Vista Tutorial - Vista/XP Networking Problem
Old 04-25-2007   #1 (permalink)
Cathy C
Guest
I just got a new laptop with Vista and am trying to do file and printer
sharing with other XP computers on the network. Two are fine, but the third
is asking for a user name and password. I have uninstalled ZoneAlarm and AV
software; set up user accounts for both computers; run the network wizard for
file and printer sharing; enabled Netbios over TCP/IP in the IP ver. 4
properties. Have no idea why the other two don't have a problem, but this one
does. All have the same workgroup name. I can do remote desktop connection,
but would prefer file and printer sharing.
Thanks for any suggestions you may have.
Cathy
Old 04-25-2007   #2 (permalink)
Cathy C
Guest
Re: Vista/XP Networking Problem
It's an XP server (PC) as are two others on the network. It's asking for a
user ID and password, but none work. No problems accessing the shared files
on the Vista laptop.
Thanks.
Cathy
"Chuck" wrote:
> On Wed, 25 Apr 2007 16:30:00 -0700, Cathy C <CathyC@discussions.microsoft.com>
> >Cathy
> Cathy,
> You say "the third is asking for a user name and password". The third is
> running which OS? And connecting to which computer when "asking for a user name
> and password""?
> To access a Vista server from an XP client, you have to
> * Set the Network Location Type to "Private". This implies that your
> computers are secure, behind a perimeter firewall or a NAT router, and opens the
> personal firewall for file sharing.
> * Check / set "Password protected sharing" (PPS). Disabling PPS is the
> equivalent of enabling Simple File Sharing, in Windows XP.
> * Setup shared folders and printers. If you enabled PPS, you should setup
> access for individual users. If you disabled PPS, you setup access for "Guest"
> or "Everyone".
> <http://nitecruzr.blogspot.com/2006/12/windows-xp-and-vista-on-lan-together.html>
> http://nitecruzr.blogspot.com/2006/1...-together.html
> And if you're trying to connect to a computer running Windows XP, read
> <http://nitecruzr.blogspot.com/2005/06/file-sharing-under-windows-xp.html#Help>
> http://nitecruzr.blogspot.com/2005/0...s-xp.html#Help
> Cheers,
> Chuck, MS-MVP [Windows - Networking]
> Paranoia is not a problem, when it's a normal response from experience.
> My email is AT DOT
> actual address pchuck mvps org.
Old 04-25-2007   #3 (permalink)
Chuck
Guest
>Cathy
Cathy,
and password""?
or "Everyone".
Cheers,
My email is AT DOT
Old 04-25-2007   #4 (permalink)
Chuck
Guest
On Wed, 25 Apr 2007 18:06:01 -0700, Cathy C <CathyC@discussions.microsoft.com>
>> >Cathy
>> Cathy,
>> and password""?
>> or "Everyone".
>Thanks.
>Cathy
OK, you have to consider the computer that it's trying to connect to. Remember
Windows XP comes in 2 flavours - Home and Pro. And Pro might have Simple, or
Advanced, File Sharing. And if AFS is used, it might be setup for Guest, or for
non-Guest, file sharing.
<http://nitecruzr.blogspot.com/2005/06/file-sharing-under-windows-xp.html>
http://nitecruzr.blogspot.com/2005/0...indows-xp.html
And what ever account (Guest or non-Guest), make sure that the account that you
think that you're using is properly prepared for network access.
Cheers,
My email is AT DOT
Old 04-26-2007   #5 (permalink)
Cathy C
Guest
Thank you!! I'm not sure if it was unchecking Simple File Sharing or the net
user command, but all the printers and shared folders are now showing up.
Appreciate your help!
Cathy
> >> >Cathy
> >> Cathy,
> >> and password""?
> >> or "Everyone".
> >Thanks.
> >Cathy
> Cheers,
> My email is AT DOT
Old 04-26-2007   #6 (permalink)
Chuck
Guest
On Thu, 26 Apr 2007 01:58:01 -0700, Cathy C <CathyC@discussions.microsoft.com>
>> >> >Cathy
>> >> Cathy,
>> >> and password""?
>> >> or "Everyone".
>> >Thanks.
>> >Cathy
>Cathy
I'll bet the latter. Your symptoms fit inability to authenticate because the
account wasn't fit for network access.
Glad I was able to help. Thanks for the feedback.
Cheers,
My email is AT DOT
networking problem Vista & XP Vista General
Problem networking XP & Vista Vista networking & sharing
Another XP & Vista networking problem. Vista networking & sharing
Vista Networking problem with VPN Vista networking & sharing
Different Vista XP networking problem Vista networking & sharing
