 that doesn't look like it > made it into Vista, so, if you are experiencing this problem, LIKE ME, then > you have no choice but to manually configure the IP settings. > > http://support.microsoft.com/?kbid=822596 > > If you are having periodic connection problems (and you know they didn't > exist before), Vista has changed the Automitic IP Address discovery timing to > be almost instantaneous. So if you have an older wireless access point, or > one that has long broadcast / "handshake" times, then you may have trouble > because of this "improvement." > > http://support.microsoft.com/kb/931550/en-us; (MS Does not provide a > solution, only info. Like the other options, you will likely have to > MANUALLY set up your IP info in the adapter, or purchase a new wireless > access point.) > > http://support.microsoft.com/kb/929824/en-us; (problems if you have the SAME > Gateway address as the one assigned to the computer you are trying to connect > to the Wireless spot). > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > To see your adapter info, use a command prompt window (Start > Run > type in > CMD) and then type: > > ipconfig /all > > Find your network adapter and write down the Gateway, DNS, IP Address, and > other settings. > > Also, go to the EVENT VIEWER and see if there are any messages related to > you trying to connect to your wireless adapter at the times you tried to > connect. > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > Regardless of the problem, if you KNOW the wireless spot works, and you had > little or no trouble on XP, try MANUALLY setting up the IP info for that > wireless access point. > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > I'm VERY disappointed at how many problems there are with the Vista wireless > networking. Especially when SO MANY of the early Vista users are exactly the > same customer base that USES WIRELESS! > > > > "Mark Thompson" wrote: > > Hello, > > > I have recently purchased a Vista Ultimate PC. I have it all set up > > and it is plugged into my wireless ADSL router/modem which also serves > > a server (which also acts as a DHCP server) I use for business and > > numerous laptops that connect locally and some remotely. > > > I have had the PC for 2 weeks or so and it has all been working fine. > > When I first connected it all up and plugged the PC directly into the > > router using a cable it just seemed to auto-detect the network set up > > via the server and automatically added itself to it. > > > I had had no connectivity problems until this morning when I noticed > > that the "Access" on the network icon in the tray was indicating > > "Limited Connectivity". I tried pulling out the ethernet cable for the > > PC from the back of the router, waiting 5 seconds and then putting it > > back again. It reconnected to the router and the internet almost > > immediately. I thought this was now sorted but within a couple of > > minutes, the same problem occurred again. Since then I have tried > > numerous things, trying the other available port on the router, > > resetting the router, rebooting the PC, turning both PC and router off > > for a couple of minutes and restarting them but the result always > > seems to be that at first things seem fine but within a few minutes > > (it is sometimes more than 2 minutes but never more than about 10 > > minutes) the connectivity is dropped and I can no longer get internet > > or even connect to the router. Any attempt to try and get Vista to > > "repair" or "diagnose" the problem via the various control panel > > options just results in failure and advice to conect my network > > administrator. > > > I find it very odd that it all seemed fine for weeks but now > > consistently things are going wrong. I have not installed any new > > hardware or software in the last few days BTW. > > > One other thing, the server and all connected laptops are all fine in > > terms of connectivity whenever the Vista PC stops working so I know it > > is something to do with the way this PC is connecting (or not!). > > > Has anybody got any ideas for this problem? > > > Thanks, > > > Mark.- Tekst uit oorspronkelijk bericht niet weergeven - > > - Tekst uit oorspronkelijk bericht weergeven - |
| Vista 64bit causing network wide connectivity problems? | Network & Sharing | |||
| BUG: Vista network connectivity lost after opening many connectionswith Perl.exe | Vista networking & sharing | |||
| Vista Limited Connectivity / Unidentified Network issue | .NET General | |||
| Lack of network connectivity of a Vista Machine to its domaincontroller | Vista networking & sharing | |||
| Lack of network connectivity of a Vista Machine to its domaincontroller | Vista General | |||
