Wireless Networking
  1. #1
    rowanhjl Guest
    Wireless Networking
    At present I have a US Robotics 5416 Wireless Network card that Vista states
    is not compatible. Is anyone aware of any wireless network products from the
    UK that will work with Vista Beta 2 (PCI cards or USB). Many thanks, agc
  2. #2
    u.s.e.TEC Guest
    RE: Wireless Networking
    Not sure if you found a solution but I will offer one, please though, make
    sure you post back and let everyone know if this helped or not.
    I had a similar problem with my D-Link 524 Router and a wireless D-Link usb
    G122 adapter, Vista stated that my device was incompatible with the router.
    Turns out that I forgot, when I setup Vista, I disabled all the WPA settings
    within my Router and was trying to connect using those very settings from
    within Vista. I guess Vista, not knowing the Router configuation, figured my
    adapter was incompatible with my router because Vista does not display a
    wireless open connection as being open like XP does. It took some digging but
    I finally reallized this by allowing Vista to Diagnose the problem.
    u.s.e.TEC PC Security Consulting
    Specializing in User Security Education
Wireless Networking
Wireless networking help MikeB Vista General 7 28 Dec 2008
Networking and Wireless 1xnyer Vista networking & sharing 2 30 Aug 2007
Wireless Networking Nero Vista networking & sharing 6 27 Jul 2007
Wireless Networking Bill Condie Vista General 0 24 Feb 2007
Wireless Networking Rowan Troy Vista hardware & devices 2 02 Jun 2006
