1.    29 Mar 2007 #1
    ogman Guest
    Wireless network connection lost frequently...
    I have several machines, 2 Windows notebooks, a Mac, and another Windows
    desktop running XP, that all keep their network connection perfectly. The
    only machine that drops the connection constantly is the one running Vista.
    I'm using a Linksys WUSB54GS wireless card and a Linksys WRT54GX router, and
    this equipment worked fine under XP. The computer itself is more than
    sufficient to run Vista.
    Does anyone know why this problem continues? Any suggestions on how to solve
    it? Please don't tell me to go back to XP, I paid way too much for Vista to
    not use it.
    Now, a bit of a rant...why the heck, in the months of beta testing, were
    problems like this not solved? I have to say that Vista seems very much like
    a still-in-progress beta, rather than a commercial product. When is this OS
    going to start coming together?
    Sorry, but I am just frustrated with the continuing problems with Vista. I
    feel like I'm part of some unsolicited testing group.
  2.    29 Mar 2007 #2
    Karl Froelich [MS] Guest
    Re: Wireless network connection lost frequently...
    This could well be an issue with your router. Differences in the networking
    stack between XP and Vista have exposed a lot of router bugs which were
    hitherto hidden.
    Vista uses UPnP much more heavily than XP ever did, and we've found that a
    lot of routers have suboptimal UPnP implementations, causing them to crash.
    1. Does this happen on both a wired connection to the router AND a wireless
    connection?
    2. when Vista "loses" connection, does it come back automatically, or do you
    have to reboot your router? Do the other xp machines also lose
    connectivity?
    3. If ONLY the vista machine loses connectivity, then there is an issue with
    your vista machine. Make sure your drivers are all up to date. If
    wireless, make sure you have the latest drivers for your card. Go to
    linksys' website and verifiy that what you've got is the latest.
    4. While you're there, make sure you have the latest firmware for your
    router. We found a lot of bugs in router firmware during development, and
    the vendors posted a lot of firmware updates.
    5. Then, try running the router tool at
    http://www.microsoft.com/windows/usi...d/default.mspx, and see if it
    passes the tests.
    If we can narrow the issue down to your router, that is, that when Vista
    loses connectivity ALL the machines (xp too) lose connectivity, then there
    are some things worth trying:
    A possible solution worth trying is to turn of UPnP. This can be done on
    the router (you would have to log onto the routers config page, find out
    where it has the UPnP on/off switch, and turn it off) or from the machine
    itself.
    You can also try disabling window scaling.
    So, please try these out:
    1. Go to the webtool, and when the test is finished, click on the "view
    detailed report" link, and copy that data off & save it.
    2. turn off UPnP, either on the router or on the vista machine:
    from an elevated command prompt,type the following:
    a. sc config SSDPSRV start= disabled
    b. net stop ssdpsrv <or> reboot the system
    3. Try your test again. If it still fails after some perioed of time, turn
    off Window Scaling:
    From an elevated command prompt, type the following:
    a. netsh in tcp set gl auto=di
    <no reboot required>
    K.
    "ogman" <ogman@discussions.microsoft.com> wrote in message
    news:32586B0B-CD46-47B7-9193-CA6F591F9AF4@microsoft.com...
    > Vista.
    > and
    > solve
    > to
    > not use it.
    > like
    > OS
  3.    29 Mar 2007 #3
    ogman Guest
    Karl,
    Thanks for the reply. I upgraded the firmware and checked that the card
    driver is the most recent. I ran the test you suggested and found that UPnP
    was "not supported." As I was going through the router settings, I noticed
    that UPnP was disabled and I enabled it. I ran the test again. The first time
    everything except UPnP was good. After enabling UPnP, the test listed Network
    Address Translator Type as not supported. On the first test (before enabling
    UPnP), "the IGD's NAT type is RESTRICTED CONE." After UPnP is enabled, "the
    IGD's NAT type is SYMMETRIC."
    My limited understanding of all of this suggests to me that, for now, my
    problems may be solved, since IPv6 is not widely in use. However, I would be
    curious to know why turning on the UPnP changed the NAT type?
    Thanks again.
    > hitherto hidden.
    > connection?
    > connectivity?
    > passes the tests.
    > itself.
    > off Window Scaling:
    > K.
    > > Vista.
    > > and
    > > solve
    > > to
    > > not use it.
    > > like
    > > OS
  4.    29 Mar 2007 #4
    Ogman, theoretically it shouldn't. I've been thoroughly through the
    process, and I'll dig into this with the developer for that.
    It may be becuase we're using an algorith developed for Teredo (Teredo is a
    technology for tunneling IPv6 over IPv4. It's in Vista), and for Teredo to
    work properly it has to have access to port mappings for the UDP "bubbles"
    it uses.
    However, I will follow up with more specifics. Aside from that are things
    working well for you now? Does Vista still lose connectivity?
    Cheers,
    k.
    news:FA0D3988-9EF9-4CF5-9518-4C1773D3C1E4@microsoft.com...
    > Karl,
    > UPnP
    > time
    > Network
    > enabling
    > "the
    > be
    > Thanks again.
    >> networking
    >> hitherto hidden.
    >> a
    >> crash.
    >> wireless
    >> connection?
    >> you
    >> connectivity?
    >> with
    >> and
    >> it
    >> passes the tests.
    >> there
    >> machine
    >> itself.
    >> turn
    >> off Window Scaling:
    >> K.
    >> > The
    >> > Vista.
    >> > router,
    >> > and
    >> > solve
    >> > Vista
    >> > to
    >> > not use it.
    >> > were
    >> > like
    >> > this
    >> > OS
    >> > Vista. I
  5.    03 Apr 2007 #5
    ogman Guest
    Me again. The wireless connection is gone again. I'm going to go ahead and
    re-install XP so I can get some work done here. Anyone in contact with
    Microsoft needs to tell them that they have royally screwed wireless
    networking in Vista. I googled the problem and it is widespread, with most
    solutions not working for more than a few hours. I need a stable system, so
    enough of Vista.
    > it uses.
    > Cheers,
    > k.
    > > Karl,
    > > UPnP
    > > time
    > > Network
    > > enabling
    > > "the
    > > be
    > > Thanks again.
    > >> networking
    > >> hitherto hidden.
    > >> a
    > >> crash.
    > >> wireless
    > >> connection?
    > >> you
    > >> connectivity?
    > >> with
    > >> and
    > >> it
    > >> passes the tests.
    > >> there
    > >> machine
    > >> itself.
    > >> turn
    > >> off Window Scaling:
    > >> K.
    > >> > The
    > >> > Vista.
    > >> > router,
    > >> > and
    > >> > solve
    > >> > Vista
    > >> > to
    > >> > not use it.
    > >> > were
    > >> > like
    > >> > this
    > >> > OS
    > >> > Vista. I
  6.    25 Dec 2007 #6
    Mac (Croatia) Guest
    I have exactly the same problem:
    I have wired and wireless connection, and my wireles connection is being
    constantly disconected after one or two hours. I have to reboot my windows
    machine , rebooting my router doesn't help.
    XP machine on same router doesn't disconnect.
    My router is Siemens Gigaset SE555 WLAN dsl. In the begining, maybe some ten
    months , my wireless connection worked just fine, and this problem started
    recently. I think it started after one of the regular Vista updates.
    Thank You in advance.
  7.    25 Dec 2007 #7
    Robert L. \(MS-MVP\) Guest
    We had some posts regarding Microsoft update. This link is one of them
    Can't access the Internet after installed Update
    http://www.chicagotech.net/vista/vistaupdate.htm
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "Mac (Croatia)" <Mac (Croatia)@discussions.microsoft.com> wrote in message
    newsFE9E355-2550-42F5-8229-B1B5DA42166F@xxxxxx
    > ten
Lost my Wireless Network connection
Hi, can u help me i have lost my Wireless Network connection? When i connected buy hard wire i have no problem, but when i connect wireless then...
Network & Sharing
Wireless connection lost on laptop restart
My laptop - Vista Premium 64-bit - connects via wireless to my desktop. All works well - I set the network properties to automatically seek the...
Vista networking & sharing
Wireless connection continually lost
Hi all - Vista SP1, Ultimate X86 I have an HP z6000 laptop with a wireless connection to my home network. I have a Netgear Wireless Firewall...
I've been trying to figure out this problem for over a week now to no avail. It appears to be random, though I lose my connection every hour or so. ...
Network Mapped Drive : Lost Network Connection
Hi, A vista laptop has a mapped drive to a SBS2003 server. The laptop is able to browse the share and open files, permissions on the share a...
Vista lost wireless connection
I bought a toshiba laptop a couple of months ago (previous laptop died). It came with home premium. I was able to connect to my wireless router...
Wireless Connection Lost after Vista Upgrade
Greetings. I have a Comcast cable modem attached to Linksys Router. Two computers, an HP Media Center with Vista and a Thinkpad with XP and...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
