| | #11 (permalink) |
| | Re: Vista Wireless Connection Problems No.. the windows xp is an older Dell laptop. "John" wrote: > Is the hardware identical between the Vista nd XP laptops? Check device > manager to be sure, especially regarding the wireless card flavour. > > > "Arjan321" <Arjan321@discussions.microsoft.com> wrote in message > news:BE7B23EF-9F5B-425D-86DD-127B80E8D780@microsoft.com... > > The point is that my windows XP laptop has none of the problems the two > > Vista > > laptops have. Which, to me, indicates one of the following > > > > - Vista incompatibility > > - Old drivers (working on that) > > - Serious hardware problems with Acer Laptops > > > > Is there a way for windows to do a check of some sort of wireless > > connections? > > > > Thanks anyway! > > > > "John" wrote: > > > >> Many times wireless disconnects are an issue between the computer's > >> wireless > >> card and the wireless router. See if your router has the latest firmware. > >> Check your router's web site for any forums where this problem may be > >> being > >> discussed. Then check the wireless card settings. It's a PITA . > >> > >> "Arjan321" <Arjan321@discussions.microsoft.com> wrote in message > >> news:588512F4-8847-4FC6-8BF7-C60C6F412EB3@microsoft.com... > >> > Hello, > >> > > >> > I've bought two brand new Acer Aspire 5102wlmi laptops with Vista > >> > preinstalled. > >> > > >> > Connection to my wireless network works fine, but once in while ( once > >> > every > >> > ~30 minutes) the connection disconnects and connects again, disabling > >> > my > >> > internet. Both laptops suffer from this. > >> > > >> > An other symptom of this problem is, while playing music in winamp/wmp > >> > small > >> > "ticks" are audible, suggesting data loss. > >> > > >> > My older laptop, running Windows XP, has no problems whatsoever. No > >> > ticks > >> > (same music) and 100% connection time. > >> > > >> > Any suggestion? > >> > > >> > Specs laptop: > >> > - Acer Aspire 5102wlmi > >> > - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest > >> > version > >> > as > >> > far as I know) > >> > - IPv6 disabled > >> > - Windows Vista Home Premium > >> > > >> > Wireless: > >> > 802.11a/b/g/n, with WPA-personal TIPK encription. > >> > >> > > |
| | #12 (permalink) |
| | Re: Vista Wireless Connection Problems Both also with Atheros cards? With driver version? I'm still searching for the latest version for mine. Sure, as far as I know, these are the hardware IDs of the Atheros AR5005G Wireless network Adapter: -PCI\VEN_168C&DEV_001A&SUBSYS_04181468&REV_01 -PCI\VEN_168C&DEV_001A&SUBSYS_04181468 -PCI\VEN_168C&DEV_001A&CC_020000 -PCI\VEN_168C&DEV_001A&CC_0200 Thanks in advance! "Barb Bowman" wrote: > can you go into device manager and get the hardware IDs for your > Atheros wireless and post them here? > > as stated, it is possible that it is the router side causing the > issues. > > BTW, my Acer Ferrari 5000 and 4000s running Ultimate x64 have no > issues hardware wise. > > > > On Fri, 18 May 2007 17:49:02 -0700, Arjan321 > <Arjan321@discussions.microsoft.com> wrote: > > >The point is that my windows XP laptop has none of the problems the two Vista > >laptops have. Which, to me, indicates one of the following > > > >- Vista incompatibility > >- Old drivers (working on that) > >- Serious hardware problems with Acer Laptops > > > >Is there a way for windows to do a check of some sort of wireless connections? > > > >Thanks anyway! > > > >"John" wrote: > > > >> Many times wireless disconnects are an issue between the computer's wireless > >> card and the wireless router. See if your router has the latest firmware. > >> Check your router's web site for any forums where this problem may be being > >> discussed. Then check the wireless card settings. It's a PITA . > >> > >> "Arjan321" <Arjan321@discussions.microsoft.com> wrote in message > >> news:588512F4-8847-4FC6-8BF7-C60C6F412EB3@microsoft.com... > >> > Hello, > >> > > >> > I've bought two brand new Acer Aspire 5102wlmi laptops with Vista > >> > preinstalled. > >> > > >> > Connection to my wireless network works fine, but once in while ( once > >> > every > >> > ~30 minutes) the connection disconnects and connects again, disabling my > >> > internet. Both laptops suffer from this. > >> > > >> > An other symptom of this problem is, while playing music in winamp/wmp > >> > small > >> > "ticks" are audible, suggesting data loss. > >> > > >> > My older laptop, running Windows XP, has no problems whatsoever. No ticks > >> > (same music) and 100% connection time. > >> > > >> > Any suggestion? > >> > > >> > Specs laptop: > >> > - Acer Aspire 5102wlmi > >> > - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version > >> > as > >> > far as I know) > >> > - IPv6 disabled > >> > - Windows Vista Home Premium > >> > > >> > Wireless: > >> > 802.11a/b/g/n, with WPA-personal TIPK encription. > >> > >> > -- > > Barb Bowman > MS Windows-MVP > Expert Zone & Vista Community Columnist > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx > http://blogs.digitalmediaphile.com/barb/ > |
| | #13 (permalink) |
| | Re: Vista Wireless Connection Problems I'm using x64, so that is the inf file I can look at. Your hardware ID is certainly covered in the x64 driver (and I can't imagine it not being covered in the 32 bit version). this is from the inf file for the April driver: %ATHR.DeviceDesc.001A% = ATHR_DEV_04221468.ndi, PCI\VEN_168C&DEV_001A&SUBSYS_04181468 On Sat, 19 May 2007 08:13:54 -0700, Arjan321 <Arjan321@discussions.microsoft.com> wrote: >Both also with Atheros cards? With driver version? I'm still searching for >the latest version for mine. > >Sure, as far as I know, these are the hardware IDs of the Atheros AR5005G >Wireless network Adapter: >-PCI\VEN_168C&DEV_001A&SUBSYS_04181468&REV_01 >-PCI\VEN_168C&DEV_001A&SUBSYS_04181468 >-PCI\VEN_168C&DEV_001A&CC_020000 >-PCI\VEN_168C&DEV_001A&CC_0200 > >Thanks in advance! > >"Barb Bowman" wrote: > >> can you go into device manager and get the hardware IDs for your >> Atheros wireless and post them here? >> >> as stated, it is possible that it is the router side causing the >> issues. >> >> BTW, my Acer Ferrari 5000 and 4000s running Ultimate x64 have no >> issues hardware wise. >> >> >> >> On Fri, 18 May 2007 17:49:02 -0700, Arjan321 >> <Arjan321@discussions.microsoft.com> wrote: >> >> >The point is that my windows XP laptop has none of the problems the two Vista >> >laptops have. Which, to me, indicates one of the following >> > >> >- Vista incompatibility >> >- Old drivers (working on that) >> >- Serious hardware problems with Acer Laptops >> > >> >Is there a way for windows to do a check of some sort of wireless connections? >> > >> >Thanks anyway! >> > >> >"John" wrote: >> > >> >> Many times wireless disconnects are an issue between the computer's wireless >> >> card and the wireless router. See if your router has the latest firmware. >> >> Check your router's web site for any forums where this problem may be being >> >> discussed. Then check the wireless card settings. It's a PITA . >> >> >> >> "Arjan321" <Arjan321@discussions.microsoft.com> wrote in message >> >> news:588512F4-8847-4FC6-8BF7-C60C6F412EB3@microsoft.com... >> >> > Hello, >> >> > >> >> > I've bought two brand new Acer Aspire 5102wlmi laptops with Vista >> >> > preinstalled. >> >> > >> >> > Connection to my wireless network works fine, but once in while ( once >> >> > every >> >> > ~30 minutes) the connection disconnects and connects again, disabling my >> >> > internet. Both laptops suffer from this. >> >> > >> >> > An other symptom of this problem is, while playing music in winamp/wmp >> >> > small >> >> > "ticks" are audible, suggesting data loss. >> >> > >> >> > My older laptop, running Windows XP, has no problems whatsoever. No ticks >> >> > (same music) and 100% connection time. >> >> > >> >> > Any suggestion? >> >> > >> >> > Specs laptop: >> >> > - Acer Aspire 5102wlmi >> >> > - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version >> >> > as >> >> > far as I know) >> >> > - IPv6 disabled >> >> > - Windows Vista Home Premium >> >> > >> >> > Wireless: >> >> > 802.11a/b/g/n, with WPA-personal TIPK encription. >> >> >> >> >> -- >> >> Barb Bowman >> MS Windows-MVP >> Expert Zone & Vista Community Columnist >> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx >> http://blogs.digitalmediaphile.com/barb/ >> -- Barb Bowman MS Windows-MVP Expert Zone & Vista Community Columnist http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| | #14 (permalink) |
| | Re: Vista Wireless Connection Problems For those who are searching, i found a reasonable recent version (7.2.0.199) here: http://www.opendrivers.com/categoryc...-download.html "Arjan321" wrote: > Could you give some pointers of where to find those drivers? Windows update > says my version is up to date. > > "Barb Bowman" wrote: > > > try windows update. Atheros driver 7.2.0.215 would appear to be the > > latest driver. > > > > On Fri, 18 May 2007 07:52:01 -0700, Arjan321 > > <Arjan321@discussions.microsoft.com> wrote: > > > > >Hello, > > > > > >I've bought two brand new Acer Aspire 5102wlmi laptops with Vista > > >preinstalled. > > > > > >Connection to my wireless network works fine, but once in while ( once every > > >~30 minutes) the connection disconnects and connects again, disabling my > > >internet. Both laptops suffer from this. > > > > > >An other symptom of this problem is, while playing music in winamp/wmp small > > >"ticks" are audible, suggesting data loss. > > > > > >My older laptop, running Windows XP, has no problems whatsoever. No ticks > > >(same music) and 100% connection time. > > > > > >Any suggestion? > > > > > >Specs laptop: > > >- Acer Aspire 5102wlmi > > >- Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version as > > >far as I know) > > >- IPv6 disabled > > >- Windows Vista Home Premium > > > > > >Wireless: > > >802.11a/b/g/n, with WPA-personal TIPK encription. > > -- > > > > Barb Bowman > > MS Windows-MVP > > Expert Zone & Vista Community Columnist > > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx > > http://blogs.digitalmediaphile.com/barb/ > > |
| | #15 (permalink) |
| | RE: Vista Wireless Connection Problems Well, looks like the new drivers did the trick.. Still connected after a few hours.. The ticks in the music were mostly gone after deactivating IPv6 But still strange windows update didn't update my drivers. "Arjan321" wrote: > Hello, > > I've bought two brand new Acer Aspire 5102wlmi laptops with Vista > preinstalled. > > Connection to my wireless network works fine, but once in while ( once every > ~30 minutes) the connection disconnects and connects again, disabling my > internet. Both laptops suffer from this. > > An other symptom of this problem is, while playing music in winamp/wmp small > "ticks" are audible, suggesting data loss. > > My older laptop, running Windows XP, has no problems whatsoever. No ticks > (same music) and 100% connection time. > > Any suggestion? > > Specs laptop: > - Acer Aspire 5102wlmi > - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version as > far as I know) > - IPv6 disabled > - Windows Vista Home Premium > > Wireless: > 802.11a/b/g/n, with WPA-personal TIPK encription. |
| | #16 (permalink) |
| | Re: Vista Wireless Connection Problems glad this is resolved for you. On Sun, 20 May 2007 06:48:00 -0700, Arjan321 <Arjan321@discussions.microsoft.com> wrote: >Well, looks like the new drivers did the trick.. Still connected after a few >hours.. > >The ticks in the music were mostly gone after deactivating IPv6 > >But still strange windows update didn't update my drivers. > >"Arjan321" wrote: > >> Hello, >> >> I've bought two brand new Acer Aspire 5102wlmi laptops with Vista >> preinstalled. >> >> Connection to my wireless network works fine, but once in while ( once every >> ~30 minutes) the connection disconnects and connects again, disabling my >> internet. Both laptops suffer from this. >> >> An other symptom of this problem is, while playing music in winamp/wmp small >> "ticks" are audible, suggesting data loss. >> >> My older laptop, running Windows XP, has no problems whatsoever. No ticks >> (same music) and 100% connection time. >> >> Any suggestion? >> >> Specs laptop: >> - Acer Aspire 5102wlmi >> - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version as >> far as I know) >> - IPv6 disabled >> - Windows Vista Home Premium >> >> Wireless: >> 802.11a/b/g/n, with WPA-personal TIPK encription. -- Barb Bowman MS Windows-MVP Expert Zone & Vista Community Columnist http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| | #17 (permalink) |
| | RE: Vista Wireless Connection Problems Just a little update for the rest of the internets. To fix (wireless connection, crackles in sound) your Acer Aspire 5100 laptop, you have to do the following: - Update your Atheros drivers (to at least 7.2.0.199) - Update your Realtek drivers - Update your ATI video drivers. Older versions generates crackes. Don't know why.. Greetings "Arjan321" wrote: > Hello, > > I've bought two brand new Acer Aspire 5102wlmi laptops with Vista > preinstalled. > > Connection to my wireless network works fine, but once in while ( once every > ~30 minutes) the connection disconnects and connects again, disabling my > internet. Both laptops suffer from this. > > An other symptom of this problem is, while playing music in winamp/wmp small > "ticks" are audible, suggesting data loss. > > My older laptop, running Windows XP, has no problems whatsoever. No ticks > (same music) and 100% connection time. > > Any suggestion? > > Specs laptop: > - Acer Aspire 5102wlmi > - Wireless-card: Atheros AR5005G, driver version 7.1.0.90 (latest version as > far as I know) > - IPv6 disabled > - Windows Vista Home Premium > > Wireless: > 802.11a/b/g/n, with WPA-personal TIPK encription. |
| | #18 (permalink) |
| | Finally connected wireless with Vista! Hello everyone, I had not been able to get Vista to connect wirelessly despite my very concentrated efforts. After following every troubleshooting step I could think of myself or find online, and believe me, I tried everything. I had probably spend 15 hours troubleshooting. My next step was going to be a reformat and a Linux install as I can get Linux running wireless in less than 10 minutes! Finally success! How? I found an even more updated driver for the atheros wireless ar5005g here: http://www.x-drivers.com/component/o...info/id,23397/ It's version 7.3.1.73 and after updating the driver, I was finally wireless!! Now I am going to have a drink...a big one!! Cheers and hope this helps anyone else in the same predicament. EggHeadCafe - .NET Developer Portal of Choice http://www.eggheadcafe.com |
| | #19 (permalink) |
| | OOPS, almost forgot one thing... I had also disabled (unchecked) Internet Protocol Version 6 (TCP/IPv6) in the properties of the wireless connection. I don't know if it needs to be done as it is something I tried before updating the driver. Cheers. PS--I'm using an Acer Aspire 5100-5540. I had also uninstalled all of the eManagement software that came preinstalled as part of my troubleshooting. Again, I don't know if it's related. Good Luck! EggHeadCafe - .NET Developer Portal of Choice http://www.eggheadcafe.com |
| | #20 (permalink) |
| | RE: OOPS, almost forgot one thing... Just to say, thank you very much Terri None, your solution solved my problem where six Fujitsu Simens experts could not. Once again many thanks! KToast "Teri None" wrote: Quote: > I had also disabled (unchecked) Internet Protocol Version 6 (TCP/IPv6) in the properties of the wireless connection. I don't know if it needs to be done as it is something I tried before updating the driver. > > Cheers. > PS--I'm using an Acer Aspire 5100-5540. I had also uninstalled all of the eManagement software that came preinstalled as part of my troubleshooting. Again, I don't know if it's related. > > Good Luck! > > EggHeadCafe - .NET Developer Portal of Choice > http://www.eggheadcafe.com > |
| Vista 64 SP1 Wireless Connection Problems | Vista networking & sharing | |||
| Sony VAIO & Vista wireless connection problems | Vista networking & sharing | |||
| New Linksys wireless connection problems with Vista Basic. HELP!! | Vista performance & maintenance | |||
| VISTA Wireless Connection IP Resolve Problems | Vista networking & sharing | |||
| XP vs Vista wireless connection problems | Vista networking & sharing | |||
