| | Problem adding wireless network, Vista RTM WPA2-PSK, no SSID broad Bug report. Tested using Vista Ultimate RTM, Linksys WPC54GS NIC, Linksys WAP54G AP, 802.11g LAN with WPA2-PSK/AES without radius server and SSID broadcast disabled, on IBM Thinkpad R51 laptop. Device drivers for Linksys NIC are MS drivers from Vista DVD. When adding a wireless network definition in Vista manually, by selecting WPA2-Personal/AES/PSK and entering the SSID and (long) shared secret, vista fails to connect with an error message, but the network definition entry is visible in the list. Hitting the [+] "Add" icon and attempting a second time then successfully connects. Suggest a possible bug in the UI in the case of networks where SSID broadcast is disabled. [Sanity check This is a known-good NIC and wireless LAN in daily use with WinXp machines, and the settings for the wireless LAN were verified on a WinXp Sp2 machine. -- Cecil Ward ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...orking_sharing |
| | RE: Problem adding wireless network, Vista RTM WPA2-PSK, no SSID broad I also posted a question regarding this problem or at least a closely related problem. No solutions yet. My PDA connects perfectly with WEP or WPA security, but the new laptop with Vista will not connect unless security is turned off. Article on MS website states that MS does not recommend non-broadcast SSID. Does not seem very secure. heh-heh. "Cecil Ward" wrote: > Bug report. > > Tested using Vista Ultimate RTM, Linksys WPC54GS NIC, Linksys WAP54G AP, > 802.11g LAN with WPA2-PSK/AES without radius server and SSID broadcast > disabled, on IBM Thinkpad R51 laptop. Device drivers for Linksys NIC are MS > drivers from Vista DVD. > > When adding a wireless network definition in Vista manually, by selecting > WPA2-Personal/AES/PSK and entering the SSID and (long) shared secret, vista > fails to connect with an error message, but the network definition entry is > visible in the list. Hitting the [+] "Add" icon and attempting a second time > then successfully connects. > > Suggest a possible bug in the UI in the case of networks where SSID > broadcast is disabled. > > [Sanity check This is a known-good NIC and wireless LAN in daily use with > WinXp machines, and the settings for the wireless LAN were verified on a > WinXp Sp2 machine. > > > -- > Cecil Ward > > ---------------- > This post is a suggestion for Microsoft, and Microsoft responds to the > suggestions with the most votes. To vote for this suggestion, click the "I > Agree" button in the message pane. If you do not see the button, follow this > link to open the suggestion in the Microsoft Web-based Newsreader and then > click "I Agree" in the message pane. > > http://windowshelp.microsoft.com/com...orking_sharing |
| | RE: Problem adding wireless network, Vista RTM WPA2-PSK, no SSID broad Update: the problem seems to be related to a misunderstanding of terminology. If I select WPA-PSK/AES (not WPA-2), then the problem seems easier to avoid. -- Cecil Ward |
| | RE: Problem adding wireless network, Vista RTM WPA2-PSK, no SSID b I have my wireless setup working by using WEP but could not get it to work with WPA. Not able to access xp machine from vista. XP PC shows up in vista network but cannot connect to XP machine. Must be a setting in the XP machine to prevent connection from outside. "Cecil Ward" wrote: > Update: the problem seems to be related to a misunderstanding of terminology. > If I select WPA-PSK/AES (not WPA-2), then the problem seems easier to avoid. > > -- > Cecil Ward > |
| | RE: Problem adding wireless network, Vista RTM WPA2-PSK, no SSID b "Cecil Ward" wrote: > Update: the problem seems to be related to a misunderstanding of terminology. > If I select WPA-PSK/AES (not WPA-2), then the problem seems easier to avoid. > > -- > Cecil Ward > I have my Notebook functioning with wireless and WPA-PSK. Had to use MAC filtering in the router. The PDA and Notebook with Vista installed work. |
| | #6 (permalink) |
| | RE: Problem adding wireless network, Vista RTM WPA2-PSK, no SSID b I confirm what I said earlier. The bug does indeed to be due to confusion over the meaning of "WPA2" vs "WPA" in my case. MS could state their definition of these terms perhaps in the UI. (To me WPA2 means "using AES" and WPA2-personal means that you "not using a radius server/802.1x".) As I am mandating AES on the WLAN, I maintain that I am using WPA2. Vista seems to only be happy if I select WPA-Personal rather than WPA2-Personal. Speculation: Much weirdness seems to be caused by Vista's fear and loathing of SSID-hidden WLANs. If anyone from MS is listening, I ask Vista dev team to test the following scenario: Both Vista x64 and x86; set to "WPA2-Personal" = WPA-PSK/AES with max length key over LAN with hw Linksys WAP54G AP + WPC54GS NIC, set to SSID-broadcast off, Wireless-G-only mode. -- Cecil Ward "Cecil Ward" wrote: > Update: the problem seems to be related to a misunderstanding of terminology. > If I select WPA-PSK/AES (not WPA-2), then the problem seems easier to avoid. > > -- > Cecil Ward > |
| adding a printer to my wireless network. xp desktop - vista laptop | Network & Sharing | |||
| WPA2 protected wireless network - Problems on reconnect | Network & Sharing | |||
| Error connecting to a wireless network with disabled SSID | Vista networking & sharing | |||
| Cannot network from XP desktop to wireless vsita when WPA2 activat | Vista networking & sharing | |||
| Broadcast SSID required to connect to wireless network - why ? | Vista General | |||
