Vista Tutorial - Remote Desktop Error *HELP ME*
Old 05-09-2007   #1 (permalink)
pnapp1
Guest
Here is the problem:
I am trying to remote desktop connect to other PC's on my network and every
time I try to connect to anything I get the following error:
" THIS COMPUTER CAN'T CONNECT TO THE REMOTE COMPUTER.
THE PROBLEM MIGHT BE DUE TO LOW VIRTUAL MEMORY ON YOUR COMPUTER."
I have 4 gigs memory and my pagefile is 5 gigs. I'm not even close to
touching any virtual memory. Remote Desktop used to work fine and my other
Vista PC works fine with RDC so I know it is not a network issue. The PC in
question is running Vista Ultimate.
Any help would be greatly appreciated! Save me from having to do a reinstall!
Old 05-10-2007   #2 (permalink)
Robert L [MVP - Networking]
Guest
Re: Remote Desktop Error *HELP ME*
Do a simple test. Can you telnet port 3389? Or this research result may help,
Troubleshooting terminal server issuesWhen trying to access TS (administration mode), you may get this message: "The client could not connect to the remote computer. Remote connections might not ...
http://www.chicagotech.net/troubleshootingts.htm
Bob Lin, MS-MVP, MCSE & CNE
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
"pnapp1" <pnapp1@discussions.microsoft.com> wrote in message news:8C0C163E-6441-4D0D-864A-EED31A653133@microsoft.com...
Old 05-10-2007   #3 (permalink)
pnapp1
Guest
Yes I can. But I don't see why this would matter since I am on the same local
network. No matter if I try to connect to a real computer on my network or
just make up one, I get the same error no matter what.
All other PC's can RDC to each other fine and even connect to the PC in
question but this one can't connect to any others. I never get past the: "THE
PROBLEM MIGHT BE DUE TO LOW VIRTUAL MEMORY ON YOUR COMPUTER." error.
I have looked everywhere for people having this same error (here, google,
ect) and have not found one instance like this. Maybe something unique to my
PC's setup or a new bug in Vista?
Old 05-10-2007   #4 (permalink)
pnapp1
Guest
Old 05-11-2007   #5 (permalink)
pnapp1
Guest
Re: Remote Desktop Error *STILL NEED HELP*
Any other suggestions?
Old 05-14-2007   #6 (permalink)
Howard
Guest
I've encountered the same problem with XP Service Pack 2 and RDC 6.0. I also
have significant memory available.
I did the telnet test, and I am able to telnet successfully to the server.
Old 08-06-2007   #7 (permalink)
lairnoc
Guest
same problem here vista ultimate
one day it worked day after no go.. got 2 gb memory and enough on hd left
for virtual.
Hope MS will come with a solution!!!
Its anoying not to be able to connect to my game server now
Remote Desktop does not connect, no error, nothing Vista General
Remote Desktop Error Vista General
Remote Desktop Disconnected error Vista General
Remote Desktop Error Vista networking & sharing
Remote Desktop Connection Error Vista General
